Old 05-19-2005, 10:41 PM   #1
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
Default NY OBD2 inspection outcome: FAILED (JDM swap)
my car failed today during a OBD2 inspection in NY because it could not read the JDM ecu.
technically im an ******* because the only reason i tested it now was for you ****ers so u guys can be informed(my inspection isnt due till 10-20-05)
so heres what happened:
took car in, passed visual because everything is hooked up correctly, i have no CELs and i have my stock exhaust(up to catback)
when the OBD test started it said turn key on then it read the ECU, then it said start motor, started the motor and it went to read to see if teh CEL went off, it wassnt able to detect that the carw as even running, so it said "car is not running please start car" but itw as, so then it failed my car...
heres some info from NYS about the inspections and how to get "waived"
http://www.nydmv.state.ny.us/vehsafe.htm
YaZahX is offline   Reply With Quote
Old 05-19-2005, 10:55 PM   #2
cronic
Member#: 9749
So you went and did this after i already posted that? And we are te ****ers?
Are you using the JDM harness?
cronic is offline   Reply With Quote
Old 05-19-2005, 11:07 PM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
where u post??
ya its the full harness and all
Old 05-19-2005, 11:25 PM   #4
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
Yaz-
Request a 'Custom' Registration and it will exempt you. The forms are easy to fill out as the web address you provided demonstrates. We'll see what happens - mine is in progress.
OR, you can pay your mechanic $450.00 or get some receipts together. Max out of pocket to pass NYVIP is $450.00 annually. It is another, although expensive, option.
Joncas2 is offline   Reply With Quote
Old 05-19-2005, 11:26 PM   #5
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Ill take your drivetrain
benjaminetanyahoo is offline   Reply With Quote
Old 05-19-2005, 11:44 PM   #6
cronic
Member#: 9749
where u post??
I posted in this forum.. I coud not pass with mine either(02 JDM wrx) I went to 2 different shops thinking it could have been the first shops machine.. I had the same comunication error.. It really pisses me off becasue the OBD2 works fine, test mode works fine, etc.. I am in AZ now so we will see what happens out here.. I know for a FACT that jdm sti ecu has passed inspection out here in an 02wrx, i am just wondering if it has something to do with the harness, not the ecu, i know there is not much different, but who knows it could be a matter of a wire..
Old 05-19-2005, 11:48 PM   #7
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
true..
funny thing is that yesterday i checked my ECU for codes with the subaru select monitor and it was clean, so i was like ok if i want, i can inspect... should i try a different shop or call dmv ask what should be done?
Old 05-19-2005, 11:50 PM   #8
cronic
Member#: 9749
true..
I don't think it has to do with the shop, but you can try.. I ended up getting my sticker though so i am good for a year.. It sucks that Ny is making it this way, my car is cleaner burning then most of these jalopies on the road.. I wanna see how it goes out here, but like you i am nervous to even get the inspection done now, when i have a year left on my current Ny.
Also like you i checked with both a subaru select, and a cheapo monitor and both worked fine, not to mention i was ecutek reflashed through the port, so i went in with all the confidence in the world..
The worst part is the printout they give doesn't tell you ****.. "comunication bla bla" that is great
Swappers, who has passed OBD2 inspection.. cronic Subaru Conversions 78 12-18-2008 02:23 AM
Need help: NY state inspection failed ttatsumi Legacy Forum 21 09-14-2008 01:02 AM
Need help: NY state inspection Failed. ttatsumi Tri-State Area Forum 24 08-16-2008 08:34 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 07:10 PM
