Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 06-22-2005, 09:25 PM   #301
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Originally Posted by calvinc
v1.0.40 is now available for download from -
in v1.0.41 i aim to include the following:
- lambda to afr conversion
- injector duty cycle as %
- proper ecu type detection
calvin.
When will this here come out? I am especially interested in the AFR since I do not have a wideband yet.
west_minist is offline   Reply With Quote
Old 06-22-2005, 10:17 PM   #302
Joelk
Member#: 7790
2009 wrx
So I just got my OpenPort (tactrix) cable today. I installed Tari DL1 and it seems to work great. I haven't gone out and done any logging yet, just turned the car on and saw it was getting data. I have a 2000 outback sport, btw. I'm going to try this on my 99 L wagon later...
Anyway, I'm looking forward to when this software will be able to read trouble codes. Need any help coding that up?
In the mean time, is there any free software out there that can read and clear trouble codes using the tactrix cable? So far all I've found is freediag (http://freediag.sourceforge.net/), and that only runs in linux. (not that there's anything wrong with linux, I just don't have it on my laptop... yet...) And the other software out there seems to only work with the elmscan cables.
Thanks for the great software.
Joelk is offline   Reply With Quote
Old 06-22-2005, 11:51 PM   #303
peterex
Member#: 27021
2015 WRX
Calvin, keep up the great work. Your program makes good logging available to the masses - not just the lucky few with UTECs or Deltadash.
peterex is offline   Reply With Quote
Old 06-22-2005, 11:54 PM   #304
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
Count me in on this bandwagon...
MK19_ is offline   Reply With Quote
Old 06-23-2005, 01:02 AM   #305
skoobywrx
Member#: 28088
05 WRB STi
06 Outback
Me:
05 STI COBB stg 1
have thrown lean codes during idle, and only at idle.
mods
snorkus delete, kn panel, catback.
highest lamda i have recorded is 1.429688 During this run, not a lean code thrown
am i dangerously lean????
skoobywrx is offline   Reply With Quote
Old 06-23-2005, 04:17 AM   #306
calvinc
Member#: 73190
2005 Impreza WRX STi
i'll try get it done asap, not too much stuff to add.
i'm still working out the addresses for the reading of trouble codes. will get there soon...
clearing them is a simple ecu reset. very easy so add that to the feature list of v1.0.41
i think this is just the start, with the initiatives of openecu.org the ability for others to do this kind of thing is getting easier so it shouldnt be long before there is a wide range to choose from across all platforms. my aim is to have a really good app that covers all the functions of the ecu from logging to flashing, and hopefuly people will keep on using it even if there is other stuff available.
doesn't lambda work the opposite? > 1 is rich but < 1 is lean. maybe thats what threw the conversions out?
calvin.
calvinc is offline   Reply With Quote
Old 06-23-2005, 04:33 AM   #307
mosqito16
Member#: 42668
2004 JBP WRX Gone W/
The Wind...09 DGM WRX 5DR
so as long as our knock correction readings are not negative...then we are not seeing knock?
is that how it goes?
my last log saw 0 min and 7 max
also...anyone else seeing the lambda stay around .7578125...mine stayed there from 3000 all the way to redline
mosqito16 is offline   Reply With Quote
Old 06-23-2005, 08:25 AM   #308
TheMadScientist
Member#: 23717
2005 Big red
calvin.
Greater than 1 is lean and less than 1 is rich.
TMS
TheMadScientist is offline   Reply With Quote
Old 06-23-2005, 08:59 AM   #309
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
calvin.
Since AFR=lambda*14.7, a lambda <1 would give you an AFR <14.7=rich, and a value >1 would = >14.7 = lean.
BTW, you didn't forget about fuel flow did you? I'd like to see instant MPG values, now that you got the vehicle speed fixed.
DougG is offline   Reply With Quote
Old 06-23-2005, 10:40 AM   #310
x99percent
Member#: 27108
2004 STi
2004 A4
0.757Lambda = 11.13:1 AFR... that is the richest the stock front O2 sensor will read.
DO NOT use this value to tune, as wideband sensors are not accurate under pressure (e.g. high pre-turbo exhaust pressure).
x99percent is offline   Reply With Quote
Old 06-23-2005, 12:23 PM   #311
calvinc
Member#: 73190
Default TARI Racing Software FORUM is up and running...
i finally managed to get the TARI Forum working. so we can move our discussions across there and stop adding to this ever increasing thread.
go to it from here (www.tari.co.za/cgi-bin/yabb2/YaBB.pl), as i havent updated the TARI main menu yet.
its a brand new forum so i havent created any groups/topics yet. it is a free forum from YaBB (Yet another Bulletin Board) so login, see if you can register and make a post in the 'test' section.
tomorrow i'll add some groups and we can get on with it.
calvin.
Old 06-23-2005, 12:59 PM   #312
DougG
Member#: 58975
calvin.
Ha! I was the first poster! This will be easier to keep the threads/info in one place, but not help me at all on my quest to rid myself of my newbie status and get "specialist" status.
