Old 06-03-2005, 09:19 PM   #101
CBoldman
Member#: 11411
I played with this tonight. I love it, I jsut need to get my old laptop back.
To whoever was having problems logging, I found that you need to be in the live tap in order for it to log when you press your cars defog button. Orignally I was in the Log tap and things where not working. Give it a shot,
CBoldman is offline   Reply With Quote
Old 06-03-2005, 10:16 PM   #102
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
it seems that you also have to have the defogger switch logging enabled to us the defogger as a trigger.
Quack is offline   Reply With Quote
Old 06-04-2005, 02:46 AM   #103
CBoldman
Member#: 11411
Good point Quack, this option is available as one of the menu items at the top of the screen and must be turned on to log.
Old 06-04-2005, 07:58 AM   #104
Quack
Member#: 57264
at least for my vehicle, you have to have the defogger switch checked in the "digital"
Old 06-04-2005, 09:15 AM   #105
Rick Schu
Member#: 34661
Got mine working, but having trouble figuring out which one is boost? I logged manifold relative pressure and manifold absolute pressure, but I'm not getting any numbers that look like boost and both are set to psi.
Rick Schu is offline   Reply With Quote
Old 06-04-2005, 09:55 AM   #106
Quack
Member#: 57264
Absolute - Atmospheric = Relative
i think (?) Relative = Boost
Old 06-04-2005, 11:04 AM   #107
methinkadoo
Member#: 37419
i have troubles getting mine to work. it worked for a while, but when i try, it doesn't seem to read the output anymore, it just shows all zeros. before it would show numbers etc etc when it gets connected
methinkadoo is offline   Reply With Quote
Old 06-04-2005, 11:07 AM   #108
calvinc
Member#: 73190
2005 Impreza WRX STi
ok...it seems lots of people are having trouble with getting the latest version installed properly and some logging issues.
install:
download both update files (2x exe files). they have default install paths (C:\Program Files\TARI Racing Software\DL1) and (C:\WINNT\System32). run them and let them install to the default paths. they will ask for confirmation to overwrite the current files - just say yes.
pci.dll (pci.exe) is the communications dll
dl1.exe (dl1.sfx.exe) is the GUI
capture:
you must have the defog switch selected as 1 of your digital data items. this is mentioned in the quick-help on the right-hand side of the screen. you also must have the 'trigger logging on defog switch' checked on the 'capture' menu. once you have both of these done you will be ablet to capture your logs.
i'm dissapointed with the freezing problems. i'll do my best to get next (full C++) version out asap. next version will also only be a single executable so no hassles with silly install programs, etc.
regards,
calvin.
calvinc is offline   Reply With Quote
Old 06-04-2005, 11:26 AM   #109
14.50377
Member#: 59685
2004 Forester 2.5XT
Sleepy Silver
calvinc,
thanks for such a useful and free program. i am glad to see that it works on my Forester XT. all of the parameters i have tried to view work except engine speed. is this an issue with other subaru models/ecu's ?
regarding the photo of the ecu to email, what exactly are you looking for?
14.50377 is offline   Reply With Quote
Old 06-04-2005, 12:20 PM   #110
Quack
Member#: 57264
no freezing on my '04 once i put the pci.dll in the correct directory
Old 06-04-2005, 05:46 PM   #111
phunkdup
Member#: 60719
2004 WRX
Java Black Pearl
Has anyone with a cobb reflash tried this? I'm running the AP stage 2 v1.22 ('04) and the numbers I logged made no sense at all.
phunkdup is offline   Reply With Quote
Old 06-04-2005, 06:05 PM   #112
Quack
Member#: 57264
yep, running the VF30 map
Old 06-04-2005, 06:22 PM   #113
drfrink24
Member#: 36369
2004 WRX STi
Java Black
I'm running AP stage 2 v1.05 on a 2004 STI, my numbers don't make sense either. I did get an error that it didn't recognize the ECU, so, I'm pretty sure that has alot to do with it.
I've followed the correct upgrade directions as well.
drfrink24 is offline   Reply With Quote
Old 06-04-2005, 06:33 PM   #114
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Cobb v1.22 stage 2 mapping used the 05 wrx firmware. So it might be that the logging software does not support that. Cobb has released the new v1.30 maps that use the 04 firwmare for 04 cars (due to stalling issues with the 05 firmware). You might want to upgrade your AP (but don't forget to unmarry first).
