Old 06-17-2005, 07:05 PM   #251
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
west_minist is offline   Reply With Quote
Old 06-17-2005, 10:44 PM   #252
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Got everything running. Awesome program!!! Here is a screen-cap in use.
crystalhelix is offline   Reply With Quote
Old 06-17-2005, 10:48 PM   #253
west_minist
Member#: 53451
w/ AVCS Silver
I think you will need to send you ecu file to Tari. I do not see your coolant temp.
Old 06-17-2005, 11:14 PM   #254
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
How do I do that? I have an 04 STi.
Old 06-17-2005, 11:53 PM   #255
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
when you first start the Tari software it should pop up a window saying that your ecu isn't in the database and if you want to send the info to him. i fyou select yes, it would create a txt file that you email him with a pic of the ecu.
Quack is offline   Reply With Quote
Old 06-18-2005, 09:13 AM   #256
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
So I send him the ecuassist.txt file and a picture of my ECU? That shouldn't be a problem.
Justin
Old 06-18-2005, 10:19 AM   #257
Quack
Member#: 57264
^^^ correct. the picture should be of the top case #'s so he knows which ecu you have
Old 06-19-2005, 12:49 PM   #258
JRSCCivic98
Member#: 67080
Hey guys, got a chance to try out this prog yesterday on a friend's car with his AP cable and while the program is nice for what it does it is missing a key item that's very important. How about the ability to read the IAM on the ecus. Without that it's pretty much useless when it comes to seeing where you are with timing maps. Everything else looks good though. It just badly needs this component on the next release ASAP.
JRSCCivic98 is offline   Reply With Quote
Old 06-19-2005, 01:28 PM   #259
Jon [in CT]
Member#: 2992
02 WRX Sedan
Even the current Subaru Select Monitor doesn't report that.
Jon [in CT] is offline   Reply With Quote
Old 06-19-2005, 08:02 PM   #260
JRSCCivic98
Member#: 67080
Well, DeltaDash does it all day long and so does the in dash display they have, so it's obviously cannot be that hard to read the info off the ecu. Besides, the Subaru Select Monitor is a tool used to diagnose problems... knowing what your IAM is at doesn't exactly need to be known especially when working with OEM flashes which should be stable for Premium fuels. (Basically, a Subaru tech doesn't need to know the IAM.) In the aftermarket field though, it's an invaluable piece of the overall info one needs to determine efficient/stable tuning. After all, why tune your timing to the edge when your IAM is at 8 if you know the ecu will try from time to time to advance it higher to see if it will det or not. You're just opening up the door for minor det which is not nessacery if an ecu is tuned properly. So, if we could check the IAM and you see it sitting on 16 the majority of the time or all the time, then you're pretty much assured that you've got a tune that's not det prone. So, with that said, you can see how invaluable this one value is.
Old 06-19-2005, 08:21 PM   #261
Jon [in CT]
Member#: 2992
02 WRX Sedan
I guess my point is that harranguing about a so-called deficiency of a free tool which reports the same info as the the $x,xxx factory tool is counterproductive.
Old 06-20-2005, 02:26 AM   #262
calvinc
Member#: 73190
2005 Impreza WRX STi
sorry for the delay...took a long weekend...
Calvin, the DeltaDash I'm running supports logging of 20ms/sample on the fastest selection. Believe that is per data item selected. I'm getting basically the same data rate with DL1 that I see with DeltaDash.
it says so but i've yet to see an actual capture rate of 20ms, even with 1 parameter selected.
So I bought I cable and tried it, and just found out the program didn't work for anything below MY99 Is there any way around this?
i have some protocol information for the 97/98 ecu but i havent got round to writing anything for it yet, so i dont know how valid it is.
for gasoline:
lambda * 14.7 = AFR
thats the calculation formula i had and the values i got werent matching. i'll take another look...
Thats interesting. I've not observed any fragmentation. My code has no logic to deal with that. Longest I've run it is about 30-40 minutes in one session.
its not the ecu, rather maybe my implemenation of the comms. maybe the MS comm OCX in VB6, yours is a .NET app. v2 is all C++ and much more intelligent so there wont be this problem in that version.
tell me the address in the ecu and you can have it in 5mins...
mail me and we'll get the address
dash display is made by PSI3, it also reads the IAM on 99/00 vehicles. i dont have access to a 04 USDM STi, so i cant get this ecu address, i'm relying on you guys here...
there seems to be some BIG confusion as to what the ecuassist is for. it is only there so that i could build up a database of what ecu's were out there and what parameters they supported. it is also there so that i can code for a nice ascii string and tell you in english what your ecu type is. few problems with the ecuassist stuff:
1) a few of you are running 1 type of ecu with a certain ecu cover and id but completely different firmware software, which means they will never match.
