Old 05-18-2005, 02:43 PM   #1
SubiePilot
Member#: 85245
V7 STi wanna be
Default 245/40 R17s with lowering springs
Wanted to talk to someone who has this set up and if they have rubbing issues. I have a 02 WRX sedan. I am currently running these tires on stock suspension but would like to put on the eibach pro kit, and I don't want to roll the fenders. If this does not work any suggestions for tire size that will not rub.
Thanx,
SubiePilot
SubiePilot is offline   Reply With Quote
Old 05-19-2005, 11:56 AM   #2
whiteGDB
Member#: 41081
2009 Forester
well I'm running 245/40/17 SO3s on 17x8.5 +50 wheels and -1.5 rear camber. I also have pink springs and the only time I exprience rubbing is with a full load going over speed bumps.
It's all going to depend on your tire brand and mainly your wheel specs (i.e. width, offset) but it's doable with a correct setup.
whiteGDB is offline   Reply With Quote
Old 05-19-2005, 08:24 PM   #3
SubiePilot
Member#: 85245
V7 STi wanna be
I am currently running S02s the wheels are 17x8 +48 and not sure what the rear camber is. But thanks for he help
Old 05-19-2005, 09:23 PM   #4
whiteGDB
Member#: 41081
2009 Forester
That's going to be close. Even though you have a half inch narrower wheel, which give you about a 1/4 inch more clearence over my wheels, your tires are just as wide if not wider.
17x8 +48 and 245/40/17 with lowering springs? xevash Tire & Wheel 11 01-22-2010 12:36 AM
So Cal: Dunlop SP Winter Sports M3 245/40/R17 FestaH Wheels/Tires 30 09-30-2007 07:09 PM
06 TR 245/40/r17 Rexxyou Tire & Wheel 6 05-09-2006 11:09 AM
245/40/17 on lowering springs? wrxwhip Tire & Wheel 0 06-20-2005 03:13 PM
245/40 R17 can this work? SubiePilot Tire & Wheel 8 05-03-2005 04:52 PM
