Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 05-18-2005, 07:36 PM   #1
JDaltonRobertson
Member#: 87472
Default 300 subaru bucks...what to buy?
Ok, so I have an 04 FXT, no mods. I have 300 subaru bucks and am thinking of buying the rear sway bar and having it installed in my next service...is this a worthwhile mod, and if not, what else would you recommend?
JDaltonRobertson is offline   Reply With Quote
Old 05-18-2005, 07:48 PM   #2
nrequeNmimi
Member#: 77646
2005 EVO VIII
SILVER
Wirelessly posted (Nokia6230/2.0 (04.43) Profile/MIDP-2.0 Configuration/CLDC-1.1)
A Sway bar sounds like a safe bet.
nrequeNmimi is offline   Reply With Quote
Old 05-18-2005, 11:24 PM   #3
Roo
Member#: 14931
I'd recommend that you buy the sway bar, end links, and STi sway bar mounts, save yourself some Subybucks, and do the install yourself. It's so easy, just get your trunkmonkey assistant to help you.
Roo is offline   Reply With Quote
Old 05-19-2005, 06:25 AM   #4
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
I'd go for the autodimming mirror/compass and the rubber rear bumper guard. STi takeoff sways can be had for $75.
Subahaulic is offline   Reply With Quote
Old 05-19-2005, 06:47 AM   #5
JDaltonRobertson
Member#: 87472
Is there a noticeable difference in ride/handling with the sway bar? Also, I know almost nothing about mechanical stuff, would it still be easy to install? BTW what is a trunk monkey?
I've got dimming mirror, that came factory. It is a great option, never had it before.
Old 05-19-2005, 07:23 AM   #6
Subahaulic
Member#: 51163
Sway improves roll angle during cornering w/out detracting from ride. Definitely, go for the short shifter setup. Since you don't have a trunk you will need to borrow someone else's trunk monkey. They mostly are used to shift weight during tight turns and require little more than an occasional case of beer to do the most onerous of tasks.
Old 05-19-2005, 08:40 AM   #7
Corkfish
Member#: 39503
I've heard of problems with an upgraded swaybar on the FXT. Look at the rest of the suspension, the endlinks and trailing arms aren't up to it (check out the cheap little welding!)
Corkfish is offline   Reply With Quote
Old 05-19-2005, 09:59 AM   #8
Subahaulic
Member#: 51163
Many use Poltech endlinks w/ the 20 mm STi takeoff. OEM Trailing arms are good to go.
Old 05-19-2005, 12:00 PM   #9
pleiad7
Member#: 71056
MY04 Forester XT
And don't be tempted to believe you can save cost by substituting a trunk dog for the trunk monkey. I've tried it, and the dog didn't work out at all... He spent most of the time sliding around and clawing for traction instead of actively helping with the weight shifting task!
pleiad7 is offline   Reply With Quote
Old 05-19-2005, 12:07 PM   #10
02rex
Member#: 15151
2005 Forester 2.5XT
I used part of my $400 Subarubucks to buy FXT STi springs from Jamie. The install is a piece of cake if you have spring compressors and airtools (good spring compressors cost about $50). stiffer ride but not too stiff.. less brake dive too.
02rex is offline   Reply With Quote
Old 05-19-2005, 12:51 PM   #11
yungster1972
Member#: 71827
2004 Forester STi
Java Black Pearl
Sway bars would be the first thing I would do. In fact the was the first thing I did. You can use STi takeoff sway bars. But I would buy a good set of hollow tube bars. I drive my car pretty hard and so far my factory endlinks and mounts are still in good shape. Another mod the can be done fairly cheap is, if you would to lower your car a little you can get a set of 04 WRX struts and springs for $200. They also have better dampening qualities compared to the Forester struts. -ED- Also with swaybars you will notice the difference on the first drive after the install :}
yungster1972 is offline   Reply With Quote
Old 05-19-2005, 01:57 PM   #12
bluesubie
Member#: 767
04 FXT
The rear sway bar is not a part available specifically for the Forester. It is for the STi sedan, so your dealer may not install it unless they're just really cool.
I bought mine from SubieGal (allsubaru.com) and installed it using scoobymods.com. I learned how to do my first sway bar install (WRX), by using scoobymods.
I would probably go with the F-STi springs, but it depends what you want.
-Dennis
Old 05-19-2005, 05:19 PM   #13
JDaltonRobertson
Member#: 87472
Hey thanks for all the input. I don't drive my FXT too hard, as I use it as my commuter car on a long stretch of highway. Swaybar might be the way to go. I also might check in them throwing on a tow-hitch. Not exciting, but practical. Kind of like my auto transmission. After 2 years with a modded '94 Audi S4, I miss the shifting.
Old 05-19-2005, 05:21 PM   #14
silvaru
Member#: 70763
2007 legacy
newport blue pearl
if you upgrade the sway bar you need to upgrade the mounts. after 10k miles the swaybar mounts cracked and the left one broke loose. the banging noise will scare the poop out of you. i also changed the end links because the broken mount bent one. the stock end links are what comes on the sti so i think the should hold up.
silvaru is offline   Reply With Quote
Old 05-20-2005, 12:54 PM   #15
Subahaulic
Member#: 51163
I think you should get Poltek adj. endlinks w/ STi rear sway--go to subaruforester,com for details.
Old 05-20-2005, 01:17 PM   #16
looney
Member#: 44464
2004 FXT-MT
w/hitch for my c-crib
have suspension, wheels, training tweeks, tune upgrades...but 300 is almost half of what you'll need for a cobb AP...
best mod ever
looney is offline   Reply With Quote
Old 05-20-2005, 04:35 PM   #17
eb50
Member#: 50947
2005 OBXT LT
remote start if its an auto
eb50 is offline   Reply With Quote
What to buy with Subie bucks? Layman Off-Topic 10 10-20-2006 10:36 AM
What to buy with $500 Subaru Bucks chuckml97 General Community 28 04-26-2006 04:41 PM
wtb 300 subaru bucks onionring Private 'Wanted' Classifieds 1 04-05-2005 07:36 PM
$500 subaru bucks what to do? WRXout General Community 24 02-28-2005 07:00 PM
('93-'01) 2 $100 MBNA Subaru Coupons, what to buy? IMPREZIV Impreza Forum 24 08-08-2001 05:50 PM
