05-19-2005, 07:54 PM | #1 |
Member#: 20107
Vehicle:2004 STi WRB |
what grommet to put boost gauge line through?
I know most people put it through the one behind the intercooler, but i really don't feel like having to take it off as I hear its a pain to put back on. I have my stereo going through the grommet above the clutch. Do you think its ok to put the line through there if i will be placeing the gauge by the bottom of the a-pillar? Or should i just bite the bullet and take of the damn intercooler...
05-19-2005, 08:54 PM | #2 |
Member#: 49895
NESIC
Vehicle: 09 Forester 06 Legacy 2.5i Wagon |
It's not that bad. You do not need to remove the intercooler to get to this plug. Just remove the plug and put a hole in it with a hole punch or sharp x-acto knife. Do not split the grommet as some people do, just put a hole in it. This will make it much easier to re-install.
05-19-2005, 10:02 PM | #3 |
Member#: 76147
well, what kind of boost gauge are you installing...manual or electric?
i wouldn't share a grommet if you're running a manual gauge, you don't want to open up that grommet too much, could be a pain to seal. but if it's an electric, running the meter wire should be cool with the power cables. taking off the intercooler is cake anyway. it should take you no more than 5 minutes to remove and install, maybe 10 if you have a strut bar in the way. |
05-19-2005, 10:09 PM | #4 |
Member#: 20107
its a mechanical... guessing i am going to have to take off the intercooler. Everyone always complainings about getting the inlet on...
05-20-2005, 09:18 AM | #5 | |
Member#: 49895
NESIC
05-20-2005, 09:59 AM | #6 |
Member#: 57056
NESIC
Vehicle:2013 328i Douchenozzle silver |
I installed mine also without removing the intercooler. I have pics if you want pm me and I'll send them to you later today.
05-20-2005, 10:39 AM | #7 | |
Member#: 25187
Vehicle:2020 Forester 2010 Challenger R/T |
05-20-2005, 04:16 PM | #8 |
Member#: 20107
thing is you guys all have wrx's... the sti intercooler is bigger, its nearly impossible to get to the grommet and put anything into it without having midget hands and long ass fingers...
05-20-2005, 04:19 PM | #9 | |
Member#: 25187
06-06-2005, 08:40 AM | #10 | |
Member#: 46224
06-06-2005, 09:39 AM | #11 |
Member#: 83494
RMIC
Vehicle:2004 WRX Wagon Red |
Hey, I have a wrx and I was easily able to get to the grommet. I read the instructions about removing the intercooler also but was less than thrilled to do that. There is a grommet on the right of the intercooler that goes to the footwell on the drivers side, right above the acclerator pedal.
06-06-2005, 11:52 AM | #12 | |
Member#: 49895
NESIC
06-06-2005, 02:24 PM | #13 |
Member#: 59394
Vehicle:2004 Impreza WRX Silver |
When you pull the grommet to cut the hole don't forget to make one in the interior insulation.
I also did mine without removing the intercooler. A little tight, but it can be done. The worst part was putting the thing back in with boost gage line, EGT Wire, Oil Pressure Wire and Oil Temp Wire. |
06-06-2005, 02:48 PM | #14 | |
Member#: 25187
06-06-2005, 03:31 PM | #15 | |
Member#: 46224
06-06-2005, 04:22 PM | #16 | |
Member#: 20107
06-08-2005, 12:09 PM | #17 | |
Member#: 49895
NESIC
06-08-2005, 12:12 PM | #18 |
Member#: 20107
You guys must have really long skinny midget fingers! I will look again during my lunch break...
Vaccum line to oem boost gauge | kooklie | Newbies & FAQs | 18 | 07-30-2009 03:38 PM |
Where to Run Meth Injection line through firewall? | scutzi128 | Water/Methanol Injection, Nitrous & Intercooler Cooling | 2 | 05-01-2008 09:03 PM |
what is the factory boost gauge for STI suppose to be at | hilfiger4you | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 08-18-2005 07:34 AM |
safe to put our AWD cars through car wash? | PinnacleChronos | Newbies & FAQs | 57 | 02-26-2005 10:56 PM |
Autometer Boost Gauge Line is Tacky White... | SJwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-24-2003 12:57 AM |
