Old 04-22-2007, 07:53 AM   #626
jruben4
Member#: 50784
2005 STi
Originally Posted by Jon [in CT] View Post
Yes, you can do this and even capture the realtime maps, if you have a 2002-5 WRX. Follow the instructions at http://forums.openecu.org/viewtopic.php?t=998.
Hmm, they removed the instructions from that post...
jruben4 is offline   Reply With Quote
Old 05-13-2007, 01:54 AM   #627
swiper7
Member#: 145826
Default gnar
gnar ftw!!
swiper7 is offline   Reply With Quote
Old 05-19-2007, 09:41 PM   #628
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
Originally Posted by rexspeedmaster View Post
I have the accessport cable and an adapter to plug it into my USB port. However when i plug everything in and turn on the car it still says the ecu is disconnected? What could be wrong? Something having to do with com porte setting i am thinking?
rexspeedmaster:
Did you ever get an answer?
I'm hoping to do the same thing. I have the first generation Cobb AP cable with the serial connector and a Keyspan serial>USB adapter that I know works for programming my digital scanner (apparently some adapters don't). The Keyspan is supposed to be one of the better adapters, IIRC.
I'll admit I couldn't force myself to read all 20+ pages in this thread, but from what I did read, it seemed that some people were able to get the AP cable with a serial>USB adapter to work, and others weren't so lucky.
I'll buy the tactrix cable if I have to but I'd just as soon save the $100. All I want to do at this point is data logging.
rexspeedmaster or anyone else have any experience using the 1rst gen AP cable? Were you able to get it to work? Does it seem to depend on what software you're using?
Second question:
Is there any consensus on what is the best data logging software?
Is it a case of 'you get what you pay for' or is the free software just as good?
sajohnson is offline   Reply With Quote
Old 05-19-2007, 09:50 PM   #629
jruben4
Member#: 50784
2005 STi
I had good luck with the 1st gen AP cable and the *radio shack* serial->usb converter. I think ecuExplorer may only recognize certain usb cables.
Old 05-19-2007, 09:59 PM   #630
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
When you say you had good luck, were you using ECU Explorer?
[Sorry for the original post, I missed the 'I had..' at the beginning and read it as, "Good luck with..."]
Last edited by sajohnson; 05-19-2007 at 10:05 PM. Reason: Misread post, corrected reply
Old 05-22-2007, 12:43 AM   #631
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
I cant seem to get onto tari's site to download. Is it still available? Or does anyone else have it that I may download from? I need to datalog pretty bad. I dont want to tune but my tuner says I need to log whats going on (I am having trouble with my green map)
Sinister redlines is offline   Reply With Quote
Old 05-22-2007, 11:13 AM   #632
Jon [in CT]
Member#: 2992
02 WRX Sedan
His site was down for a couple of days. Try it again.
http://tari.co.za
Jon [in CT] is offline   Reply With Quote
Old 05-22-2007, 11:50 AM   #633
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
http://tari.co.za
Sweet, thanks...
Old 05-28-2007, 03:44 PM   #634
DTwrx
Member#: 119275
02 WRX
PSM, Stg. 2
Originally Posted by sajohnson View Post
rexspeedmaster:
Second question:
i decided to give this a shot today and it worked for me:
- I have the V1 AP cable for my 02/03 wrx. i went to Radioshack and bought their serial-to-usb cable (~$30..could've saved some $$ online but I wasn't feeling patient today..Part Number is 26-183).
- Next I popped in the drivers cd that came with the cable and installed it.
- Connected the AP cable to my ODB-II port, connected the radioshack cable to that and to my laptop (Windows XP)
- Started up ecuExplorer and in the bottom left pane it showed the radioshack cable listed under one of the ports. Right click on this and assign it to 'SSM Diagnostics' or whatever your option is. You're all set. From there its a matter of learning the program, etc.
Keep your eyes on the road
DTwrx is offline   Reply With Quote
Old 05-30-2007, 01:47 AM   #635
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
Thank you DTwrx!
Old 05-30-2007, 03:05 AM   #636
DTwrx
Member#: 119275
02 WRX
PSM, Stg. 2
Thank you DTwrx!
No Prob.
FWIW I got Enginuity to work as well. Basically you do the same thing as above. But along with downloading Enginuity you also download the 'EcuFlash' program and install it (just for the OpenPort drivers, even if you're just logging). Connect everything, go to the logger in Enguity and hit refresh.
