05-17-2005, 04:13 PM | #1 |
Member#: 55651
Vehicle:2004 Impreza WRX Platinum Silver |
STi Cluster question...
ok, i have tried several searches, all of which turned up nothing. quickie question...when putting an STi cluster in a WRX, i noticed that the STi goes to 160 and WRX goes to 140. Does the STi cluster register the speed the same? ie...it actually displays the speed, not just a stepper motor showing 50% of the max speed?
so, as simply stated as can be...if the STi cluster shows me doin 80 (which is 50% of the speedo, roughly) am i ACTUALLY doing 80 or am i doin the 70 the WRX cluster would normally show? does this make sense?
05-17-2005, 04:25 PM | #2 |
Member#: 84565
Vehicle:2000 Impreza 2.5 RS Full USDM STi Swap |
good question
05-17-2005, 04:50 PM | #3 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
It will read correctly. The signal sent to the cluster is a number of pulses per revolution of the axles, not a '50% of max' kind of thing. The cluster electronics themselves deal with the coversion of pulses per second to speed.
So, installing a STi cluster on a WRX will result in 80 MPH actually being 80 MPH (+/- the usual error due to tire size, etc), regardless of max speeds on the gauge. |
05-18-2005, 10:42 AM | #4 |
Member#: 55651
awesome...i went thru and did some timed tests on the speedo on the interstate. this is absolutely correct. everything seemed ok. i appreciate the info, none the less...feels good to officially know i'm actually doin the speed it shows :P
05-23-2005, 03:52 AM | #5 |
Member#: 78675
Vehicle:2002 white bugeye 04 kawasaki 636 |
lucky, i wish i had an sti cluster in my wrx.
05-25-2005, 05:27 PM | #6 | |
Member#: 31816
05-25-2005, 11:09 PM | #7 | |
Member#: 70656
RMIC
Vehicle:Old Mazda3 Hatch Shelby Lancer #623 |
All that matters is they are close enough! |
05-25-2005, 11:19 PM | #8 | |
Member#: 77483
NWIC
Heh, tire pressure, tire tread, clutch wear, road condition are all easily enough to make a 5MPH difference.
05 STI Cluster Question | stimko68 | Interior & Exterior Modification | 2 | 08-16-2007 11:21 PM |
JDM STi cluster question. | burritotown | Interior & Exterior Modification | 1 | 11-19-2006 10:02 PM |
STI Cluster Question | Rustyr6 | Electrical & Lighting | 6 | 09-01-2005 02:33 AM |
sti cluster question | WrexLifter | Interior & Exterior Modification | 17 | 10-22-2004 08:03 PM |
STi cluster questions | Davenow | Interior & Exterior Modification | 8 | 12-09-2002 09:46 PM |
