Old 06-26-2005, 09:04 PM   #351
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
DL could mean data log also right?
Just trying to help.
Don Arm is offline   Reply With Quote
Old 06-26-2005, 11:59 PM   #352
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
Originally Posted by JRSCCivic98
Hey Calvin, what's up with the exhaust temp sensor readings. I've logged 2 cars already 1 with Cobb Stage 2 and the other with EcuTek Stage .5 (stock car) and they both register 356C degrees. Is the address just wrong for the sensor or will it just not read? Since you have an STi I wana guess that you just don't have the address right since there's not stock egt on the STi uppipe. Just wondering.
Just a thought, the EGT sensor is to make sure the cat in the uppipe does not overheat. since the STi does not have the cat in the uppipe from the factory, there may not be an EGT sensor.
just my .02 cents.
Joe
scoobdude is offline   Reply With Quote
Old 06-27-2005, 03:08 AM   #353
calvinc
Member#: 73190
2005 Impreza WRX STi
i have changed to a forum based website so please rather use that. go back to the main page (www.tari.co.za), press Ctrl-F5 for a full page refresh and then click on the text. you will be taken into the new forum stuff where you will see the groups for the different software, etc.
egt's - i cant really offer any solid advice on this since as i havent owned a scoob with a stock egt sensor fitted. all i can say is that whatever value its showing is most likely coming directly from the ECU and therefore its the ECU that isnt changing it. we can verify this with some port sniffing, email me and i'll let you know how to do this.
calvin.
calvinc is offline   Reply With Quote
Old 06-27-2005, 11:55 AM   #354
C_WReX
Member#: 39285
2003 Impreza WRX
2005 Impreza OBS
Thanks for all the hard work and great software calvin.
I would also like to vote for the addition of IAM to the next rev.
C_WReX is offline   Reply With Quote
Old 06-28-2005, 12:04 AM   #355
JRSCCivic98
Member#: 67080
just my .02 cents.
Joe
Thanks for pointing out the obvious dude. The logs I've done were on WRXs which have an OEM EGT in the uppipe. If you reread what I wrote you'd see that I'm stipulating that he may not have the appropriate address being logged "because he owns an STi" which "don't have EGTs in the uppipe".
JRSCCivic98 is offline   Reply With Quote
Old 06-30-2005, 02:04 PM   #356
euro
Member#: 42697
2004 WRX STi
White/Gold
I wish I could just view the IAM.
04, AP Stage 2
euro is offline   Reply With Quote
Old 06-30-2005, 07:47 PM   #357
JRSCCivic98
Member#: 67080
For those of you that have already done some logs. What is the higest and lowest reading on the Knock Correction your're seeing? Better said, what is acceptable for knock correction and what would be considered a value that some tuning might help? I realize that knock correction values logged will tell more if I knew what my IAM was, but we're all waiting on that value to be added in.
Old 06-30-2005, 08:49 PM   #358
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
Have you seen this? http://www.ecutek.com/tuning/diagnostics/
I haven't seen anything other than 0's on my '05 WRX with a Cobb stage 1 93 map.
BTW, we should take any more discussion of DL1 to the dedicated forum at http://www.tari.co.za/cgi-bin/yabb2/YaBB.pl
DougG is offline   Reply With Quote
Old 06-30-2005, 08:58 PM   #359
JRSCCivic98
Member#: 67080
Can't belive I actually missed that on EcuTek's webpage. Anyway, after some reading I've discovered that I was interpreting KC incorrectly. All is good.
Old 07-02-2005, 06:41 PM   #360
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Calvin, will we have the new version tomorrow?
west_minist is offline   Reply With Quote
Old 07-02-2005, 09:26 PM   #361
STirocket
Member#: 84006
WRB with Goldies
JRSC,
I have a run with Knock Correction values from 0 up to 6. They appear to be at periods of heavy boost and wide throttle opening. Not necessarily at maximum RPM...
STirocket is offline   Reply With Quote
Old 07-03-2005, 02:10 AM   #362
Student Driver
Member#: 65161
2002 2.5RS, AW
I can taste teh suck
Subscribe, thanks.
