Old 09-21-2006, 04:34 PM   #601
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
So I just randomly saw this thread, downloaded the program, and tried it out with my AccessPort cable. What a cool program! I don't have any real use for it, but its still cool to pull up plots in excel of everything!
twizzstyle is offline   Reply With Quote
Old 09-21-2006, 05:14 PM   #602
STL WRX
Member#: 88304
05 VF34 Aspen WRX
What serial to usb adapters are compatible? I pan on using the AP cable.
STL WRX is offline   Reply With Quote
Old 09-21-2006, 05:55 PM   #603
Skidd
Member#: 1853
GC6 Supercharged
STM
Originally Posted by limeylight View Post
It's OBD-II.
What connector works?
If your asking about JDash, then at present only the Tactrix OpenPort cable works. I'm still working on making JDash work with an ELM module. Thats my next big goal.
Skidd is offline   Reply With Quote
Old 09-21-2006, 05:56 PM   #604
Skidd
Member#: 1853
GC6 Supercharged
STM
If you don't already have the AP cable, they already make a OBD-II->USB version. It uses the FTDI usb->serial adapter internaly. I am also doing some testing with a friends older OBDCOM cable through a keyspan USB adapter. And so far, so good.
Old 09-21-2006, 06:26 PM   #605
STL WRX
Member#: 88304
05 VF34 Aspen WRX
I have the cable... I just dont have a serial port on my laptop... I need to know that brand adapter works best with the data logger and the ap's cable. Someone said the Belkin doesnt work and someone said the Radio Shack adapter works...
Old 09-21-2006, 06:33 PM   #606
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Looking at the Tactrix website, there are two cables there, the "OpenPort for WRX and drive-by-wire vehicles" and also the "OpenPort for Subaru Drive-by-wire vehicles". From what I can tell the only difference is the WRX-specific one comes with a reflash connector.
I have an 05 Impreza RS, which was the first year for n/a Impreza's getting drive-by-wire. The OpenPort for Subaru vehicles only lists the turbo models as compatible, but it looks from this thread like other Impreza owners have used this thing without issues, anybody have anything to say about my application before I order one up?
FalconRS is offline   Reply With Quote
Old 09-21-2006, 10:18 PM   #607
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
Belkin works on my son's XP laptop along with an AP cable connected to a 2002 RS2.5.
DougG is offline   Reply With Quote
Old 09-25-2006, 03:33 PM   #608
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Wouldn't one of these inexpensive cables work??
Undepelo is offline   Reply With Quote
Old 09-25-2006, 05:02 PM   #609
Skidd
Member#: 1853
GC6 Supercharged
STM
Not quite. But almost. As I understand the OBD-II interface, it's not directly compatable with a PCs serial port. The cables on that site seem to provide a way of connecting the standard OBD plug to a standard DB9 plug. But, from there, you still need some hardware to convert the line signals to one a PCs serial port would understand.
Check out #1 in this faq.. it seems to back me up.
http://www.ross-tech.com/vag-com/faq_3.html
And here is an example of a homemade OBD bridge.
http://www.planetfall.com/~jeff/obdii/
Old 11-04-2006, 02:49 AM   #610
ImportVenom
Member#: 34204
2004 WRX
WR Blue
I tried searching this thread but couldn't seem to find the answer. The ecuExplorer is giving me a bunch of currrent and historic trouble codes (both lists are the same). However, there is no check engine light on. Should I worry about these trouble codes?
I am using v3.0.25 and saw an old post that there might be issues with trouble code reading...I'm just wondering if I should worry about the 19 trouble codes showing up as current AND historic...thanks
ImportVenom is offline   Reply With Quote
Old 11-04-2006, 09:28 AM   #611
Jeramie
Member#: 56995
2016 WRX
WR Blue
Trouble codes do not work properly. But I think you have the right idea, if you do have a trouble code there will be odd one
Jeramie is offline   Reply With Quote
Old 12-01-2006, 07:57 PM   #612
jmc9809
Member#: 33344
2015 WRX
Hey all -
I posted this in its own thread, but thought I'd mention it here for anyone that is subscribing to this thread. I put up a webapp that will do some simple analysis and create graphs from your logfiles. The thread can be found here, and the webapp is located at http://www.waygate.net/plotter
jmc9809 is offline   Reply With Quote
Old 01-01-2007, 04:17 PM   #613
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Very nice JMC.
Thanks for sharing.
Buck
***EDIT***
It is interesting that due to the Y-axis scaling, boost and load almost exactly match each other.
bucket7788 is offline   Reply With Quote
Old 01-23-2007, 02:49 PM   #614
lostintheforest
Member#: 123157
2004 forester xt
white
not sure if this has been broughten up yet..but i own a AP v2 with the USB cable not the serial cable..wondering if it would work going from the AP obd plug and connecting the mini usb motorola to and then connecting that to the ole laptop?? hopefullyyyyy
lostintheforest is offline   Reply With Quote
Old 02-13-2007, 02:31 AM   #615
Sinister7
Member#: 139685
2006 WRX Sedan
SGM
yeah.. it's on the website under approved cables.
Sinister7 is offline   Reply With Quote
Old 03-12-2007, 04:30 PM   #616
jruben4
Member#: 50784
2005 STi
Anyone get JDash to work with the AP v1 cable (+USB converter)? I got it to read for a second or two, but then froze...
jruben4 is offline   Reply With Quote
Old 03-12-2007, 04:32 PM   #617
jruben4
Member#: 50784
2005 STi
Is there any reason why you couldn't use ECU Explorer to read the image of your ECU programming when you have a COBB map installed?
Old 03-12-2007, 05:49 PM   #618
Jeramie
Member#: 56995
2016 WRX
WR Blue
You can but it won't include any realtime maps. Not sure what the point would be if it did include the realtime maps. Cobb = very safe and conservative. Theres lots and I mean lots of power left on the table.
Old 03-23-2007, 08:34 AM   #619
MG-T
Member#: 143663
Does ecu explorer use the subaru select monitor protocol? I'm wondering if i can pin out tx, rx signals to the yellow subaru connector. I got legacy 2,5 euro my96. It hasnt obdii connector.
MG-T is offline   Reply With Quote
Old 03-23-2007, 09:07 AM   #620
Jon [in CT]
Member#: 2992
02 WRX Sedan
Yes, you can do this and even capture the realtime maps, if you have a 2002-5 WRX. Follow the instructions at http://forums.openecu.org/viewtopic.php?t=998.
Jon [in CT] is offline   Reply With Quote
Old 03-24-2007, 04:13 AM   #621
MG-T
Member#: 143663
Question
Old 03-25-2007, 06:58 AM   #622
MG-T
Member#: 143663
Where can I download the ecuexplorer. I changed my hdd and lost the instalation. Tari says its under construction. Please link me.
Old 03-25-2007, 11:39 AM   #623
logic
Member#: 47613
2005 WRX Wagon
Obsidian Black Pearl
Go to Tari's website, click on "ecuExplorer - Latest Release" in the sidebar. Looks like it works just fine to me...
logic is offline   Reply With Quote
Old 03-26-2007, 07:41 AM   #624
MG-T
Member#: 143663
Thanks its fine now!
Old 04-16-2007, 11:52 PM   #625
rexspeedmaster
Member#: 123103
2003 WRX
Full 07 STI trans
I have the accessport cable and an adapter to plug it into my USB port. However when i plug everything in and turn on the car it still says the ecu is disconnected? What could be wrong? Something having to do with com porte setting i am thinking?
rexspeedmaster is offline   Reply With Quote
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
