Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-18-2008, 01:50 AM   #676
ElPaisita's_STI
Member#: 162191
2004 WRX STI
Thanks for the info.
ElPaisita's_STI is offline   Reply With Quote
Old 04-23-2008, 01:32 PM   #677
snake2332
Member#: 173313
2006 WRX Wagon Lmt'd
Urban Gray Metallic
Originally Posted by SSLegacyGT View Post
From the limitless.co.nz website:
"4) serial obdII adapter that will support 10400baudrates, I will post up some circuit diagrams, I have heaps of diagrams.
(just usb cables are supported in EvoScan v2.1 at this stage - support for serial ports will be re-introduced in a later version, as the usb version is far superior.) "
I couldn't get it to work, so I checked back on the website and it looks like only the cable they make or a tactrix cable will work.
Hope that helps!
I got EvoScan v2.2 but can't make it work. Anyone out there have a WRX with a flashed ECU and a tactrix cable and can successfully use EvoScan/STiScan? I want to make some custom gauges for my 7" dash-mounted LCD but can't
snake2332 is offline   Reply With Quote
Old 06-18-2008, 12:06 AM   #678
RSbullet
Member#: 177171
2006 Sti
never tried one, i think i will now.
RSbullet is offline   Reply With Quote
Old 06-18-2008, 11:33 AM   #679
snake2332
Member#: 173313
Urban Gray Metallic
Version 2.3 of the software works for me, so nevermind.
Old 06-29-2008, 07:39 AM   #680
BlueSubaru22
Member#: 179474
08 STi Stg 2
WRB Pearl
will this evoscan work for a 08 STi?
Last edited by BlueSubaru22; 06-29-2008 at 07:40 AM. Reason: Doh...forgot to subscribe
BlueSubaru22 is offline   Reply With Quote
Old 07-21-2008, 01:20 AM   #681
yakkosmurf
Member#: 81931
2008 STI (Stage 1)
WR Blue Mica w/ Gold BBS
I'm wondering the same thing.
yakkosmurf is offline   Reply With Quote
Old 07-27-2008, 09:06 PM   #682
El Capitan
Member#: 121261
06 STG 2+ STi
CGM
It didn't say anything about supporting WBO2s. Am I missing that? Did anyone see it?
El Capitan is offline   Reply With Quote
Old 08-05-2008, 10:39 PM   #683
samj
Member#: 112535
2006 WRX Ltd
Black (OBP)
Like many out there, I had a hard time finding a download link for EcuExplorer. Most threads link to http://www.tari.co.za/blog/2008/05/ecuexplorer-v3025/ but it appears that site is no longer in use.
Finally found out that Calvin has moved his downloadables to Google Code along with the source. http://code.google.com/p/ecuexplorer/
For those trying to get ecuExplorer to work w/ an 06 like I was, this thread is helpful: http://www.cobbforums.com/forums/showthread.php?t=36743
samj is offline   Reply With Quote
Old 08-11-2008, 11:16 AM   #684
toxin
Member#: 51259
2007 WRX
СGM
I just tried to download both versions: 3.0.25 and 3.0.28
Neither one won't communicate with the ECU
Weird thing: I borrowed the laptop from my buddy, and the same s/w worked there like a charm..
Any suggestions or advices how to get mine to work will be appreciated.
I was trying to follow these instructions, but it didn't work for me..
Also, if I can get it to work somehow, how can I log the knock correction data?
The only thing that I can see here is "Knock signal #1" at the bottom of the screen. However, everybody who share their logs here do have the "knock correction" field.
Thanks.
Anton.
toxin is offline   Reply With Quote
Old 08-12-2008, 10:29 AM   #685
samj
Member#: 112535
2006 WRX Ltd
Black (OBP)
What cable are you using?
Are the problems installation related? Does the laptop detect new hardware when its connected to the subie?
Old 08-12-2008, 10:36 AM   #686
toxin
Member#: 51259
2007 WRX
СGM
with either laptop, mine or my friends I use the same cable, which was provided along with the AP.
Both laptops detect the new hardware "Cobb Talk 2.0" The windows control panel says that it works properly.
Still, one laptop can communicate with the ECU, and the other cannot.. ((
Old 08-12-2008, 12:58 PM   #687
samj
Member#: 112535
2006 WRX Ltd
Black (OBP)
If you are trying to run it on XP SP2, check post 169 and 166 on this thread:
http://www.cobbforums.com/forums/sho...574#post545574
Mixed success rate, but if you have nothing to lose except some time, give it a shot
Old 09-10-2008, 10:22 PM   #688
MiracleMan
Member#: 99318
205 wrx
crystal gray
I had some success with the following ...let me explain my scenario.
1. Installed the latest version of Accessport Manager
2. I installed the accessTuner Race software
3. Tried to hook up car via accessTuner....
4. An install for Cobb FU or something came up...(I was like WTF?)
4.5 Cannot connect...blah blah
5. Tried ecuExplorer...no luck...could not connect
6. Found the dongle instructions and latest ecuExlorer.exe file via Cobb website. Followed instructions. No luck.
7. Went to Device manager and noticed Cobb FU thing with yellow question mark
8. Reinstalled driver by pointing to the directory for where the dongle instructions/new ecuExplorer.exe were located.
9. Both apps work now...
good luck
MiracleMan is offline   Reply With Quote
Old 12-11-2008, 04:56 PM   #689
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
canbus help please, with vista any suggestions.