2) its a rather annoying little message box each time you use the app.
I've removed the ecuassist stuff from v1.0.40 - please note that this WILL NOT affect the functionality of the application
On startup the ecu responds with a bit mapping of what parameters are supported. this is done and the data item list is generated regardless of whether it understands your ecu id or not.
v1.0.40 will be available in the next few days...
Calvin.
calvinc is offline   Reply With Quote
Old 06-20-2005, 08:50 AM   #263
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I will be taking of photo of the my 2004 USDM STi computer tonight. Sorry but I can't offer it up for examination as I use my car often. Is there anyway I can retrieve the data you need from a 04 STi? I will post the picture and ECUassist file tonight.
Thanks,
Justin
PS - I pluged this in to a Saab 9-2X (saabaru) this weekend and it worked. I can get a picture of his ECU and txt file as well.
Old 06-20-2005, 10:23 AM   #264
JRSCCivic98
Member#: 67080
Saab 9-2x ecus are identical to the Subaru ones. Or rather I should say... they are the Subaru ones used in the WRX wagons.
Old 06-20-2005, 01:07 PM   #265
sandiegowrx
Member#: 41743
It is a neat program. However my MAP pressure seems to be off. This should be the same reading as the AP or boost gauge, right?
sandiegowrx is offline   Reply With Quote
Old 06-20-2005, 01:41 PM   #266
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
The logger values shown are absolute not guage pressure. Subtract normal atmospheric pressure (~14.7 psi ) get a value that the AP or dash guage would show.
forced4 is offline   Reply With Quote
Old 06-20-2005, 02:38 PM   #267
my04sti
Member#: 61501
04 subaru sti
blue 12.68 @ 106 mph
Use the "relative pressure" to monitor boost levels.
greg
my04sti is offline   Reply With Quote
Old 06-20-2005, 04:40 PM   #268
DammitBevis
Member#: 3569
2006 STi
AW
Default Feature Suggestion
I have a humble feature suggestion that might make things easier for you.
Until all the ecu's can be auto-detected, could you add a feature to specifiy your own memory addresses like in the mmCD program for DSM's?
Even if it's just a text file that it reads in at startup. Just a simple format:
[ADDRESS] [DESCRIPTION] [D/A] [EQUATION]
Might help in the long run because we could experiment and find what works on our own.
Heck, you could put the whole table you currently have out there.
DammitBevis is offline   Reply With Quote
Old 06-20-2005, 07:48 PM   #269
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
dood this prog sucks, I wasted 15 bucks on a USB to serial cable. The damn thing won't connect
murrdogg24 is offline   Reply With Quote
Old 06-20-2005, 07:55 PM   #270
R4ND0M_AX3
Member#: 67483
2005 WRX STi
you can still use your wasted $15 cable for other things like an LM-1/LC-1/XD-1.
R4ND0M_AX3 is offline   Reply With Quote
Old 06-20-2005, 08:09 PM   #271
feiron
Member#: 62327
2005 WRB STI
[S600BY]
dood many people had this program to work with their car! You dont jerk over free stuff! its not like you paid for the program! Pay to play
feiron is offline   Reply With Quote
Old 06-20-2005, 08:38 PM   #272
Quack
Member#: 57264
what cable are you trying to use, the Cobb AP cable?
are you using the correct com port?
can you connect to any serial device through that com port?
are you computer literate?
Old 06-20-2005, 09:22 PM   #273
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
are you (computer) literate?
DougG is offline   Reply With Quote
Old 06-20-2005, 10:22 PM   #274
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
2004 STi ECU Picture and ECUassist file
Sent via PM
Hope this helps Calvin!!
Thanks,
Justin
(edited for civic guy)
Old 06-20-2005, 10:36 PM   #275
JRSCCivic98
Member#: 67080
Just a suggestion Justin, but why not email him this info instead of posting on the web for the entire world to see? Just a thought, but privacy is sometimes the best policy... I would delete your post and send this info directly to him via email. Just a thought.
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
