Old 05-19-2005, 03:41 PM   #1
PhoKingWRX
Member#: 30861
2002 Silver
Perrin Parts Slut
Default Question: brake light on, clock light out, daytime running light out
so i had a unichip installed awhile back. i took it out with no problem. however the end result was having the following go out or left on:
-brake light in cluster dash is constantly on even when e-brake is down all the way
-day time running lights is off (i kinda like this)
-clock light is out
i tried checking all the fuses but nothing is blown. maybe im looking in the wrong place? are all three electrical issues related to just one fuse or plug? any help/ suggestions would be greatly appreciated. thanks in advance.
PhoKingWRX is offline   Reply With Quote
Old 05-22-2005, 12:52 AM   #2
PhoKingWRX
Member#: 30861
2002 Silver
Perrin Parts Slut
can anyone reccommend anything?
Old 05-22-2005, 07:29 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The brake light on is low brake fluid, probably from worn pads. The DRLs not working are a result of this because the DRL module sees the contact closure from the level sensor and thinks the e-brake is on. Look at your pads and replace them if worn, the fluid level should then come back up to normal. Don't just add fluid or it will overflow later when the pads are changed.
The clock light is unrelated, most likely in the clock itself if all other lights are working.
Turning off daytime running lights on 04 WRX? MF-DIF Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 08-16-2009 01:31 AM
daytime running lights on 05 sti- turn off? sbend Electrical & Lighting 11 10-24-2007 11:44 PM
Disabling Daytime Running Lights (DRL) on WRX 03 kovalov Newbies & FAQs 11 12-27-2002 08:58 AM
('93-'01) How to remove daytime running lights on 2002 Imprezas Dr. Spud Funk Impreza Forum 9 05-08-2001 05:43 PM
Disabling Daytime Running Lights on a 2000 Legacy GT? rao Legacy Forum 16 05-04-2001 12:35 AM
