Old 05-20-2005, 05:32 PM   #1
rhd
Member#: 81820
2003 WRX sedan
Sedona
Default My fans won't turn off?
ok, i just started driving my WRX again.....it's been sitting for over a month. I figured i might as well drive it some...since it's sitting here....but i'm rambling...
anyways, i get in the car yesterday and drive. no biggie, nothing special. I turn the car off, go inside, come back out and get int he car. i put the key in and turn it to "on"...but i didn't crank it. my fans came on. I didn't really think anything about it...since i had just driven it. Well, i come out this morning to install a tv (i had one laying around....my g/f likes it..so, i was kinda FORCED into it) And i turn the car back to "on" to make sure everything is cool with the wiring..and the fans pop on. I'm thinking....w.t.f? Well, i popped the hood and BOTH are on...and going full steam. The car has been sitting overnight, so it's completely cooled down.
Both fans continually go...with the car running and the car int hte "on" position...so...what's up?
the only issure with my car, right now, is the CEL is on from the lack of a VSS. it was broken when i pulled the tranny out (the top popped off..no biggie, gonna fix it here in a min) But other than that....nothing has changed, and it used to not do that.
anyone have any ideas????????????????????????????????????????????? ????
rhd is offline   Reply With Quote
Old 05-20-2005, 07:44 PM   #2
bajabob
Member#: 73236
2003 Baja
Baja Yellow
I belive in some cars if the air cond. is turned on at least one fan will run constantly - you might want to check that.
Bob
bajabob is offline   Reply With Quote
Old 05-20-2005, 08:20 PM   #3
WRXRgr
Member#: 54942
2004 WRX
Did you need a jump, to get it started?
The battery might have dropped voltage enough to let some of the ECU ram get corrupted...if you can get the battery charged (by driving, or charger), try resetting the ECU.
Edit: What's the VSS?
WRXRgr is offline   Reply With Quote
Old 05-20-2005, 11:00 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....green diagnostic plugs under the dash.....UN-plug them for normal operation
Old 05-21-2005, 04:20 AM   #5
rhd
Member#: 81820
2003 WRX sedan
Sedona
the green plug isn't plugged up
the battery never died, optima red top
and the ecu has been reset
the VSS = vehicle speed sensor
Old 05-21-2005, 06:41 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
....is the HVAC set to defrost/defog???? If so, the AC compressor is engaged...and causing the fans to run.
Old 05-21-2005, 12:08 PM   #7
rhd
Member#: 81820
2003 WRX sedan
Sedona
no, its been set there before.....but, it is presently in feet/head mix.....and it's not on, and the a/c button is not depressed
Old 05-21-2005, 12:57 PM   #8
WRXRgr
Member#: 54942
2004 WRX
Might just be a stuck fan relay.
Old 05-21-2005, 01:48 PM   #9
rhd
Member#: 81820
2003 WRX sedan
Sedona
pulled all relays and moved/replaced them, TWICE
Old 05-21-2005, 01:49 PM   #10
rhd
Member#: 81820
2003 WRX sedan
Sedona
and both fans are going...not just 1. they each have a seperate fuse, and like...3 relays each
Old 05-21-2005, 02:55 PM   #11
mikaust
Member#: 7468
2013 Focus ST
You are in a limp mode. Check and see if your car like crap around 4 to 4500.
Your speedo gear or sensor is causing this.
mikaust is offline   Reply With Quote
Old 05-21-2005, 03:19 PM   #12
rhd
Member#: 81820
2003 WRX sedan
Sedona
i know............and its' 5k
but that's not my fan problems...
Old 05-21-2005, 03:33 PM   #13
mikaust
Member#: 7468
2013 Focus ST
I had a broken speedo gear and my avcs ( JDM swap) did not work, my fans ran all the time, and I had to pass into the UTEC to get past 4500.
Old 05-21-2005, 03:40 PM   #14
rhd
Member#: 81820
2003 WRX sedan
Sedona
oh really?
you should have mentioned the fan thing first :P
well, i'll go take it off and see if i can't fix it then
i don't really wanna spend $90 on a new one right now, if i can fix the old one for free
Old 05-21-2005, 03:48 PM   #15
mikaust
Member#: 7468
2013 Focus ST
Check and see if it is the sensor. Make sure the screwdriver type end is properly positioned in the tranny. If that is not the case try and find someone with a sensor and change it out. If your gear is blown you have to drop the tranny and go inside.
Old 05-21-2005, 03:59 PM   #16
rhd
Member#: 81820
2003 WRX sedan
Sedona
no, the sensor actualy broke in 2.
there was only a small piece of plastic that holds the pieces together...adn below that an o-ring and the contacting surfaces.
it was hit during tranny removal
Old 05-22-2005, 03:51 AM   #17
rhd
Member#: 81820
2003 WRX sedan
Sedona
super glue is my new lover! VSS is fixed, along with that...the fans now work properly!
thanks for the help!
sucks though, my greddy boost gauge took a **** on me right after i got everything else fixed
Old 05-23-2005, 09:08 AM   #18
WRXRgr
Member#: 54942
2004 WRX
Originally Posted by rhd
super glue is my new lover! (
Errr...dunno if I'd go that far I'd wonder about "separation anxiety".
Glad to hear that was your fix!!
Old 05-23-2005, 08:58 PM   #19
rhd
Member#: 81820
2003 WRX sedan
Sedona
it's holding fine, actually. i was just bored and had some superglue sitting beside me...figured, why the F not?
Old 05-24-2005, 12:40 AM   #20
WRXRgr
Member#: 54942
2004 WRX
Heck yeah...good work! (I was referring to the "new lover" comment)
radiator fans won't turn off Arek Normally Aspirated Powertrain 20 10-27-2015 06:05 PM
My lights won't turn off after I turn the car off. need HELP sillyme Newbies & FAQs 8 12-18-2008 08:41 PM
My rad fan won't turn off shinjyo Normally Aspirated Powertrain 13 06-25-2007 01:11 AM
Fans won't turn off. Please help! ImprezaWRX02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-13-2006 11:38 AM
My lights won't turn off Stinsanity STi Forum Archive 13 08-24-2003 04:32 AM
