Old 05-20-2005, 10:21 AM   #1
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Question Car stalling at idle...
Every now and then when I have the A/C on and the compressor kicks on, the car will stumble and die if I don't blip the throttle. When I do blip it, the RPMs will go up to 2000-2500 or so, stay there for a couple seconds and eventually drop back down.
Also, the engine seems to be losing a ton of power when the A/C is on. At a constant throttle position during acceleration, there is a very noticeable decrease in performance. I checked the belts and they don't feel like they are too tight but I probably don't know what it should be like. Any ideas?
-Brett
ExecNav is offline   Reply With Quote
Old 05-20-2005, 10:42 AM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
lol u always should tell what EM ur using ???
Old 05-20-2005, 10:53 AM   #3
Aphex28
Member#: 11506
2015 WRX
Yah.. it definately sounds like your EM isn't tuned for the AC yet
Aphex28 is offline   Reply With Quote
Old 05-20-2005, 02:55 PM   #4
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
E-Manage, WRX fuel pump, 440cc injectors, 7psi, etc...
Okay so what's involved with tuning for A/c...
-Brett
Old 05-20-2005, 03:05 PM   #5
Aphex28
Member#: 11506
2015 WRX
just turn the ac on.. and start tuning
I saw soembody do this with a Hydra.. but don't ask me any specifics.
Old 05-20-2005, 08:46 PM   #6
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
I have the same issue with my setup and emanage. Hydra I know has a setting to increase fuel when A/C is on. However, with an Emanage setup either you tune with A/C on and therefore run rather rich when A/C is off (which can cause the engine to die when A/C is off) or you have a laptop and mutliple maps and switch when A/C is on/off. There certainly are advantages to a full aftermarket EM setup.
ai42 is offline   Reply With Quote
Old 05-21-2005, 02:34 AM   #7
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
when the AC steps on, the idle should increase slightly. You can expand the maps around those load sites to work the cinks out.
Also, I would try adding a little timing at idle or even in a load site lower than idle. I have additional timing added at idle and below such that if the car starts to stall, it will make a little more power and kick itself back up. This technique is widly used on cars with light flywheels to prevent them from stalling as the revs come down.
you don't have any more control out of a full standalone unless it has specific control maps for AC. Usually its just a step up of idle speed.
Todd
Hitokiri is offline   Reply With Quote
Car Stalling at Idle after minor Mods MaLT Newbies & FAQs 21 01-10-2012 03:58 PM
new battery, now car stalls at idle 04works UTEC 7 02-16-2007 05:48 PM
Car stalling at idle joeyd02 Newbies & FAQs 3 10-16-2006 11:23 PM
--> <-- this close to stalling at idle. RaceCarRiot Normally Aspirated Powertrain 4 01-29-2002 07:39 PM
Stalled at idle... RallyImprezive Normally Aspirated Powertrain 3 04-10-2001 01:30 PM
