Old 08-02-2005, 03:00 AM   #426
hatchy
Member#: 36852
2004 STI
tried it. does not work.
Originally Posted by ahains
I'm fairly certain that the TARI app does not use the ODBCII protocol, I think it uses the Subaru Select protocol (or whatever it is called). IMHO, you are *far* better off buying the tactrix cable and leaving the door open to flashing your ECU down the road.
hatchy is offline   Reply With Quote
Old 08-03-2005, 12:37 AM   #427
Student Driver
Member#: 65161
2002 2.5RS, AW
I can taste teh suck
The cable didn't work for you? What happened?
Student Driver is offline   Reply With Quote
Old 08-03-2005, 12:44 AM   #428
Student Driver
Member#: 65161
2002 2.5RS, AW
What would be nice is if the you ran inside another prompt, similar to using "nslookup" in Windows to dig up DNS records. You launch the command with the connection parameters, then it can persist the connection while accepting further commands to read, write, compare, etc. This would assure that you stay connected to the "OS" running in volatile RAM and not have your connection reset when the executable fails and kills the command prompt (like the GUI control).
The app is good, and what it can do is awesome. But there are risks with everything. The replacement ECU was $150 + shipping, and I didn't have too much heartburn with that. I hope to work with the project some more to help out others in the future, and I might get another ECU to play with later on.
Old 08-03-2005, 01:02 AM   #429
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
I think he is referring to the VAG-COM cable.
colby is offline   Reply With Quote
Old 08-03-2005, 01:04 AM   #430
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
That is, in effect how things work. You can run the ecuflash.exe app multiple times without turning the car off and on again. It is turning the car off and on that drops you out of the kernel (which is the equivalent to the "prompt" you mention).
(olby
Old 08-03-2005, 01:58 PM   #431
jugger
Member#: 64228
can someone help me out please
i have a 03 wrx and was wanting to do two things
1.monitor my IAM but i cant seem to fine that option on the list of items to monitor...iv downloaded and installed all the latest patchs but nothing seems different...where is IAM option on the list and what version of the sofware was is implemented?
2. i would like to log some of this data but i cant find a "csv" file...what is a csv file and where can i find one i asume this is the file i need in order to log
thanks
jugger is offline   Reply With Quote
Old 08-03-2005, 02:08 PM   #432
timmah
Member#: 54203
2011 WRX
a .csv is the type of file it saves when you do the logging. its just a comma separated values (hence, csv) file. It can be read in excel or openoffice.
timmah is offline   Reply With Quote
Old 08-03-2005, 02:13 PM   #433
jugger
Member#: 64228
when i hit the *.* button its looking for a csv file but i dont have one....if i just select some random file like excel and then open a small box comes up and its in chines
Old 08-03-2005, 02:21 PM   #434
wall of tvs
Member#: 29716
2006 wrx wagon
booze powered e85 monster
Has anyone been able to find out the proper address for the '04 ecu (specifically AH791) regarding the IAM?
I recall somebody saying that they had a sniffer program to figure out specific addresses.
wall of tvs is offline   Reply With Quote
Old 08-03-2005, 02:46 PM   #435
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
You need to modify a registry setting to get IAM logging to work. Details are on the Tari forum.
When logging (use the Defrost switch to trigger logging), the DL1 will put timestamped .csv files in the Program Files/Tari Logger/DL1 directory. You can find them in there and open them with either the DL1 or Excel.
drees is offline   Reply With Quote
Old 08-03-2005, 02:59 PM   #436
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Quick Q. Is this software still uncompatible with the 04-05 STi's?
Undepelo is offline   Reply With Quote
Old 08-03-2005, 03:24 PM   #437
JRSCCivic98
Member#: 67080
Software works fine on 04 STIs. Can't tell you anything about 05 because I just haven't logged one, but it works just fine on 04's. Can't see why it would be a problem on 05's.