Old 06-23-2005, 01:41 PM   #313
mosqito16
Member#: 42668
ahh thank you...clears that up
Old 06-23-2005, 02:24 PM   #314
rsk135
Member#: 65578
Thanks for this post. I have a MY00 Forester and a MY01 Outback Limited Sedan. I still need to buy the cable and was wondering if this would work. Which cable did you get, generic or wrx?
I'm also wondering about the code and code clearing software. Did you find any?
As for Calvin perhaps we could just ship beer to his home. I'm sure there's a local distributor/brewery that would be happy to do that. Plus he wouldn't have to wait for if/when he came here.
rsk135 is offline   Reply With Quote
Old 06-23-2005, 05:37 PM   #315
Joelk
Member#: 7790
2009 wrx
I bought the generic cable. It has one pin missing (#14 I think) compared to the WRX version. I read that that pin is used to supply voltage for reflashing WRX ECUs. I don't know if the existence of that pin would cause any problems on a non-WRX subaru, but I didn't see any WRXs in my future so I just played it safe...
I have not yet found any other software that will work with this cable that reads the diagnostic codes. The other free software I've tried have given errors saying it can't open device or find the correct interface. For example, scantool.net has some free software, but the cable they sell uses different pins than the OpenPort cable. They are also using an ELM 323 chip, which may futz with the data from the ecu before sending it to the software.
I am going to try freediag next (freediag.sourceforge.net). Hopefully I can get it to work on a slax cd or something. I was also looking at their source code to see how hard it would be to finish porting it to windows. Some of the os abstraction has been done, but it looks like it's still using linux specific serial functions.
Old 06-23-2005, 11:44 PM   #316
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
I have the same question about the knock correction readings as Mosquito16.
I went out and gave the program a little test and saw a 0 min and 1 max.
Does this mean that I had one episode of detonation?
Thanks,
Don
Don Arm is offline   Reply With Quote
Old 06-23-2005, 11:52 PM   #317
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
I don't think so. KC usually scales from negative values to positive, with negative usually being low single digits, and positives going all the way up to 12+.
How far the KC gets depends on the current IAM value as well as how much KC authority the map you are running allows at that load/RPM point.
I'm not sure that the logger always logs KC correctly, I have seen a couple logs from it where the KC has ranged between 0-1 which would be very abnormal.
drees is offline   Reply With Quote
Old 06-24-2005, 04:41 AM   #318
mosqito16
Member#: 42668
he is talking about the digital signal...it will only show 0 or 1...you are talking about the knock correction in terms of degrees (analog)
Old 06-24-2005, 07:02 AM   #319
drees
Member#: 25905
2003 Silver Wagon
OK, so if Don was looking at the Knock Sensor signal, all you can tell from it is whether or not the ECU is seeing knock when you happened to sample it. So if it hit 1, the ECU picked up some knock.
Old 06-24-2005, 07:12 AM   #320
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
Well, I hope it's not detonation.
I'm running Cobb Stg 2 93 oct map w/ gutted stock up-pipe, TXS turboback, K&N filter, ported and polished TB, Walbro FP. I usually run Sunoco or Shell 93
I've had another problem w/ stg 2 running really high >1600 F egt's during track day's. But after flashing their current stg 2 map the egt's do not get above 1500 which is still a little high.
When I called Cobb about the high egt's I did not get much help.
That's why I'm hoping it's not knock.
Don
Old 06-24-2005, 01:59 PM   #321
SubieRX
Member#: 16611
05' STi w/ meth inj
Tuned By Harman Motive
Originally Posted by skoobywrx
Me:
Yeah, I've also recorded a 1.390625 right after I lift off the gas. Is this too lean?
Edit: Btw, this program is way cool. Awesome job calvin.
SubieRX is offline   Reply With Quote
Old 06-24-2005, 02:11 PM   #322
JRSCCivic98
Member#: 67080
Lean conditions like that is normal when you lift off the gas. This is normal with all vehicles.
JRSCCivic98 is offline   Reply With Quote
Old 06-24-2005, 03:05 PM   #323
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Were can I get a cable for a laptop?
Patrick L is offline   Reply With Quote
Old 06-24-2005, 03:07 PM   #324
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
look in the earlier pages.
the tactrix will work, Cobb AP cable...
Quack is offline   Reply With Quote
Old 06-24-2005, 03:35 PM   #325
ahains
Member#: 28823
2004 WRX Wagon
And just to be clear - the tactrix cable is USB, and Cobb cable is serial.
If your laptop only supports one or the other, this may be an issue for you.
Although note that the free tool to download the ROM image to your computer appears to currently require an unusual baud rate and may not work with the Cobb cable (I'm not certain).
The thread discussing that tool is here:
http://www.openecu.org/viewtopic.php...r=asc&start=15
-Adrian
ahains is offline   Reply With Quote
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 06:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 08:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 08:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 09:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 02:17 PM