ImportVenom is offline   Reply With Quote
Old 06-04-2005, 06:46 PM   #115
Quack
Member#: 57264
i don't think that's an error, it's just that ECU isn't in it's database, so if you click yes, it will create a TXT document that you email him along with a pic of your ECU case.
Old 06-04-2005, 07:31 PM   #116
stircas
Member#: 53886
calvin,
thank you so much this program rocks. just had a guestion is the (iam) selection going to be on the next upgrade? i didn't seee it on this one. but it was on the first release. o and great program. if what they say holds true what gos around comes around then you should have many good things coming your way.
stircas is offline   Reply With Quote
Old 06-04-2005, 08:53 PM   #117
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
i am running the stage 2 on an 04. here is what i noticed. the numbers all look fine except for one thing. if you log engine speed all the information from that grid on need to be moved to the right as the RPMs do not show up anywhere.
try moving reading the data one column to teh right.
other than that, excellent stuf clavin. I think if calvin has a paypal accoutn we should all throw him at least enough for a burger and fries to help him stay up for the next release.
Joe
scoobdude is offline   Reply With Quote
Old 06-04-2005, 09:21 PM   #118
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
Joe
Agreed!
Bort is offline   Reply With Quote
Old 06-04-2005, 11:38 PM   #119
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
maybe I'm an it tool but I have a few questions...
1. I have an ap I can plug the ap plus into the ob port and the other end in my loptop and I'm good to go
2. I'm running a cob stage 2 (version 1.05) is this version not supported yet?
3. Basically I just wanna view my air/fuel and injector duty cycle....this is good for that right?
Thanks...matt
mpower22 is offline   Reply With Quote
Old 06-04-2005, 11:50 PM   #120
ahains
Member#: 28823
2004 WRX Wagon
Joe
+1
Calvin, do you have a paypal account we can send a few bucks to?
I don't even have a cable yet, but I want to support this kind of grass roots activity however I can
-Adrian
ahains is offline   Reply With Quote
Old 06-05-2005, 12:58 AM   #121
electronfrost
Member#: 16242
'08 STi
A friend of mine found this software the other day. He has a Cobb Stage 2 '05 STi (turboback, intake) and I have an '04 STi with just a catback and CAI (I'm installing MRT DP this weekend) and it worked on both of our cars with his AP cable.
I didn't even turn off my car. He just jumped in with his laptop and I plugged it in and drove off. Worked great! The loggin ver wasn't out when we tried but we'll try again in a few days.
We were really comparing Air Inlet Temp. He drove his car around for a while, mixed driving and at an idle for 5 minutes after driving his AIT skyrocketed to 75+ Celcius. We then switched and after driving mine (hard 100+ MPH stints) for about 10 mintes we let it idle. My AIT peaked at 55C...then very slowly dropped...
I'd like to grab my own (very cheap) cable for the time being till I get my AccessPort. Looking at options now.
Calvin,
Where should I send all my money?
EDIT: I'm also curious if a cable like this one on ebay would work if I got a regular serial to USB adapter. I don;t need to reflash. I'll get an AP for that. Unless, that is, I could get a Cobb map to work with a not so cheap cable. lol
electronfrost is offline   Reply With Quote
Old 06-05-2005, 02:23 AM   #122
twg
Member#: 25587
2004 Forester XT
Thanks Calvin...
I dl'ed new version... logging works great...
Only thing I noticed so far after playing with it the first time, when the logging is enabled and i shut down my car, the program goes into an infinite loop with an error of not being able to connect to ECU or something like that..
twg is offline   Reply With Quote
Old 06-05-2005, 07:26 AM   #123
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
Still wondering..
How about a 2002 RS?
or a 1998 Volvo
or a 1999 Subaru Legacy sedan?
Can these all use the WRX cable, or a Cobb AP cable for that matter?
DougG is offline   Reply With Quote
Old 06-05-2005, 08:35 AM   #124
Quack
Member#: 57264
^^^why don't you try it and tell us...
Old 06-05-2005, 12:42 PM   #125
peterex
Member#: 27021
2015 WRX
Thumbs up
Awesome.
Just got this to work with my PowerBook G4 laptop, Virtual PC (running Win 98), AccessPort cable, and $18 USB-to-Serial adapter. Guess I won't be needing DeltaDash now...
peterex is offline   Reply With Quote
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
