Old 05-16-2005, 01:11 PM   #1
warpath
Member#: 84622
2016 TR Golf R
1992 MKIII Supra
Default Best way to increase torque?
Before i get do a search, i did.
how can i get more torque out of the 2.0? Besides opening up the exhaust. i know going to a 3" exhaust can actually drop torque. changing gears? what is a realistic number the 2.0 can reach with out pushing the limits of the stock bearings, connecting rods,etc.
as always thanks for the help.
warpath is offline   Reply With Quote
Old 05-16-2005, 01:26 PM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
A 3" exhaust will give you more torque everywhere in the powerband. It will NOT make less torque than stock. Do uppipe, full turbo back, IC hoses and ECU reflash and enjoy your new found power.
Leaving the stock exhaust on is a recipe for a slow car.
mbiker97 is offline   Reply With Quote
Old 05-16-2005, 01:38 PM   #3
23b_Rex
Member#: 79394
02 gda
wrb
jdm swap
23b_Rex is offline   Reply With Quote
Old 05-16-2005, 02:06 PM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
bump up the boost..
jigga is offline   Reply With Quote
Old 05-16-2005, 03:47 PM   #5
brianbot5000
Member#: 44000
2013 2013 WRX Hatch
1997 Toyota Tacoma
- spool up the turbo at lower RPMs (by opening up exhaust, engine management, etc). Just an uppipe/downpipe should make a noticable bump in lower end torque, especially around 2500-3000rpm.
- Gears would certainly increase low end torque, but I would think at the cost of higher end torque (that is, if my Grand Turismo training has taught me anything).
- Lighten the the unsprung weight and rotational mass; lighter wheels can have a noticable effect. Friend of mine put OZ Superleggeras (which are about 13lbs a piece I believe) and noticed a difference.
It's never going to be a torque monster though.
Oh - and as far as the exhaust diameter -- the debate has been out on the 3" vs 2.5" diameter exhaust and which will generate more lower end torque. According to Cobb, a 3" exhaust that's properly designed will generate just as much or more torque than a 2.5". Either way you go will be OK though - 2.5" shouldn't restrict you any unless you're making a lot of power (300+). But you probably have more choices by going 3". Both are better than stock diameter.
brianbot5000 is offline   Reply With Quote
Old 05-16-2005, 04:09 PM   #6
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
USDM STi block
silver arrow is offline   Reply With Quote
Old 05-16-2005, 04:14 PM   #7
Davenow
Member#: 23676
starting at the block
Port the exh manifolds and heat wrap them
Port the Up pipe to match the manifolds (the lip)
Port the exh housing
Catless turboback exh, 3 inch all the way out.
Set lower timing numbers in the spoolup area in the timing maps of your EM to get EGT's up. Lean fueling down a bit there as well.
RA gearset in your trans
Lighter wheels
Lighter, smaller diameter tires
You are still not going to have the torque you would have with a 2.5 block swap, but it will be MUCh better than stock...
Old 05-16-2005, 04:16 PM   #8
Killian Maynard
Member#: 73734
2005 WRX I caught
you a delicious bass
Originally Posted by silver arrow
USDM STi block
I love replies like this.
Q:"How do I get more torque out of my 2.0 liter engine?"
A:"replace it with a 2.5 liter engine." <------ Must have read a different question altogether
You could run a stroker kit on your 2.0. That would give you some more torque. IIRC Cobb tuning has a 2.2 liter stroker kit available.
Killian Maynard is offline   Reply With Quote
Old 05-16-2005, 07:09 PM   #9
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
I love how you dog them, and then do it yourself!
"No replacement for displacement."
However, you can port and ceramic coat the heads, and everything after them. Also throttle body, and TGV. Y pipes, and turbo inlet hose. Intake silencer removal. NOS. That about covers it under 2.0 liters.
bofh is offline   Reply With Quote
Old 05-16-2005, 09:12 PM   #10
ronf
Member#: 51034
03 WRX, 02Forester
a more detailed numbers or examples please. Thanks
ronf is offline   Reply With Quote
Old 05-17-2005, 06:34 PM   #11
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
My point was, the least expensive way to get torque on the 2.0 is to replace with a $1700 USDM block. Do the math and even with supporting mods comes out as a good alternative. Add FP $100, injectors $400 ,VF22 $700 and tune it = >300hp/300ft/lbs across a wide rpm range.
ej207: best way to increase CR? WReXd Built Motor Discussion 10 03-05-2010 01:34 PM
Best way to increase ride height? jpfurtak Brakes, Steering & Suspension 12 03-06-2008 07:12 AM
Best way to increase low-end grunt? Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-01-2005 12:06 PM
Best way to 4 cyl HP increase? branshew Outback Forum 11 02-27-2004 10:15 AM
Best way to get more torque from EJ25? mirror70 Normally Aspirated Powertrain 43 06-16-2001 12:06 AM
