Old 05-26-2005, 11:29 AM   #76
willguidry
Member#: 16388
Bevis, as a member of OpenECU, I assumed that was the point of his application.
I'll look into the OpenECU logger.
Thanks
willguidry is offline   Reply With Quote
Old 05-26-2005, 01:42 PM   #77
CMJ
Member#: 39235
Originally Posted by willguidry
Huh...I'm sorry...It's my mistake. I thought when someone puts a feature into the feature notes, it means it's a functional piece of a software package.
*taken from http://www.tari.co.za/products.htm*
Features
Features currently available:
- view saved log files
- view live data
So yeah..... logging isn't too hard to enable in any application. It's like the first thing you learn when coding. If someone could write an application like this, they could have easily included logging like they advertised.
TPIWWL (This Program is Worthless without Logging)
Go back and read it again. You can view any saved csv file that you have captured from a different source. In the future you will be able to capture logs to csv.
Code:
Features in future releases:
- extra analogue parameters
- digital parameters
- ecu type detection
- view diagnostic trouble codes
- logging to .csv file
- logging triggers (full throttle, defogger switch, etc)
- alarms
- data conversions (lambda to AFR, C to F, injector ms to duty %, etc)
- approximate fuel consumption
- data logging templates
- speed optimization
- seperate data grids for logged data and live data
CMJ is offline   Reply With Quote
Old 05-26-2005, 07:52 PM   #78
stircas
Member#: 53886
i love this program. so cool. thats all i wanted is to be able to moniter what the engine was really doing. to who made this you are cool. thank you
stircas is offline   Reply With Quote
Old 05-26-2005, 08:21 PM   #79
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
NOOB HERE. can someone explain to me what are the normal parameters (+/-)for timing, knock correction and lamda. Because I saw some weird numbers. BTW I have cobb stage 1..THANKS and good JOB..
STISTL is offline   Reply With Quote
Old 05-27-2005, 08:31 PM   #80
stircas
Member#: 53886
IAM (should)=16 ingition timing i have max +42.5 min-.5 knock corr# max 10 min 0. dont know if this helps i have vf34 sti injectors up+down pipe no cats tunning cobb vf34 91oct map. but i am running torco mix for fuel now befor my iam was 13. if you have cobb an easy way to get your iam # up is put the fuel econ map in and do the ecu trick works like a charm. sorry i only have min and max but cant watch it when driving. but this program is still great even with no logging. now i have a much better idea whats happening with my car. i dont understand when people talk about being at 20 degrees or 26 or 28 where mine gos up to 42.5 or is that just something with utec?
Old 05-27-2005, 08:51 PM   #81
MRF582
Member#: 48219
. Always drive
the race line .
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
will that work as an alternative cable? i currently don't have a laptop with USB capability so there is no point in buying the cable from tactrix.com. will that ebay cable work to just read from the ECU? i know i won't be able to flash the ECU with that.
MRF582 is offline   Reply With Quote
Old 05-31-2005, 02:55 AM   #82
calvinc
Member#: 73190
2005 Impreza WRX STi
hi,
next release is finished and i'm doing some final testing before releasing it to you all. i'm still not happy with the speed of the interface and i've decided to rewrite the UI in a faster language. i have been using VB6 as the UI development language just because it mean quick development. the communications is all within a C++ dll.
this means no new features after this release until i get the speed sorted out.
it should be up for download by friday.
calvin.
calvinc is offline   Reply With Quote
Old 05-31-2005, 07:23 AM   #83
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
Sounds great Calvin. This is all much appreciated.
Bort is offline   Reply With Quote
Old 05-31-2005, 08:39 AM   #84
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
much appreciated!
Old 06-01-2005, 12:45 AM   #85
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
subscribing...
salaki is offline   Reply With Quote
Old 06-01-2005, 01:59 PM   #86
Zeglus
Member#: 54574
2003 Impreza WRX
WR blue
does anyone know how to get this program to work on a mac, or if its even possible? where can i find a program to let me run .exe files on here?
Zeglus is offline   Reply With Quote
Old 06-01-2005, 02:30 PM   #87
djplayboy
Member#: 72933
MY02 WRX Wagon
:subscribes:
does the current version also read afr readings??? or is that in a future release....