Student Driver is offline   Reply With Quote
Old 07-03-2005, 02:26 PM   #363
willguidry
Member#: 16388
Were do you download the software now?
willguidry is offline   Reply With Quote
Old 07-03-2005, 02:32 PM   #364
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
Quack is offline   Reply With Quote
Old 07-03-2005, 02:33 PM   #365
Quack
Member#: 57264
Old 07-04-2005, 03:21 AM   #366
calvinc
Member#: 73190
not sure about that. still have to put in the ECU reset function (clear cel's). all other additions seem to be working fine.
calvin.
Old 07-04-2005, 08:02 AM   #367
west_minist
Member#: 53451
w/ AVCS Silver
ok. well, it is too late now. The weekend is gone now.
Next weekend then.
The reset function would be great. I hope my AFR works. what value would you use? 46?
Old 07-07-2005, 12:09 PM   #368
dnyet
Member#: 58445
If the Cobb cable loses contact with the odbII port will it cause any issuse other than an error? Wanted to try the software but my Cobb cable loses conection sometimes when reading boost levels.
dnyet is offline   Reply With Quote
Old 07-07-2005, 10:01 PM   #369
JRSCCivic98
Member#: 67080
If that happens Tari's DL1 program will throw up a message on the screen stating that "Communication has failed with ECU". You then have three options.
1) Turn ignition off then on and try again.
2) Get a replacement cable and try again.
3) Send in your ECU + Laptop to have them both replaced only to get them back and they still won't talk to each other.
Sorry, couldn't resist.
But seriously now... no, it won't do anything bad. It'll just loose communication. That's all.
Old 07-14-2005, 12:58 AM   #370
vlady
Member#: 77997
dirty blue
This is awesome. Just downloaded and will spend some of sat tinkering with it. I love tinkering
vlady is offline   Reply With Quote
Old 07-14-2005, 09:08 PM   #371
dnyet
Member#: 58445
Can you log EGT'S with this software or will it be possible with latter versions?
Old 07-15-2005, 10:50 AM   #372
ahains
Member#: 28823
2004 WRX Wagon
Yes, it logs EGTs from the stock EGT probe.
Folks say this is not accurate because it is in the up-pipe (pre-turbo), and so the back pressure causes a drop in accuracy.
They also say it is only/mainly used by the ECU for something to do with the cat.. probably cat efficiency or something.
I would be very very very curious to see someone post logs of the stock EGT alongside an aftermarket EGT probe, to see how they differ.
My logs show a peak of about 1525*F EGT, and this was at 3k rpm and 12.8psi boost, so it may be somewhat accurate.. I wouldn't tune based off of it though, at least not until folks show logs comparing it to a real probe.
HTH!
Adrian
ahains is offline   Reply With Quote
Old 07-15-2005, 02:32 PM   #373
io1029
Member#: 78993
2005 WRX
TGV, begone!
HTH!
Adrian
Everything I've been reading on these forums makes it sound like the stock EGT probe is just there to ensure the uppipe cat doesn't melt. So it might only be sensitive enough to know the difference between "Oh ****" and "Everythings OK".
io1029 is offline   Reply With Quote
Old 07-15-2005, 09:03 PM   #374
stanton
Member#: 21508
'03 WRX Wagon
I was going to post the same thing. ECU only reacting to EGT by backing stuff off if that temp gets too high. This is based on the same stuff you read.
Also, the probe is after the cat. So the fact that it's pretty far from the exhaust valve, plus after the cat makes it what you don't want to tune from. The temperature there will be different than near the head, and not always by the same amount. Cooler by distance, warmer by catalytic reaction.
edit: I have no cat there and a VDO probe and gauge. A normal 70mph highway cruise is 1200F. Highest I ever saw was about 1450F today at 100mph (Pocono) with 94 octane.
stanton is offline   Reply With Quote
Old 07-17-2005, 12:18 PM   #375
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
I just got the IAM function working on the logger. 16 oh yea baby the car is happy.
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
