05-18-2005, 02:40 PM | #1 |
Member#: 86646
Vehicle:2004 WRX sedan Black |
Blitz DCII DTT vacuum hose install
I know this has defintely been asked a million times, but I am still having trouble. Where is the easiest location to get this vacuum line through the firewall and to another vacuum source. I have checked some threads, but I'm still not sure how to go about it. I appreciate any advise. Thanks.
Jeff
05-18-2005, 04:03 PM | #2 |
Member#: 76565
International
Vehicle:CLXX Stricta Parata Neci! |
I am assuming you mean the boost gage tube. It depends on where you mount it...I have mine right next to the cup holder on the dash, and I ran the tube down the pillar, through the driver fender, and it came out next to the battery. I also had it go through the firewall down by where your ecu is.
05-19-2005, 04:25 PM | #3 |
Member#: 86646
I wound up running the hose through the firewall on the passenger side. Everythings is working fine. I did have trouble connecting to the P brake ground wire. It was so tight that I could not cut it to splice it together. I stripped the wire from the turbo timer about three inches and wrapped it around the terminal tightly, then soldered it to make a good connection. No problems so far.
FS CA: Blitz DCII DTT Turbo Timer + Perrin Radiator Shroud | 1FSTREX | Engine/Power/Exhaust | 9 | 10-21-2009 02:59 PM |
Blitz DCII DTT | IBAUCLAPlaya | Electrical & Lighting | 2 | 06-22-2004 08:00 PM |
Blitz DCII DTT | IBAUCLAPlaya | Mid West Subaru Owners Club Forum -- MWSOC | 1 | 06-11-2004 11:00 AM |
Blitz DCII install not working. Need help. | Microbomb | Electrical & Lighting | 3 | 05-17-2004 08:44 PM |
Blitz DTT DC II install ? | NGNIOUS | Electrical & Lighting | 8 | 04-07-2003 09:39 PM |