This is all very new to me, but I think I prefer Enginuity mostly because in ecuexplorer none of the IAM (advanced multiplier) options gave me a reading, nor did engine load..hmm.
Old 06-14-2007, 08:19 AM   #637
tubbytreats
Member#: 35104
02 WRX TD0518G 7cm
www.daytonsubies.com
Hey folks, I've used ecuExplorer many times before with the Cobb AP cable, but I just got a new Windows Vista lappy (Core 2 Duo 2.0Ghz) and am unable to get ecuExplorer to start the logging process. I AM able to see the "live view" of data from the ECU, and am able to connect without any problems over my USB-to-Serial adapter.
I just can't get ecuExplorer to start logging...set up the "rear defog switch" option, and nothing. I even right-click in the "live data" window and choose "start/stop logging" and get nothing.
Is Vista Home Premium compatible with ecuExplorer? Your help and insight is greatly appreciated.
tubbytreats is offline   Reply With Quote
Old 06-14-2007, 09:07 AM   #638
Jeramie
Member#: 56995
2016 WRX
WR Blue
Hey man, ecuexplorer is dated, actually very dated at this point. You should upgrade to enginuity logger, many many many new features compared to ecuexplorer.
Jeramie is offline   Reply With Quote
Old 06-14-2007, 11:41 AM   #639
tubbytreats
Member#: 35104
02 WRX TD0518G 7cm
Jeramie - Thanks for the tip, I'm gonna try Enginuity 0.4.1b tonight to see what I get. Does Enginuity work with the AP cable though?
Old 06-14-2007, 11:47 AM   #640
Jeramie
Member#: 56995
2016 WRX
WR Blue
Yeah, works the same way ecuexplorer does. The only think you can't do with an AP cable, is flash.
I'm sure once you try enginuity you will be very happy.
Old 06-14-2007, 11:57 AM   #641
Jeramie
Member#: 56995
2016 WRX
WR Blue
Have you checked to see if the default log file location exists in vista. 2ndly when you run ecuexplorer in vista I would make sure you. .. .
"Run As Administrator"
Old 06-14-2007, 03:32 PM   #642
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
Ahhh. Be prepared to find other hardware and software incompatibilities with Vista. That is the main reason that Vista has not taken off and Dell as well as others decided to re-offer WinXp as an OS on their new systems.
DougG is offline   Reply With Quote
Old 06-17-2007, 03:53 PM   #643
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I hate trying search though this whole thread.
OK, for us RS guys. I just want to datalog.
Is this cable ok and what software will work to pull codes and datalog?
Patrick L is offline   Reply With Quote
Old 06-18-2007, 09:25 AM   #644
Jeramie
Member#: 56995
2016 WRX
WR Blue
Only SW I know of (beside cobb) is ecuexplorer. Enginuity AFAIK doesn't do trouble codes.
Old 06-19-2007, 03:15 PM   #645
dudley123
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
Ya.. I need something that does trouble codes for an 06!! Ecuexplorer Doesnt... Anything else that does?
dudley123 is offline   Reply With Quote
Old 06-22-2007, 04:02 PM   #646
tubbytreats
Member#: 35104
02 WRX TD0518G 7cm
Thanks for that tip, I'll have to try it out and let you know how it works for me. Totally forgot about that addition to Vista.
I also had problems getting Enginuity 0.4b to work on either Vista or WinXPPro, it just doesn't recognize my ECU for logging purposes... weirdness. So I'm back to ECUExplorer until I get that sorted out.
Old 06-22-2007, 06:02 PM   #647
Jon [in CT]
Member#: 2992
02 WRX Sedan
If you have a Tactrix/OpenPort cable then I think you can use the free LogWorks program from Innovate Motorsports to read trouble codes via OBD-II protocol. Their website is at www.tuneyourengine.com.
Old 06-26-2007, 06:52 PM   #648
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Link is all fubarred again
Old 07-01-2007, 04:25 AM   #649
06sti-cgm
Member#: 152804
looks nice
06sti-cgm is offline   Reply With Quote
Old 07-01-2007, 08:44 AM   #650
Jeramie
Member#: 56995
2016 WRX
WR Blue
Whats your ecuid? The def could possibly need to be added. A post on the enginuity forum will ussually result in a quick update, but you would need to pull the rom off the ecu and post it (if infact it is not supported).
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
