North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 05-17-2005, 02:01 PM   #1
Letitrip
Member#: 57914
2004 WRX
Java Black
Default Question on lowered springs
Is it normal to hear the springs noise? I have Espiler GT springs. Front I can hear the slamming noise when I hit a small bump . While it didn't do that when it was stock. Rear end I hear the right side rattle after heavy pull 1st and 2nd gear and reverse. I know there was some issues with top hats on the rear for the 04 WRX. But this never happened until the new springs was installed. That's the best I can describe it. Everything is tight to spec.
Letitrip is offline   Reply With Quote
Old 05-17-2005, 02:11 PM   #2
Shifty Eyes
Member#: 72126
2004 Sold WRX Wagon
Now 07 GT Leg Pearl
I remember when mine were new on my wagon. I have tein s-techs and for about a month or so they would make a soft popping sound, I was pretty sure it was from when they were new. Now there're quiet as could be. But they only made that sound when I would come into steep driveways.
Shifty Eyes is offline   Reply With Quote
Old 05-17-2005, 02:19 PM   #3
Letitrip
Member#: 57914
2004 WRX
Java Black
I have had it for almost 6 months now. I thought it would stop as well.
Old 05-17-2005, 03:09 PM   #4
kleinfreak
Member#: 37233
Shut Up,
I'm making bacon!
When you reassembled the springs and struts, did you ensure that the top plate (cup) was facing out? There should be 3 holes as I recall. If these are facing the wrong direction (either front, back or inside) it can cause the spring to compress at an angle causing a knocking or rattleing when you hit a bump.
kleinfreak is offline   Reply With Quote
Old 05-17-2005, 04:10 PM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
how much do these springs lower?
sounds like you're compressing/bottoming out....
Jamie
www.subeigal.cmo
Old 05-17-2005, 04:35 PM   #6
Letitrip
Member#: 57914
2004 WRX
Java Black
Kleinfreak, I can't recall if I was paying attention to that. It seems that I re-installed it as logically as i removed the OEM springs.
Subiegal, I believe the front drops just a little under 1.5". Back .5" or no difference from stock.
Old 05-17-2005, 05:10 PM   #7
RoundtheBend
Member#: 5034
2004 Money Pit
silverish-mud
The Espiler GT springs I just put on my FXT are a 30mm drop front and 20mm drop rear.
I bought the '04 WRX springs and they were put on the '04 STi factory struts. I have no NEW noises since the install.
RoundtheBend is offline   Reply With Quote
Old 05-17-2005, 05:25 PM   #8
Letitrip
Member#: 57914
2004 WRX
Java Black
Thanks for the input. It sound like I have a couple of things to check out base on kleinfreak recommendation.
Old 05-17-2005, 05:53 PM   #9
SeattleWRX
Member#: 10350
02 WRX Sedan
I may have this same problem. I'll try what kleinfreak said.
SeattleWRX is offline   Reply With Quote
Old 05-17-2005, 06:17 PM   #10
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
You said you had a rattling noise sometimes... after installing my springs/struts (RS) I had a rattle when I reversed. It turned out that my rear cross member got bent somehow during the install
twizzstyle is offline   Reply With Quote
Old 05-17-2005, 06:22 PM   #11
Letitrip
Member#: 57914
2004 WRX
Java Black
I am not sure how I could of bent the xmember, but that something to look at.
Need Help Deciding on Lowering Springs on 2002 Wagon.. NEED PICS! Cain0023 Member's Car Gallery 22 03-03-2010 05:12 PM
Quick question about lowering springs GTWagon_Phreak Brakes, Steering & Suspension 3 02-04-2006 08:48 PM
Quick question on lowering springs? WRedX Brakes, Steering & Suspension 1 05-09-2005 07:15 PM
Question about lowering springs (04 WRX/STi pinks) Spin4 Brakes, Steering & Suspension 1 04-11-2004 11:28 PM
Question about lowering springs? rayw1128 Brakes, Steering & Suspension 0 08-15-2002 01:11 AM
