Old 05-16-2005, 09:24 AM   #1
Zaskar
Member#: 3770
MY00 GC
MY05 GD
Default STI V8 into MY00 GC8 [few questions]
1- Can I use the STI V8 axles or I have to get R180 GC8 axles?
2- Can I use the STI V8 aluminium control arms or I will end up with bad camber?
3- What to do with cruise control? It seems to be at the same place than the turbo...
4- Do I need to get GD gas pedal wire or I can use the GC8 one?
Other questions will surely come soon
Thanks!!
Zaskar is offline   Reply With Quote
Old 05-16-2005, 09:52 AM   #2
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
SEARCH, It's all been pretty much answered...
benjaminetanyahoo is offline   Reply With Quote
Old 05-16-2005, 11:04 AM   #3
2000wrx
Member#: 66659
2000 L WRX'd
wow way to be helpfull....
I would give lachute a call I think they are near you.
2000wrx is offline   Reply With Quote
Old 05-17-2005, 11:29 AM   #4
Zaskar
Member#: 3770
MY00 GC
MY05 GD
thanks 2000wrx.
And yes, I did a search. All I found is answers like "it should" or "it shouldn't". I want to hear from people who actually tried.
Old 05-18-2005, 09:18 AM   #5
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Don't know the answer to your first question, but:
2). I'm 95% sure you can, I know some people have used USDM WRX stuff with good results.
3). Throw it away/sell it. Your V8 uses an electronic cruise control system, the RS one is mechanical. You'll need an electronic WRX unit.
4). Not sure if the V8 is drive by wire, if not, yes, you can use your GC8 throttle cable, just trim it.
HTH
jamesfacts is offline   Reply With Quote
Old 05-18-2005, 10:01 AM   #6
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
GC R180 rear axles are the same length as the GD V8.
Ver.III is offline   Reply With Quote
Old 05-18-2005, 01:00 PM   #7
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Is it a USDM motor or a JDM motor? There are a variety of differences between the two, with the USDM motor being a lot more work.
Old 05-18-2005, 06:42 PM   #8
Zaskar
Member#: 3770
MY00 GC
MY05 GD
Ok, it's a JDM Ver8.
Americanyouth: JDM is not drive by wire. So maybe I'll try to use my mechanical cruise control.
Ver.III: thanks a lot!
Old 05-20-2005, 06:51 PM   #9
V6
Member#: 2703
Y2K GC8
Silver forever
Hello,
I am going to do the same think in the future (GC8 with JDM V8)
Can we share some experiences and info?
V6 is offline   Reply With Quote
Old 05-23-2005, 03:37 PM   #10
Zaskar
Member#: 3770
MY00 GC
MY05 GD
^^^^ of course. My project is halfway done. If you have any questions, feel free to ask. I'll be happy to help you!
Old 05-26-2005, 05:46 PM   #11
V6
Member#: 2703
Y2K GC8
Silver forever
do u have the DCCD also??
Old 05-26-2005, 09:53 PM   #12
Zaskar
Member#: 3770
MY00 GC
MY05 GD
No DCCD
Old 07-18-2011, 02:09 PM   #13
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
Im doing a similar swap but the JDM sti v8 is going into a 95L . you probably have to do fewer parts to make the swap work.
I read a thread that said you can reuse your gas pedal because the JDM v8 are not fly by wire. I personally am not I just bought a full 02-05 wrx pedal assembly with the lines and slave cylinder because my L doesnt have hydraulic clutch. you do so your fine there.
the aluminum control arms shouldnt give you a problem I believe they are the same length but if they are shorted you can always lower the car a bit and it should fix the problem.
Im getting rid of the cruise control I never liked it and my swap is going to be for a auto x car / track days car . depending on what your doing with it you should consider looking for an STI gas tank or the gas tank mod to help with starvation. The older tanks dont have a problem with is but Ive heard all the way up to 06 have experienced Fuel starvation in corners with 1/4 tank of gas.
Are you using the same steering rack ? have you gotten a crossmember to fit the engine? Are you doing the full drivetrain swap as well ?
jhenry1983 is offline   Reply With Quote
sti ecu into my00 wrx question ncarn8 Pre-2002 Factory Turbo Powertrain 2 10-18-2009 03:50 PM
GDB Drivetrain into 98 GC8, many questions psyctto Subaru Conversions 8 05-09-2008 08:49 PM
MY06 STi crossmember into MY00 GC NFJ79 Subaru Conversions 3 12-04-2007 02:52 AM
ej20g into 99RS: GC8 radiator question civic2scooby Subaru Conversions 8 05-07-2007 04:57 PM
MY00 GC8 power question willguidry Normally Aspirated Powertrain 8 05-06-2003 02:35 PM
