Old 05-20-2005, 09:42 PM   #1
BenBortner
Member#: 50017
2010 Genesis Coupe
Default Time to jump in to the engine swap I guess... What to look for when purchasing
abcde
BenBortner is offline   Reply With Quote
Old 05-20-2005, 09:52 PM   #2
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Um first I would see if it has any warrenty, second I would check the compression if its possible, third I would inspect every inch of the wiring harness, and finally I would check the timing on the engine. If the wreck damaged the head it may have done more than that like knock off the timing belt or worse cracked the block. You never know man I would just go over every inch of it before commiting!
DuoMaxwell is offline   Reply With Quote
Old 05-20-2005, 10:05 PM   #3
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 05-20-2005, 10:23 PM   #4
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Ahhh... good ole Foster's auto parts.... or somewhere else? If it's Foster Auto, they are reputable and trustworthy, IMO. Any visible cracks (obviously) and pull the dipstick to check the color of the oil. If it looks like cafe' latte, or anything other than normal, it is contaminated with water or coolant.
Kreeger is offline   Reply With Quote
Old 05-21-2005, 01:16 AM   #5
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 05-21-2005, 09:12 AM   #6
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
The motor situation is a little concerning but overall thatís a good price. Especially considering you get to pull the old harness (which sucks) but will definitely ensure you get all the right portions youíll need if undamaged. Make sure you pull the bulkhead harness with the p-side and behind the IC engine bay cords. And ensure you get the SMJ (both sides) including the entire front wiring harness which runs down the drivers side. Also pull the fuel pump cord although itís not mandatory.
Good luck
xcntrk75 is offline   Reply With Quote
Old 05-21-2005, 04:06 PM   #7
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 05-21-2005, 07:28 PM   #8
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Make sure that's not for an STi motor.... That is insulting!
Old 05-21-2005, 07:47 PM   #9
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 05-22-2005, 05:55 PM   #10
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I paid $600 for mine
jamesfacts is offline   Reply With Quote
Looking to buy in bulk and sell various things - But what to buy? sedagive Off-Topic 31 12-29-2009 08:58 AM
What I look for when buying a used 1999 impreza? Chris99 Newbies & FAQs 1 03-16-2009 09:42 AM
What to look for when purchasing a used turbo? generalee69 Newbies & FAQs 11 10-12-2008 10:56 PM
Things I should look for when purchasing? BAM6I4 Newbies & FAQs 4 12-10-2005 08:44 AM
What to look for when purchasing a used road bike? Fach Off-Topic 5 08-15-2005 09:07 PM