Tuned200 is offline   Reply With Quote
Old 10-19-2009, 10:08 AM   #690
007WREX
Member#: 165518
logger accessport?
007WREX is offline   Reply With Quote
Old 10-19-2009, 10:30 AM   #691
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
Originally Posted by 007WREX View Post
logger accessport?
nice....press 1...
DougG is offline   Reply With Quote
Old 12-20-2009, 08:15 AM   #692
jaimesales
Member#: 218707
2006 WRX SW
hello good days work with windows 7?
my car is a 2006 wrx
Thank you and Merry Christmas
jaimesales is offline   Reply With Quote
Old 02-07-2010, 11:01 AM   #693
subaru01legacy2010
Member#: 237675
2001 Legacy GT
black
niceee
subaru01legacy2010 is offline   Reply With Quote
Old 07-19-2010, 03:46 PM   #694
Bug_i_Sti
Member#: 224598
hey guys ive got the obII scanner from autozone, the cable has more pins than my ap cable.. would it be better to use?
Bug_i_Sti is offline   Reply With Quote
Old 01-09-2011, 05:21 PM   #695
Ezmendriz
Member#: 10747
Cool Nokia N900 Phone logger with ROMRAIDER
Hi guys,
This post is how I manage to assemble the pieces to make a logger for my car.
I own a Subaru WRX 2002 (US) I wish to be able to see some ecu parameters in a screen in a portable solution.
At first (2006) I wish a Linux carputer with a touchscreen, but the HW was expensive and there were no good OS interface.
I could use a laptop but still too big.
Then I discover Nokia tablets.
I owned a N810 that I manage to connect to the car using an adapter and a Tactrix cable. I used this because I tune the car with RomRaider (http://www.romraider.com).
The problem was that the open sourced program was made in java so it was slow and unresponsive.
Anyway, I fell in love with the tablet, so I sold my N810 to get
the N900 phone.
I almost shot myself when I learned that the N900 does not support USB OTG like the N810.
Then MohammadAG announce the USB host mode (H-E-N Thread)I thought that maybe possible so I installed it ( I already have powerkernel).
So I connect my old adapter and yes it work, except for the drivers to the serial port.
I did some digging and found the drivers were compiled for me and come with the installation of the powerkernel46.
They are not loaded by default, but they are available in /lib/modules/2.6.28.10power46.
I needed usbserial.ko and ftdi_sio.ko ( the Tactrix cable use this chipset).
The modules where added to the kernel using the following commands:
Code:
insmod /lib/modules/2.6.28.10power46/usbserial.ko
insmod /lib/modules/2.6.28.10power46/ftdi_sio.ko
The port was mapped successfully to /dev/ttyUSB0 after you enumerate in H-E-N.
Now the Java on the phone part:
I learned in this thread (Java Thread)
that I could run java applications and installing an official java engine from Sun(Oracle).
With this, the application works, but the logger part failed, because of the lack of the librxtx-java library that connects it to the cable.
Here comes the black magic:
After several failed attempts with the libraries from the RXTX site compiled for arm, the libraries were old so they conflicts with the ones in the N900 like libpthread.so,
it occurs to me that the Debian libraries should work. So I download the librxtx-java deb package from the debian libraries for armel in here (Librxtx lib Debian package) and force it in with:
Code:
dpkg --install --force-all librxtx-java_2.1.7r2-4_armel.deb
The reason I have to force it, is because the we do not the java-runtime installed. Perhaps we could install it from the Debian also instead to avoid the brute force.
For some reason, the package install the file in unexpected directories(/usr/share/lib), so I have to move the .so libraries to /lib.
I also copy the RXTXcomm.jar from the debian installation to the lib folder of the RomRaider program.
After I copy the files I unistall the package to avoid the invalid problems with the apt.
Now, I can connect the cable, enable the port using H-E-N and start the java logger program with:
Code:
java -jar RomRaider.jar -logger
I test it with two parameters(manifold relativ pressure and exhaust gas temperature) and get 7-8 refresh per second, in my phone!
More dicussion about it in: http://talk.maemo.org/showthread.php?p=91624
Ezmendriz is offline   Reply With Quote
Old 06-23-2013, 03:06 PM   #696
oasiv
Member#: 303977
Very nice!
oasiv is offline   Reply With Quote
Old 09-18-2013, 07:11 PM   #697
scottcrooke
Member#: 368717
Default wait
im kinda of confused what you are asking
scottcrooke is offline   Reply With Quote
Old 08-07-2014, 12:30 PM   #698
CarbonLip2237
Member#: 398311
02 WRX
Sedona Red Pearl
Has anyone used this since 2005??
CarbonLip2237 is offline   Reply With Quote
Old 04-06-2015, 11:30 AM   #699
Subru28
Member#: 417914
Default Logger
My buddy has messed with one before.
Subru28 is offline   Reply With Quote
Old 07-28-2015, 02:02 PM   #700
Micahwesson
Member#: 416180
I gotta try this
Micahwesson is offline   Reply With Quote
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 06:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 08:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 08:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 09:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 02:17 PM
