Old 05-20-2005, 10:06 PM   #1
BenBortner
Member#: 50017
2010 Genesis Coupe
Default ej20 swap, which tranny?
abcde
BenBortner is offline   Reply With Quote
Old 05-21-2005, 01:52 AM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
hmm.. i'm not sure about the L gearing.. but the wrx is pretty tall. If you can find a rs tranny.. that would suit much better. IMO
subbyspeed is offline   Reply With Quote
Old 05-21-2005, 02:29 AM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
That's what I've heard/read. The rs gears aren't any weaker than the WRX so might as well go with something a little more useable.
TyranosaurusWRX is offline   Reply With Quote
Old 05-21-2005, 04:12 PM   #4
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 05-21-2005, 04:32 PM   #5
MeshmeZ
Member#: 58908
'07 STI
you are going to need a new clutch either way. i wouldnt run a stock L clutch with a wrx motor. so its just a matter of which clutch you end up buying (upgraded L clutch or wrx clutch). and as far as flywheel, wouldnt it be a good time for a lightweight flywheel anyway ;-) i dont know about the gearing on the L but if its anything like the RS i would stick with it. im planning on keeping my rs tranny with my wrx swap. the wrx tranny has tall gears, so unless your goal is top speed runs, the rs tranny will keep you faster in the turns.
MeshmeZ is offline   Reply With Quote
Old 05-21-2005, 04:38 PM   #6
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
AMEN to that!
Old 05-21-2005, 04:41 PM   #7
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 05-21-2005, 05:22 PM   #8
MeshmeZ
Member#: 58908
'07 STI
the final on the RS is 4.111 (on the 02-03 at least.) im assuming you mean you have an UPGRADE NA exedy clutch, because i dont think the stock replacement will like the wrx motor. i say use the L tranny for now (unless the L tranny is prone to breaking) and then later you can do the jdm or whatever if you feel you need a different ratio.
Old 05-21-2005, 07:43 PM   #9
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 05-21-2005, 09:33 PM   #10
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
my 01 has a 4.11 rear end also.. i believe the 00 does too.
Old 05-22-2005, 04:01 AM   #11
MeshmeZ
Member#: 58908
'07 STI
Originally Posted by BenBortner
Also, my L tranny has 95k miles soo... Its getting a bit old. Yes, an upgraded exedy. I think I probably will do the L tranny
just treat it right and it will treat you right.
Old 05-22-2005, 11:43 PM   #12
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
I used Legacy GT Gears and diffs (Front and Rear) in a WRX case. I wanted the gearing of the legacy with the strength of the pull style clutch. Gears, Front and Rear diff were from a late 1998 Legacy GT, WRX Case was from a 2002, and the transfer case and center diff were from a 1991 Turbo Legacy.
wrx_driver_2002 is offline   Reply With Quote
Old 05-23-2005, 12:57 AM   #13
MeshmeZ
Member#: 58908
'07 STI
im not positive on this, but cant you just change the clutch release mechanism from push to pull? i was under the impression that the tranny housing between the wrx and rs were the same, so i figured you could just switch over the release mechanism.. anyone have a answer on this?
Old 05-23-2005, 01:52 AM   #14
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I wouldn't trust the L trans with power.... IMO I don't know though just me? i have a 94 L with EJ20G swap and with the jdm drivetrain... I really like it and over all feels better than the L but your car is newier soo I donno? if you go RS or wrx you'll have to change over to hydrolic or figuar out a way to keep it cable i konw its possible.
scobaru is offline   Reply With Quote
Old 05-23-2005, 10:21 AM   #15
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
The bell housings are different. When I get into the shop today, I'll take some pictures. Instead of having a ball that the clutch fork pivots on (the push style transmissions pivot on a ball) the pull style transmissions pivot on a pin (about 3/4 to 1" in diameter and about 6 inches long) that runs through the fork... The fork design is completely different also. It's not just a matter of swapping forks.
-Mike
Old 05-23-2005, 10:36 AM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ill throw in
your tranny will be fine
i have 175k miles on my L tranny (w/ ej20G)
the usdm wrx transmission is not well matched to the ej20 .. at all it too high
pulling the engine reallly isn't that tough after the first time
i say go with the tranny/starter/flywheel/clutch/cable you have deal with the wiring of the swap then if needed do the tranny later
Old 05-23-2005, 06:00 PM   #17
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
04 RS with upcoming EJ20 swap. Tranny question. feelthebreak Transmission (AT/MT) & Driveline 1 03-13-2008 02:15 AM
Tranny swap- which crossmember? xcntrk75 Transmission (AT/MT) & Driveline 3 12-15-2004 02:23 PM
Which tranny would work best for my swap? Cajual Subaru Conversions 6 11-29-2004 11:02 PM
Keep RS tranny with ej20 swap? taeyax82 Subaru Conversions 11 10-15-2004 02:04 PM
which ecu for ej20 swap? iwannaej20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-12-2002 08:50 PM
