05-19-2005, 09:47 AM | #1 |
Member#: 38280
RMIC
Vehicle:2000 2.5RS w/ EJ205 tuned @ teh Ghetto Garage |
My signals make my headlights flicker!
Hey all -
I've got a 2000 RS and a few weeks ago I noticed a small annoyance that my headlights would flicker (similar to if I flashed my high-beams, except they flickered off and not brighter) for an instant about 40% of the time I would use a turn signal. As time went on, it started becoming more prominent so I checked under the dash because I installed a GTechPro RR over Christmas and I wiretapped the unit into the switced +12V line by the foglight switch (like was done in this Ravensblade mod). There were no bare wires shorting together, and I suspect that if my GTech was loading down the lighting circuit I would have seen this problem more recently after the install. Any ideas? I'm really scratching my head here. Last night my headlights turned completely off when I put on my left signal!!! Could my battery be losing ability to source the necessary charge? I don't remember the current draw of the GTechPro, I'll snag it when I get home. The battery is an OEM replacement and it's 2 years old. Thanks in advance guys!
05-20-2005, 12:47 AM | #2 |
Member#: 38280
RMIC
Bump...The GTech draws about 200mA peak.
05-20-2005, 03:30 AM | #3 |
Member#: 81042
Vehicle:2000 5 door turbo Silver |
I would check the wiring feeding the turn signal switch. There may be a break which only shows when the switch is moved.
The connection that you made may have severed the wires. Othetr than that, it's a case of following the circuit with a tester and a pin. John |
05-20-2005, 03:33 AM | #4 |
Member#: 78147
Vehicle:93 impreza 4dr 280.000 and runs 100+ |
Might not hurt to check your grounds also.
05-20-2005, 08:29 PM | #5 |
Member#: 54942
South East
Vehicle:2004 WRX |
Not sure if the wire you tapped on to is involved or not, but if you used the crimp-on blade style tap, they can be problematical. They're convenient, but depending on the wire/tap sizing match-up, they can create problems in a number of ways.
05-20-2005, 11:22 PM | #6 |
Member#: 82440
Vehicle:99 2.5rs... RIP 00 2.5rs |
That sucks, mine does that all the time, when it happens i turn high beams on and off and then it is fine for a while
05-21-2005, 01:10 AM | #7 |
Member#: 78147
Could also be a bad relay although I believe they are individual per each side.
05-21-2005, 02:21 AM | #8 | |
Member#: 38280
RMIC
Thanks for all the tips guys...keep 'em comin' and I'll keep you posted as I try things. |
05-21-2005, 02:55 PM | #9 |
Member#: 14489
Vehicle:2007 Audi A3 VR6 Quattro |
I had a similar problem on my 02 RS, sometimes the headlights would flick off momentarily when using the signals. At the time I had the DRLs unplugged at the resistor under the hood, but not under the dash. So I unplugged the DRL controller under the dash and the problem went away. Maybe give that a shot?
05-22-2005, 10:54 PM | #10 |
Member#: 82440
My car is bone stock.
05-23-2005, 12:23 AM | #11 |
Member#: 78147
Just another quick observation, since the dimmer switch is integrated could it be possible that its the culprit?
headlight flicker when turn signal used | STIckySTIfee | Electrical & Lighting | 13 | 07-10-2010 02:04 PM |
Headlights flickering when using turn signals | Honest Bob | Electrical & Lighting | 0 | 04-05-2009 08:10 PM |
Spiider Controller install makes my gauges flicker | Jpizzzle | Electrical & Lighting | 3 | 11-28-2007 08:27 PM |
Headlights flicker when turn signal is applied | Aspenbullet | Electrical & Lighting | 6 | 07-16-2007 03:46 AM |
headlights flicker with left turn signal | EPskate | Electrical & Lighting | 1 | 03-26-2007 09:42 PM |
