Old 07-30-2006, 02:17 PM   #576
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
^^^That's probably the case.
Count the pins on the cable (9) and then on the port on the laptop. I think you'll find it has 15 pins which is VGA not serial.
Bort is offline   Reply With Quote
Old 07-30-2006, 08:08 PM   #577
rotaman
Member#: 92086
2002 wrx stage 2
Subaru Blue
yeah, thanks guys i didnt look at it carefully enough, i went and bought a serial to usb adapter and it works awesome! is there anyplace i can go to compare some numbers now that i have some logging done? thanks for the help, love the software
rotaman is offline   Reply With Quote
Old 07-30-2006, 09:37 PM   #578
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
So, is anyone actually runnning this on their Mac via VPC?
I only saw 3 posts in this thread that mentioned a Mac and it was a while ago.
If it works I am going to get the Tactrix cable so that I can log my new engine.
If not, I will have to look into a cheap laptop.
Thanks.
chudlo is offline   Reply With Quote
Old 08-03-2006, 11:10 PM   #579
MSo
Member#: 5008
2002 /06 STi GGA
SRP
*subscribe*
MSo is offline   Reply With Quote
Old 08-09-2006, 10:22 PM   #580
Nis01
Member#: 31942
'99 Miata Sport
I have downloaded the Tari software and have the cable (from Accessport) and am just wondering if anybody has written a procedure on how to use the software correctly. I am a noob to datalogging and don't want to fry the ECU. Is it as simple as plugging it in... selecting the right COM port and firing up the car to go datalog? If there is a link to a previous procedure guide I would grealy appreciate it. I've read the user guide and wanted to double check everything. Thanks.
Nis01 is offline   Reply With Quote
Old 08-09-2006, 10:42 PM   #581
Swordfish II
Member#: 95554
2007 The Surly Squad
Yes it is that simple. The ECU cannot be fried by that since you are only reading the data from the port. In order to write to the ecu you have to use all the connectors that go with the Accessport, and it is only then you risk frying the ecu.
Swordfish II is offline   Reply With Quote
Old 08-09-2006, 10:45 PM   #582
Nis01
Member#: 31942
'99 Miata Sport
Thank you for the quick reply. I appreciate it. Time for some logging.
Old 08-31-2006, 05:19 PM   #583
rayzz
Member#: 95543
2005 WRX Wagon
Crystal Gray Metallic
got this working with my cable last night, thanks colby for the cable!!! arrived extremely fast, and ECUExplorer is amazing, such great FREE software. Thank you guys so much, took no time at all to get it up and running.
rayzz is offline   Reply With Quote
Old 09-07-2006, 08:17 AM   #584
sebtarta
Member#: 82883
2006 2.5i Wagon
'72 Nova Turns & Stops
Hey guys/gals quick question.
I have the Belkin USB->Serial adapter. For some odd reason I cannot manage to have the ecuExplorer recognize the ECU.
Does anyone have this adapter and is successfully reading logs etc?
The Belkin is recognized by the laptop, Win XP SP2 with all updates.
sebtarta is offline   Reply With Quote
Old 09-07-2006, 08:32 AM   #585
Jeramie
Member#: 56995
2016 WRX
WR Blue
On the tari forum I belive there is a list of adapters that work properly. I don't recall the belkin being one (I could be wrong). For some reason I think I rember they saying the RadioShack adapter works fine?
Jeramie is offline   Reply With Quote
Old 09-07-2006, 02:38 PM   #586
Skidd
Member#: 1853
GC6 Supercharged
STM
At 24 pages long, I dont think this can be considered a Hijack.. but.. since Calvin has stopped working on ecuExplorer, and for other reasons, I've started a similar program of my own. It's main purpose is for sensor display and logging. NOT for flashing. It works with the Tactrix OpenPort cable, so I thought you guys here might be interested in it. It's still in development, but comming along nicely.
http://jdash.sourceforge.net.
Skidd is offline   Reply With Quote
Old 09-07-2006, 02:48 PM   #587
Jeramie
Member#: 56995
2016 WRX
WR Blue
You may want to check this out
http://www.enginuity.org/viewtopic.php?t=44
Old 09-07-2006, 07:51 PM   #588
Skidd
Member#: 1853
GC6 Supercharged
STM
Enginuity has a different mission that JDash though. It's main job seems to be for the modification of ecu maps. The job of JDash is for realtime display only. I created JDash for my in car PC, so I could watch the sensors on the LCD.
