Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-31-2001, 07:29 AM   #1
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
Default Wolf 3D + Stock Injectors?
Boeleni is offline   Reply With Quote
Old 07-31-2001, 10:26 AM   #2
SubaFastR
Member#: 5786
using a rrfpr would totally mess up your Wolf's fuel maps. Get some injectors first. Kaos200 is selling some 330cc RC injectors.
Kevin
SubaFastR is offline   Reply With Quote
Old 07-31-2001, 04:01 PM   #4
kaos200
Member#: 2692
actually I have 370cc RC injectorsthat I am selling soon, they have been used with the Wolf 3D, no RRFPR needed at all, and I can support 15psi if needed...
kaos200 is offline   Reply With Quote
Old 07-31-2001, 04:26 PM   #5
SubaFastR
Member#: 5786
I was close!
Old 08-01-2001, 02:12 AM   #6
kaos200
Member#: 2692
Talking
ROFLMAO!
Kevin I told you, that extra 40cc an injector can make a HUGE difference!
Old 08-01-2001, 03:36 AM   #7
SubaFastR
Member#: 5786
spoken like a true salesman
Old 08-01-2001, 10:10 AM   #8
efoo
Member#: 80
I have to disagree - it is very unlikely 370cc injectors can support 15 psi of boost on a EJ25 without bumping up the fuel pressure. Shiv ran out of fuel with his 550cc injectors at 14-15psi when he was pushing his engine to the limits. Even with my own car, I run 60-65% duty cycles at 7psi with 550cc injectors, indicating that I'm using ~360cc already.
-Edwin
efoo is offline   Reply With Quote
Old 08-01-2001, 10:26 AM   #9
SubaFastR
Member#: 5786
5500 rpm?
Old 08-01-2001, 12:38 PM   #10
shiv
Member#: 607
-Edwin
On pump gas, I ran out of fuel (85+% duty cycle) at 10psi and 280 wheel hp. On a race gas/pump gas mix (which allowed a leaner fuel curve), I ran out of fuel at 13psi at 296 wheel hp. Injectors actually went wide open in the end and ran me a little too rich up top. I suppose I could have raised the boost even more to compensate but that would have been risky, to say the least
Cheers,
shiv
shiv is offline   Reply With Quote
Old 08-02-2001, 02:18 AM   #11
kaos200
Member#: 2692
just so you know... I was stuck at 5,500 rpm with that setting, the crank sensor shook above that and wouldn't allow the revs to be read....
so there it is, I agree, I dont think 370cc's will hold up at full rpm at that boost either, but I never went lean and didn't ping either...
Old 08-02-2001, 03:44 AM   #12
kaos200
Member#: 2692
and my fuel pressure and entire fuel system have been "bumped up"...
AP Header, 850cc injectors, stock injectors, parts, etc nXgnSTi TXIC Private Classifieds 54 05-30-2010 04:48 PM
RS-T with Wolf 3D insanesuby Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-17-2003 09:56 AM
who has a Wolf 3D? sanders Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-22-2001 06:49 PM
Wolf 3D and Boost Control Boeleni Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-22-2001 06:02 PM
Tec-II vs Wolf 3D Saw Jai Normally Aspirated Powertrain 8 03-15-2001 09:29 PM
