Welcome to the North American Subaru Impreza Owners Club Sunday April 20, 2014
Old 05-16-2005, 02:48 AM   #1
booimaghost
Member#: 71144
94 MKIV
Default Boost controller with cobb AP?
Im running cobb stage 2 and Im getting some boost spikes around 18-19 psi on the normal stage 2 93oct map. I was wondering if a turbo xs mbc could solve this problem and also give me a nice constant 15psi.
Will this work with the AP?
will this stop the spiking?
Thanks
booimaghost is offline   Reply With Quote
Old 05-16-2005, 03:00 AM   #2
Max Umbarger
Member#: 1112
2006 FXT
RBP
Don't know about the controller, but as for reference I have the same stg2 and I have peaked 18-20 pounds of boost, but usually regulates close to 16 pounds. I think it just depends on load, but that is why the AP recovers it back to the ~15-16 pound range.
>>MAX
Max Umbarger is offline   Reply With Quote
Old 05-16-2005, 04:25 AM   #3
FastWagon
Member#: 20898
2002 WRX Wagon
May be worth checking your vaccuum hoses. I have AP St.2 and I was getting some spiking to 18-20psi. I checked and had a small crack in the vacuum hose connecting to the actuator. About $0.10 worth of hose and the spiking is gone
FastWagon is offline   Reply With Quote
Old 05-16-2005, 04:49 AM   #4
Max Umbarger
Member#: 1112
2006 FXT
RBP
I just did my uppipe, while moving the turbo around I seen a broken vac line. This SOB was hard. It was hard al the way to controller under the shield. I did my best at wrapping with electrical tape.
Old 05-16-2005, 06:16 AM   #5
booimaghost
Member#: 71144
94 MKIV
I actually just replaced all the hoses(and brass pill) near the turbo becaust I dident have the pill in place and with the cobb stage2 I was only hitting 9psi or so. It seems now I will spike around 17-19 and stay level at about 14-15. On my previous DSM I was spiking until I got a mbc and when I put it on I got instant steady boost with no spikes. I want to know if the AP will freak out if the stock boost system is overtaken.
Any one tryed this?
Old 05-16-2005, 11:51 PM   #6
Max Umbarger
Member#: 1112
2006 FXT
RBP
maybe look for a cheap used one and give it a shot, then if it is okay reply with the news! Then you could sell the used one and buy a better one or just use the one you used to test with.
Old 05-17-2005, 09:31 AM   #7
speedracer_sti
Member#: 87273
Have you Downloaded the new version of Stage 2.. Just curious.. It may help you a little
speedracer_sti is offline   Reply With Quote
Old 05-17-2005, 02:31 PM   #8
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
Did you reset the ECU after replacing the vac lines? It may still be trying to work too hard from old learning with the bad hoses.
TheRipler is offline   Reply With Quote
Old 05-18-2005, 06:53 AM   #9
booimaghost
Member#: 71144
94 MKIV
isent that bad if it spikes arounf 18 or so???
How do I prevent this spiking and get a nice constant level???
Do other cobb users get this spiking???
Old 05-18-2005, 11:37 PM   #10
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
One thing you might try is to adjust the actuator length on your wastegate. Spikes might be cured by turning the connector out a half turn. Each car is different. On my car, I've turned the connector in as far as it will go, and I never see boost spikes. The ecu seems to learn the change in good time. My boost hits about 16 lbs before tapering off. BTW, old APS/Club_Spec kit here with stage2 93 octane reflash (not supported anymore by COBB)
do a search on adjusting the wastegate. it's simple enough to do. just takes a few minutes.
Darryl
Darryl is offline   Reply With Quote
Old 06-03-2005, 01:00 AM   #11
Max Umbarger
Member#: 1112
2006 FXT
RBP
I know I've adjusted the actuator length it seemed to make the spike less it still spikes but is way smoother.
MAX
Old 06-03-2005, 01:01 AM   #12
Max Umbarger
Member#: 1112
2006 FXT
RBP
As for the vacuum lines, mine are very hard, also, I could not pull them off the solenoid on either end. Is there a trick? I wanted to just cut a slit in them and pull them off and replace but, if there was something more to just pulling them off I did'nt want to wreck anything. Figured I'd ask.
MAX
vf22 boost control with Cobb AP Sausage AccessPort 0 06-26-2006 11:08 AM
Boost Creep with COBB AP? Amir1987 Engine Management & Tuning 9 09-29-2004 09:10 PM
blitz sbc boost controller with cobb ecu jdzumwalt Engine Management & Tuning 2 10-08-2003 12:25 PM