Old 09-08-2006, 02:18 AM   #589
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
I think Jeramie's point is that Enginuity already has logging working and perhaps your time may be best spent on enhancing an existing one instead of reinventing the wheel. Of course, if you don't program in Java...
drees is offline   Reply With Quote
Old 09-08-2006, 08:43 AM   #590
Jeramie
Member#: 56995
2016 WRX
WR Blue
Enginuity is to edit images, but the enginuity logger that the link links to is a logger with a dash display (and graph display). I wasn't trying to put down your work, but no sense in having 2 people work on the same projects. Paul (person working on enginuity logger) is doing a great job, and I'm sure he could use help. I just figured I would point it out incase you had a interst in contributing.
Old 09-08-2006, 08:44 AM   #591
Jeramie
Member#: 56995
2016 WRX
WR Blue
Yep
Old 09-08-2006, 03:00 PM   #592
Skidd
Member#: 1853
GC6 Supercharged
STM
Ah.. Hadn't seen that part of Enginuity. I'll go have a closer peek at it.
There might not be enough overlap though. JDash is being designed primarily for sensor display within a CarPC. And, JDash will be fully skinnable. It's logging capabilitys come 2nd. Plus, JDash will, in the end, support OBD-I, OBD-II, ElmScan and any other interface I can get my hands on. But.. I'll still have to look closer at Enginuitys logger.
As for 2 projects with the same mission.. It's not really a waste of my time. 1, I'm learning some good new stuff with Java. 2. competition is good.
Old 09-18-2006, 07:57 AM   #593
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
My son has used this adapter with his laptop in conjunction with DL1, the predecesor of ECU explorer. This was with Windows XP pro on a Dell Inspiron 9100.
DougG is offline   Reply With Quote
Old 09-20-2006, 08:53 PM   #594
limeylight
Member#: 5428
97 Legacy Outback
I just read all 24 pages of this awesome thread on this awesome software. I downloaded the software too but have not yet forked out for a cable as I didn't find out if it will work on my 97 Legacy. (that's why I read the whole thing). There were a few tantilizing mentions but nothing definitive. Then I find the discussion moved to the TARI forum but dont have time to read all that just yet so I'll pose the question here in the hope that someone already knows: can it read my ancient ECU?
limeylight is offline   Reply With Quote
Old 09-21-2006, 11:51 AM   #595
Ezmendriz
Member#: 10747
Question Skidd the Skins?
Skidd you said yor aplication is skinnable and configurable, but i was unable to do so. How it is done?
BTW yor aplication is great. It is just what i was looking for for my car-pc project.
Ezmendriz
Ezmendriz is offline   Reply With Quote
Old 09-21-2006, 12:00 PM   #596
limeylight
Member#: 5428
97 Legacy Outback
Does Jdash work with 97MY subarus?
Old 09-21-2006, 03:55 PM   #597
Skidd
Member#: 1853
GC6 Supercharged
STM
Ezmendriz
Glad you like it. I designed it for an in car PC app from the get go.
As for the configurable and skinnable interface. Well.. I'm still working on the documentation on the main website. It will eventually explain how to setup a skin, and configure a sensor file. Have you looked over the site lately? Also, if you want to get into a dialog on how to create a skin, or configure a sensor file, you can start a thread in the JDash forums. That mgiht be a better place for it.
limeylight
If memory serves, the my97 is OBD-I. Is that correct? If it's OBD-II, then JDash will work for you. I'm still working on Subaru OBD-I support. I'm working with a guy in Austria of all places. The SSM protocol is still supported on older Subies, but the format is different. And you'll need a different connector.
Old 09-21-2006, 03:59 PM   #598
qoncept
Member#: 44762
2013 BRZ
If you'd be interested in making the dash in Enginuity skinnable at some point that'd be great.
qoncept is offline   Reply With Quote
Old 09-21-2006, 04:00 PM   #599
limeylight
Member#: 5428
97 Legacy Outback
It's OBD-II.
What connector works?
Old 09-21-2006, 04:14 PM   #600
qoncept
Member#: 44762
2013 BRZ
You'll probably be best off with an ELM cable, which you can find on google. It won't work with any of the openecu software though.. :\ It will be easy enough to add other interfaces like the ELM in Enginuity once the logger is released though, just need the cables to test.
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
