05-19-2005, 11:43 PM | #1 |
Member#: 80182
Canadian STi Gauge Cluster
I have a 2002 WRX and I ordered a STi cluster from a dealer. I got it and it reads kilometers with mph small on the inside. So I install it thinkng it will just go in like it should. NOPE!!!! The connector on the left side of the cluster has more more pins than it should
Also as soon as I turn on the ignition it starts this high pitched buzzing like the door chime but constant. It popped the fuse for the radio and the abs and rear diff temp lights are on. I know I dont have a rear diff temp. HELP ME PLEASE!!!!!!!!!!
05-20-2005, 11:00 PM | #2 |
Member#: 69370
E. Canada
Vehicle:2007 Legacy GT DGM |
I think the problem is not the canadian cluster, it is 05 model sti cluster
It sounds like your problem is that you are running a 2005 cluster in a 02-04 model car. From what I understand this will lead to the buzzer being constantly on and some lights not turning off. The fix to the buzzer problem is to remove it (I don't know how, I have never done it, I remember reading about it several times before though). The radio fuse blowing is something that will happen if you install an 04 or 05 sti cluster in a 02-05 non-sti model car. The fix for this problem is to cut one wire on the harness (again, I don't know which wire, I read about this a long time ago when considering buying a used 2005 sti cluster). I hope that this has been at least somewhat helpful to you.
05-20-2005, 11:13 PM | #3 |
Member#: 80182
Do you remember where you read it?? This is a problem with all 05 STi clusters?
05-23-2005, 01:44 AM | #4 |
Member#: 76729
Vehicle:2004 WRB WRX 2.7L S400SX3, PPG, AEM, 701whp |
Hey brother, I am with you on this one, just put my 05 cluster in and got the buzz and lights.. I have spent all day chasing diagrams and nothing yet... I know we are not the only ones with this issue.. others please chime in if you heard of this and remember what is the fix or where we can find it.
05-23-2005, 08:43 AM | #5 |
Member#: 80182
since you have an 04 you should just try to get a 04 cluster. did you buy it used or new?
05-23-2005, 07:10 PM | #6 |
Member#: 76729
I bought it new and they sent me an 05... that is why it is not plug and play. I am sending it back and they are sending the 04 usdm instead of the 05 can.
I also had them send me the wiring diagram for te 05 sti so i can trace the differences. |
05-24-2005, 08:33 AM | #7 |
Member#: 80182
did you get yours from Jamie (SubaruGenuineParts)? She is who I got mine from and she said I wasnt the only one that the wrong part.
05-25-2005, 12:04 AM | #8 |
Member#: 76729
Yeap!! I ordered it from her and i sent it back now i am waited for the right one t get here.. she mentioned you to me as well.
05-25-2005, 12:35 AM | #9 |
Member#: 80182
what was your first thought when you plugged it in and turned the car on?
05-26-2005, 08:04 PM | #10 |
Member#: 37375
NESIC
Vehicle:2002 WRX Silver |
Hey guys try looking at subbymods.com had a similar question on how to install an 04-05 cluster in my 02 WRX
05-26-2005, 08:07 PM | #11 |
Member#: 37375
NESIC
doh , but subbymods tells you what wire to snip and step by step processes on almost every mod i even have the guys email who posted the thread for further questions , anyway this is my bro. name im Ej2002StIwRx if anyone wants the address or if you need the instructions this guy is supposed to be sending me a step by step.
05-27-2005, 01:43 PM | #12 |
Member#: 80182
05 cluster IS NOT plug-n-play, only 04. the write up on scoobymods is for a 04 cluster.
05-28-2005, 04:28 AM | #13 |
Member#: 80182
I got my 04 replacment cluster today, I cut the B28 wire and it works perfect
05-28-2005, 10:15 AM | #14 | |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
we used the wrong part number - as became apparent when you guys received your clusters. I couldnt get straight answers from Subaru regarding which part was which (they just didnt know or understand what we were trying to do here....) so i snagged the vin off of an 04 to sort out the correct part ## (yes i know, why didnt i do that in the first place... coz i didnt know there was an 'issue') i'm just really sorry guys that this took an extra 4-5 days to sort out but very glad that we've GOT IT SORTED shout with questions Jamie www.subiegal.com |
05-28-2005, 02:03 PM | #15 |
Member#: 80182
Jamie, if anyone asks you about putting it in, tell them they need to cut wire B28 (B is the middle connector and on the back of it underneath each wire is a very small number) The B28 wire is yellow with a bright green stripe on it, cut it and tape it. That wire is also used for the outside temp sensor install. If anyone asks about hooking that up, there is a write up HERE on how to do it
05-28-2005, 07:01 PM | #16 |
Member#: 18058
Does the '04 cluster perform the sweep around like the JDM cluster at startup??
Also, where do i buy the temp sensor or do i use the one from my car? |
05-30-2005, 02:06 PM | #17 |
Member#: 80182
The 04 does sweep when you turn on the car. You can get the temp sensor from a local Scooby dealer, I dont know if your stock one would work.
FS WA: 04 Sti Gauge Cluster and 05 Sti cluster | wrxwagon253 | Interior/Dressup/Audio & Security | 17 | 12-12-2008 01:12 AM |
WTT: 05 STI gauge cluster for 04 WRX cluster | nixgame22 | Interior/Dressup/Audio & Security | 28 | 08-15-2007 03:49 AM |
WTT: 05 STI gauge cluster, for 04 STI cluster | Ctracer911 | Interior/Dressup/Audio & Security | 0 | 06-26-2007 01:26 AM |
WTT 05 STI gauge cluster for 04 cluster | ThAReDReX | Tri-State Area Private Classifieds | 13 | 11-29-2006 09:37 PM |
WTT '04 STI gauge cluster for '04 WRX gauge cluster + $$ | Lexington | MWSOC Private Classifieds | 29 | 08-03-2006 11:27 AM |
