Old 05-18-2005, 03:28 PM   #1
Udonboy
Member#: 40788
2004 WRX Sedan
Default Difference between WRX Prodrive and STI Prodrive springs?
I was wondering what exactly are the differences between the Prodrive springs made for the WRX and the Prodrive springs made for the STI are? To be a little more specific, I'm more interesed in how the 04+ WRX Prodrive springs differ from the STI Prodrives. I know the STI Prodrive springs are red and the WRX are blue. I'm assuming the springs rates are different, but what exactly is different? Thanks
Jason
Udonboy is offline   Reply With Quote
Old 05-19-2005, 03:28 AM   #2
Udonboy
Member#: 40788
2004 WRX Sedan
Anybody?
Old 05-19-2005, 03:38 AM   #3
EZ Rider
Member#: 38224
2004 WRX
Spring rates. Maybe ride height. They don't publish their rates though so no one knows. My assumption would be you can't use your stock WRX struts with them, if that's where you're going with this.
edit: Not that you can't use stock struts, but you shouldn't.
EZ Rider is offline   Reply With Quote
Old 05-19-2005, 03:42 AM   #4
Udonboy
Member#: 40788
2004 WRX Sedan
I already bought the WRX Prodrives, but I was just wondering what the differences are between the two.
Old 05-19-2005, 08:22 AM   #5
Siper2
Member#: 1134
2007 BMW 328xi wagon
Not sure. EZ Rider is probably right, though.
2002+ Impreza spring rates for Prodrive/STi springs have been typically lower than the spring rates for Prodrive/STi springs on the old-style cars... The P1 springs are ideally paired with STi Type RA struts, but work with regular STi V5/6 struts if need be.
However.... I bet the springs are still taut enough to be better off with STi struts on a new-age car.
=S2=
Siper2 is offline   Reply With Quote
Old 05-19-2005, 01:57 PM   #6
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
prodrive springs for the STi also get a bumpstop replacement.
Arnie is offline   Reply With Quote
Old 05-19-2005, 10:02 PM   #7
Zuffy
Member#: 35268
2004 WRX Stg2 & with
added PDX goodness
STi struts have external bump stops?
Zuffy is offline   Reply With Quote
Old 05-20-2005, 12:21 AM   #8
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
They're external to the strut, but internal to the strut assembly/housing... more or less. You remove a nut on the bottom of the strut housing/assembly, pull the strut itself out from the top, and there's a bump stop on the shaft of it. The strut looks pretty puny once you get it out.
-Mike-
CreoWRX is offline   Reply With Quote
Old 05-20-2005, 01:06 AM   #9
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
Prodrive (Eibach) makes different springs for different cars.
WRSport (2001-prior RS)
44s (2002-2003 WRX, TS, RS)
44s (2004 WRX)
Sports (STi, 2004-2005)
Might want to look at Eibach if you are needing spring rates. The only thing Prodrive offers is alingment settings.
WRXedUSA is offline   Reply With Quote
Old 05-22-2005, 07:00 PM   #10
Zuffy
Member#: 35268
added PDX goodness
-Mike-
Cool, thanks! I saw the Prodrive instructions, and you are right the strut shaft does look puny.
difference between wrx tr and sti exhaust.... 8smitty Newbies & FAQs 4 08-16-2007 08:43 AM
Difference between 04+ Sedan and Wagon rear springs Arnie Brakes, Steering & Suspension 3 02-25-2006 02:20 PM
Difference between the 22b and sti ver 5/6 spoiler? LB2.5rs Interior & Exterior Modification 13 10-06-2003 06:19 PM
Did a search- Difference between Subaru OEM and STi 4-pots? beachbum Brakes, Steering & Suspension 8 07-15-2001 10:07 PM
