Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 05-18-2005, 10:38 AM   #1
nyngbld
Member#: 60326
2004 WRX
Black -AndThenSomeCHIPS-
Default Clear My04 Headlights Info
I read through the gigantic sticky in this forum about 3 times. I am going to attempt this on my04 this weekend. I am still a little nervous, just unsure about getting the lights to seal well afterwards. Also don't want to scratch them or crack anything. I will use a huge terry cloth towel to keep my lights on while working on them. I wanted to see if anyone had any little suggestions or tips they ran into in the process of clearing your lights? Thanks all.
-ny
nyngbld is offline   Reply With Quote
Old 05-18-2005, 11:22 AM   #2
edaniele1212
Member#: 71013
2004 WRX STi
Java Black/Goldies
take your time and do exactly what the sticky says and use extra sealer its worth the 8$ and the time to do it all over again if it leaks.
edaniele1212 is offline   Reply With Quote
Old 05-18-2005, 11:27 AM   #3
B WReX
Member#: 50747
2004 WRX
the sticky is awesome - just follow it, and you'll have no problems. I did not use any extra sealant, and everything seems fine
B WReX is offline   Reply With Quote
Old 05-18-2005, 11:33 AM   #4
paperchasin
Member#: 57117
2004 STi
$5 for the black sealant...was able to do over 6 sets of headlights with that tube...$5 for peace of mind and NO leaks/fogging....
paperchasin is offline   Reply With Quote
Old 05-18-2005, 11:36 AM   #5
Thumper23
Member#: 11571
I followed the sticky and mine came out great
Thumper23 is offline   Reply With Quote
Old 05-18-2005, 11:40 AM   #6
nyngbld
Member#: 60326
2004 WRX
Very cool, thanks guys. I am looking foward to this mod.
Old 05-18-2005, 01:00 PM   #7
kheovnien
Member#: 79025
2004 WRX
when u take the headlight out remember u kind of have to pry off the white plastic piece that is hidden behind the bumper (u use a 10mm ratchet to unbolt it first). it is held behind there so u'll have to pop it out for the assembly to come loose. i put a screwdriver behind the white plastic piece and popped the headlight loose. just be careful and u'll figure it out when u see it.
kheovnien is offline   Reply With Quote
Old 05-18-2005, 01:10 PM   #8
willguidry
Member#: 16388
This is on the side closest to the grill of the headlight. It will be the only thing holding the lights into the frame once all bolts are removed.
Grab it close to the grill, and give it a sharp tug STRAIGHT back to you. You'll here a crack sound, it won't break, don't worry and the headlight will be in your hand. When re-installing, go in that side first and give it a good whack with an open palm on the front assembly and you'll hear that crack again. That means it in and secure.
This mod seriously...is VERY easy. Take your time with the heat. DO NOT use BROIL. Use BAKE at lowest setting. (200 degrees F.)
If you have adjustable racks, put the rack on the bottom with a sheet pan on the rack. Don't just put the headlight on the bare rack. (helps disperse heat evenly)
Do one headlight at a time, I didn't need extra caulking...and no leaks. On two pairs. Just make sure you reheat them again to warm the caulk when you put em back together, then QUICKLY put all the screws back in.
If you have any worries, or questions, PM me.
willguidry is offline   Reply With Quote
Old 05-18-2005, 05:37 PM   #9
nyngbld
Member#: 60326
2004 WRX
Thank you all again. I did actually pull the lights out to see how difficult that would be. It did take a decent yank to get that white tab out of the clip. At that point I bitched out and didn't bake them. Hopefully I can step up and just "git r done." ty.
-ny
Old 05-18-2005, 07:09 PM   #10
DieselClown
Member#: 36135
2005 WRX
one bit of advice, be careful when you pry out the orange pieces! the housing car crack VERY easily! also, buy a tube of silicone and make sure every inch of the housing is sealed before the final bake.
DieselClown is offline   Reply With Quote
Old 05-19-2005, 12:41 PM   #11
nyngbld
Member#: 60326
2004 WRX
Can I still go at it with flathead screwdriver or should I consider some other means? ty.
Old 05-19-2005, 12:45 PM   #12
willguidry
Member#: 16388
Use a jewelers flathead screwdriver.
You can get em at any hardware store.
That's what they look like. Go easy, and you'll get em out.
Old 05-19-2005, 01:31 PM   #13
fireball_jones
Member#: 67536
00 AW GM6
And a bunch of parts
I pulled mine out with the smallest flathead I could find. Bigger than a jewlers, just small enough to fit in the housing to pop the cover for the parking lights off. The other covers (side reflector and turn signal) are very easy to get out.
fireball_jones is offline   Reply With Quote
Old 05-19-2005, 04:26 PM   #14
subieworx
Member#: 47769
I haven't used any extra sealant on mine and I have had them apart 3 times now with no subsequent fogging or leaking issues.
subieworx is offline   Reply With Quote
Old 05-19-2005, 04:36 PM   #15
willguidry
Member#: 16388
+12345
Old 05-19-2005, 09:58 PM   #16
DieselClown
Member#: 36135
2005 WRX
i sealed them up good for the added piece of mind. The last thing I need is a wet hid bulb.
