Old 05-16-2005, 03:07 PM   #1
Impreza_RSTi
Member#: 86458
Default Evap sensor problem & P0457 code questions!? plz help.
I got a USDM STi engine swap in my RS. I used my ODBII scanner to pre-test the emission sensors but the Evap sensor is always "not ready" and the code P0457 throw out once a while. I am sure I have tightened the gas cap completely and these problem should be related.
I have checked those hose under the red maniford, no loosing hose was found so far.
anyone has idea what the problem is?
Impreza_RSTi is offline   Reply With Quote
Old 05-16-2005, 05:03 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Between the RS and the wrx, at least the GC to the GD, there is an extra evap sensor thats on the GD. I'd look into that. plus you could have a leak somewhere in the system.. double check any vacuum connections on the engine and by the canister in the back..
subbyspeed is offline   Reply With Quote
Old 05-16-2005, 07:03 PM   #3
SWAT
Member#: 12493
2000 Impreza STi V6
where is that sensor located at?
SWAT is offline   Reply With Quote
Old 05-17-2005, 11:13 AM   #4
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i'll have to check my books when i get home.. I'm thinkin in the back by the canister, but i'll look and see.
Old 05-17-2005, 05:30 PM   #5
Impreza_RSTi
Member#: 86458
if you find the answer from ur books, please let me know
Old 05-20-2005, 09:25 PM   #6
Impreza_RSTi
Member#: 86458
the O2 and catalyst sensors take forever to be "ready" if I use ODBII scanner to check, is it normal to all Subarus?
FS: STi evap canister with lines and evap sensor (bOOsted) Engine/Power/Exhaust 5 07-15-2013 02:57 PM
HELP!!! Problem with 2nd O2 sensor running a lean code? JTS88 Newbies & FAQs 7 05-25-2009 08:35 PM
EJ22T running rich, O2 sensor wires & error codes in all 4 injectors s'ko Legacy Forum 2 07-09-2008 08:26 AM
P0457 Code Keep getting it Works Engine Management & Tuning 16 07-04-2003 12:19 PM
OBD-II: P0457 code Drews_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-02-2003 06:28 PM