JRSCCivic98 is offline   Reply With Quote
Old 08-03-2005, 05:52 PM   #438
Student Driver
Member#: 65161
2002 2.5RS, AW
(olby
Did you by chance try the GUI and see if it breaks the connection when it collapses the command prompt after execution? Basically, try a backup of the ECU, then immediately run the compare mode.
Old 08-03-2005, 05:56 PM   #439
Student Driver
Member#: 65161
2002 2.5RS, AW
The address hasn't been found yet for IAM, but this is the thread to keep a watch on:
http://www.tari.co.za/cgi-bin/yabb2/...num=1120868917
Old 08-03-2005, 05:59 PM   #440
drees
Member#: 25905
2003 Silver Wagon
Jugger (who I had replied to) has an 03 WRX and the IAM has been identified for it. I should know, I've logged IAM on my 03.
Old 08-03-2005, 06:23 PM   #441
Student Driver
Member#: 65161
2002 2.5RS, AW
Ah, my apologies, as it appeared you were replying to wall of tvs, who has an 04.
Old 08-03-2005, 06:49 PM   #442
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
It works fine on an '05 WRX as well, just not the IAM...yet...
Be sure to read and follow the tari message board
http://www.tari.co.za/cgi-bin/yabb2/YaBB.pl
DougG is offline   Reply With Quote
Old 08-04-2005, 12:07 AM   #443
wall of tvs
Member#: 29716
2006 wrx wagon
Yup. I see that both you and I have posted in this thread regarding this issue on the '04.
Old 08-04-2005, 02:31 AM   #444
Student Driver
Member#: 65161
2002 2.5RS, AW
Yeah, I dug up the link and saw your name already there, but posted it for others to go directly there if and when a search turns this up.
Old 08-04-2005, 06:11 PM   #445
scooterforever
Member#: 55011
This software rocks. Calvin just helped me out with an RPM problem I was having, and now I can log my RPM and Injector duty cycles. Also, the Tactrix cable is working out very well. Used AP cable for cheap anyone?
I've been waiting to get the RPM data working so I could check on my IDCs -- I have been running alky injection for the last 2,300 miles, and wanted to see how low there were. Well... 72.x% is my peak IDC in a 2nd gear WOT pull (VF-34 and support mods, aquamist 2d).
Again, hats off to the the folks behind Tari, Tactrix, OpenEcu, etc. Cheers,
scooter
scooterforever is offline   Reply With Quote
Old 08-05-2005, 10:13 AM   #446
jugger
Member#: 64228
thanks for your help
are you saying i need to manually hit the defrost switch located on my dash board to initiate logging?
Iv hit both of the defogger check boxes in the program but nothing
(maybe im going about this all wrong but) when im in the log window There is a *.* button (that I assume is looking for a file to log to) so when I hit the *.* button it is asking for a csv file (I assume to log and store the data to) but I don’t have one….where do i find one?
Old 08-05-2005, 10:36 AM   #447
DammitBevis
Member#: 3569
2006 STi
AW
The log window is for viewing .csv files you already made. You log from the view window and it auto generates log file names from the date/time.
DammitBevis is offline   Reply With Quote
Old 08-05-2005, 01:17 PM   #448
tool1128
Member#: 84306
2004 WRX
theres alot of info here and I read the vast majority but I'm still lost and am a complete noob.....
are there any easy directions to download the logger and how to just run it and log for now so I can get used to how it works??? maybe where at in this whole thread they might already have covered this in case I missed it?
tool1128 is offline   Reply With Quote
Old 08-05-2005, 02:27 PM   #449
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
In the tari forums, there is a documentation section. I am working on it now... See it for more info. www.tari.co.za
bofh is offline   Reply With Quote
Old 09-09-2005, 12:15 AM   #450
intence
Member#: 58477
. Member #1 of
the witty MS Crew
what does IAM stand for?
intence is offline   Reply With Quote
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