"and no i havent seen it if its already been posted"
djplayboy is offline   Reply With Quote
Old 06-01-2005, 03:02 PM   #88
MK2TMR2
Member#: 18501
1996 Eunos Roadster
R2-Limited
You'll need to use VirtualPC to run .exe files on your Mac.
I emailed asking if there is any plan to make an OS X or Java (.jar) version that will run cross-platorm. I'm looking forward to it if it's in the works.
MK2TMR2 is offline   Reply With Quote
Old 06-02-2005, 02:47 PM   #89
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
Originally Posted by crazymikie
Depends on what that pin connects to in the other car. If there's nothing there, you are probably okay. OBD standard only specifies a few pins, the rest are left for manufacturer use.
What kind of car?
How about a 2002 RS?
or a 1998 Volvo
or a 1999 Subaru Legacy sedan?
Can these all use the WRX cable, or a Cobb AP cable for that matter?
DougG is offline   Reply With Quote
Old 06-03-2005, 08:29 AM   #90
calvinc
Member#: 73190
new version (1.0.39) is up for download. check website for full list of new features. most importantly it now has support for generating your own log files.
i have noticed some problems with the user-interface either being slow or freezing, because of this i am rewriting it in another programming language. if you experience the same problems please email me.
calvin.
Old 06-03-2005, 08:29 AM   #91
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
WOOOHOOOOO!!!!! you the man!!!
but i have the freezing problem
Quack is offline   Reply With Quote
Old 06-03-2005, 08:34 AM   #92
Quack
Member#: 57264
where does the PCI.exe file need to be installed to? the system32 dir or the TARI Racing Software/ DL1 dir?
Old 06-03-2005, 09:45 AM   #93
Rick Schu
Member#: 34661
I installed the latest version but can't get it to log. Live data reads fine. I have the defogger option selected. I installed pci.dll in the same directory as the main software. Is this right? I also get some error message about invalid object names or something when shutting down after trying to log.
Rick Schu is offline   Reply With Quote
Old 06-03-2005, 10:31 AM   #94
Mr Kleen
Member#: 58991
now I have another reason to wait by the mailbox for my accessport!
I'm new to all this ECU stuff, but just the fact that somebody would put all the time in to develop, test, and code something and then just give it away to the community is just hella-cool!
Mr Kleen is offline   Reply With Quote
Old 06-03-2005, 10:52 AM   #95
yobtah
Member#: 48939
Download both "upgrade" files from the website and run them. Take the defaults for the install directories. It should try to install pci.dll in "c:\windows\system32" and the new dl1.exe file in your program directory (probably something like "c:\program files\tari racing software\dl1").
In both cases, if you had the previous version (1.0.33) installed, the installers should ask you about replacing the files. Choose "yes" both times.
yobtah is offline   Reply With Quote
Old 06-03-2005, 10:59 AM   #96
KGreb
Member#: 13463
2012 Chevy Volt
I figured it out - you have to select "defogger switch" under the digital logging items (Live tuning tab) so that the program can know if you are pressing the defogger to log. After that it started writing to files just fine.
KGreb is offline   Reply With Quote
Old 06-03-2005, 11:09 AM   #97
Rick Schu
Member#: 34661
I did check this, but it doesn't log. How did you install the pci.exe update? I installed it to the dr1 directory. Am I supposed to install this to windows/system32 instead?
Old 06-03-2005, 11:15 AM   #98
KGreb
Member#: 13463
2012 Chevy Volt
Execute the two updates - they are self-extracting RAR archives. Let them install in the default directories and it should work.
Old 06-03-2005, 11:58 AM   #99
ahains
Member#: 28823
2004 WRX Wagon
calvin.
Hi Calvin,
Thanks for the update.
You may want to try recompiling your current stuff with the Visual Basic Express beta 2 stuff. It's a free download, so couldn't hurt. I'm not really a VB guy, so I don't know if there is updated runtime stuff or not.. I think I recall seeing it for msvcr*, so it might be better.
I'd go with c#, but I'm guessing you probably don't want to impose the requirement of the CLR
Thanks again!
-Adrian
ahains is offline   Reply With Quote
Old 06-03-2005, 02:28 PM   #100
Quack
Member#: 57264
working for me now, install the files in the default dir
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
