Old 05-19-2005, 02:20 AM   #1
MeshmeZ
Member#: 58908
'07 STI
Default getting WRX swap ok'd for smog?
im going to be swapping a WRX motor into my RS this summer, i was curious what the process is for getting it certified. do i just make an appointment with the smog ref? and what kind of paperwork do i need? do i need to prove i bought the engine or anything like that? thanks for any info.
MeshmeZ is offline   Reply With Quote
Old 05-19-2005, 07:05 PM   #2
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
You might wanna ask a local shop that does swaps. I know ispeed is in california, mabye PM them and then post what answers you get.
DoctorNick is offline   Reply With Quote
Old 05-19-2005, 08:18 PM   #3
SWAT
Member#: 12493
2000 Impreza STi V6
They should be state legal if all sensors work
http://www.smogcheck.ca.gov/stdPAge....ee_Centers.htm
ask adam at www.licmotorsports.com
SWAT is offline   Reply With Quote
Old 05-19-2005, 08:41 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
You need to do a lot of smog/dmv work and spend a good amount of money at both. Your best bet is to talk to i-speed they are the only vendor I know of to get a swap to pass CA smog.
Old 05-19-2005, 09:02 PM   #5
MeshmeZ
Member#: 58908
'07 STI
totoherbs: i was under the impression that the swap was easy to get passed..
Swat: thanks for the link it is helpful.
guess i will be calling some places for more info
Old 05-19-2005, 09:23 PM   #6
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
granted i don't know the cali smog laws, i would think, a wrx engine, regardless of what car its in, if its wired correctly and has all the stock stuff running off of it, i don't see why it wouldn't pass the donor cars' emission laws.
subbyspeed is offline   Reply With Quote
Old 05-19-2005, 10:02 PM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Well if there is a bad sensor anywhere, it will fail. The wiring will need to work right with the correct ECU and it will pass. If you are looking for one to pass, i'd definatly recommend one of the shops who has done it before rather than DIY.
Old 05-20-2005, 01:05 AM   #8
MeshmeZ
Member#: 58908
'07 STI
im not worried about it passing. i just basically need to know the process. i have a donor wrx and im basically swapping everything over. i know that the wrx motor in my car with all the wrx sensors ecu etc is legal. i just need to know the process to get it certified. thanks for the reply here and on the other board kostamojen
and i dont feel like paying someone to do the swap. for me, doing it myself is 75% of the fun anyway.
Old 05-20-2005, 08:22 AM   #9
totoherbs
Member#: 7321
.... 122 IggPoints
Originally Posted by I-Speed USA
OK.
I am not clear what each state's rules so bear with me.
In CA, the state referee checks out the car/swap for...02 sensors, emission equipment, Co and Nox, and they want to connect to the ECU.
What we did to the JDM/WRX conversions is this:
- combine the JDM and USDM harness (the jdm harness is without emission stuff and the USDM is without the AVCS stuff)
- Keep as many things stock as possible.
- Keep the USDM ecu in the car for the state referee check so that the ref can see it with their scanner.
Some people ask about the AVCS.
Rather than switch the pin-out from the TGV to the avcs for the jdm ecu, we added more wires so that we can use the USDM AND jdm ecu. Of course when using the USDM ecu , we do not have avcs.
If all your wiring is correct and/or you have a re-flash on either the JDM or USDM ecu, then you should be able to run BOTH the US and JDM ecu's without any problem.
Chris
I-Speed USA
4168 Avenida De La Plata Ste.116
Oceanside, Ca.92056
[email protected]
http://forums.nasioc.com/forums/show...highlight=smog
This thread should help...
Old 05-20-2005, 12:09 PM   #10
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
not the wiring!
good luck with the swap
NYC: WRX swapped Impreza for sale $$$$ Flat4TW Private Vehicle 'For Sale' Classifieds 51 07-15-2009 09:56 PM
WRX swap tuned for NA??? FuJi K Normally Aspirated Powertrain 12 12-02-2008 12:30 PM
Place in NorCal to get WRX swap? blaznc Bay Area Impreza Club Forum -- BAIC 2 07-06-2006 02:13 AM
guaging interest: complete 02' wrx swap prewired for 01rs akcel Private 'For Sale' Classifieds 21 01-16-2006 06:28 PM
WRX Swapped RS for sale crazzy_azz_white_boy Private Vehicle 'For Sale' Classifieds 85 12-01-2005 09:42 PM