Old 05-19-2005, 10:03 PM   #17
Ohannon7
Member#: 63824
05 WRX WRB pearl
Cobb II+
when they say use the jewlers flat head they mean it, and pleae be very patient, I am not. I just did it over the weekend and crackd part of the black frame in the lense, but its ok, I fixed it to where you cant tell.
Be patient, and most importantly do not pry, those orange lenses are hard to pop out
Oh, and I used a heat gun, i dont trust the oven method but thats just me, others have done it. Be sure to heat the sealant back up really really well b4 you put it back together, the last thing you wanna have to do it pop them open again just to reseal them. Theres a local wrx w/ condensation in his light
Ohannon7 is offline   Reply With Quote
Old 05-19-2005, 10:33 PM   #18
jmh
Member#: 28568
09 G8 GXP
silver/silver
This was the first mod I did. I didn't use any sealant and at just over a year and a 1/2 I'v had no leaking or foging . But this is the valley of the sun. Not so much in the way of cold rain
jmh is offline   Reply With Quote
Old 05-19-2005, 11:03 PM   #19
millerbc
Member#: 81205
2005 WRX STi
any one in central NY (syracuse aera) have experiance clearing headlights? I hear it is a little easier with another set of hands.
6 pack of your choise to whom ever can help me out.
millerbc is offline   Reply With Quote
Old 05-20-2005, 11:03 AM   #20
nyngbld
Member#: 60326
2004 WRX
Should I bake them open to warm sealant, then put the together and bake again to seal? Or should I just put them together, bake and put pressure on them to seal and put screws back in?
I will take my time, I am gonna try and get those jewelers tools. Thanks all.
-ny
Old 05-20-2005, 11:36 AM   #21
subieworx
Member#: 47769
-ny
That depends on how quickly you can take them apart. I can do it fast enough now that I don't have to heat them back up, didn't the first time either. If you take longer than 5 minutes I would heat them back up for a few minutes separately then put them back together.
Old 05-20-2005, 11:37 AM   #22
willguidry
Member#: 16388
Close them when you are done to the best of your abilities. LEAVE THE SCREWS OUT.
Rebake to warm sealant, (one light at a time) and remove them QUICKLY, pushing them back together and put the screws to em quickly.
Old 05-23-2005, 11:12 AM   #23
nyngbld
Member#: 60326
2004 WRX
Ok, what the hell??? I know I am not a subie specialist, but I am not a TOTAL jackass. Everything was great, until I went to seperate the lights. Baked first light for 18 mins, removed all screws, got top portion of light to seperate, but thats it. Is there a decent ammount of force required to pull the two sections apart? I could not get it over the clips on the bottom. Should I pop the clips off the bottom some how first, then pull the lights apart, or will they just come open like a taco and still be hooked on bottom? Did I just not pull hard enough? It seemed like the top opened ok, but they would not seperate on sides? Not enough bake time? The silicone was pretty sticky, decent amount got on screw driver. Instructions make it sound like they just come apart. Once it was not coming open, I re-sealed them, I thought I may not get them back together. The housing on the top bulb seemed like it was loose and would fall onto the lower headlight. Thanks for the help, I am pretty annoyed I couldn't get this simple **** done.
Old 05-23-2005, 11:23 AM   #24
CapeRex
Member#: 81070
I did mine this weekend,and that was the only problem I had....I broke a part of the housing prying out the orange part.The first one went smoothly,because I was patient and following the instructions,but I rushed on the second and that happened...so be patient! I also broke a bulb,but so far everything is great! It has rained non-stop the last few days and I've seen no fogging yet....fingers crossed.
The hardest part was prying the first headlight out of the car...I was afraid to use too much force,but it took a good tug to get it out.The second was a piece of cake.
CapeRex is offline   Reply With Quote
Old 05-23-2005, 12:14 PM   #25
nyngbld
Member#: 60326
2004 WRX
So did you need a decent amount of force to get the light pulled apart? I didn't want to yank on them too hard and break anything, but I was pulling decent and they still would not budge.
How to clear MY04 headlights - photo instructions skivvie Car Care & Detailing 1374 03-14-2015 02:07 PM
WTT: Cleared 04 headlight for not cleared headlight STREETFAME16 Exterior/Styling 0 10-22-2009 03:47 PM
cleared out headlights for MY04 Nonijuju Interior & Exterior Modification 3 08-12-2005 02:12 PM
Clear LHD headlights for MY04 STi? trrbocharged Electrical & Lighting 7 07-05-2004 12:41 PM
