Old 06-06-2005, 07:30 PM   #151
Drayton
Member#: 44055
2003 WRX
I compiled graph from the data values from my run last night and this was the result.
I think this software will become a standard piece of equipment before long.
Thanks to this software, I now know that under the type of driving I do 80% of the time, the EGTs generated do not pose an immediate risk of feeding the probe to the turbo. That is peace of mind and best of all, for free.
Drayton is offline   Reply With Quote
Old 06-06-2005, 07:31 PM   #152
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
just hooked my EGT probe back in, will take it for a spin when i go get dinner.
Quack is offline   Reply With Quote
Old 06-06-2005, 07:45 PM   #153
yobtah
Member#: 48939
Don't waste too much time or energy re-installing the stock EGT probe. I've read that it's not very accurate... the ECU simply uses it as an indicator of health of the uppipe cat.
365 is definitely not accurate... no matter if it's Celcius or Fahrenheit (it would be 689 F if it's 365 C). I have an Omori EGT gauge with the probe tapped into the driver's side manifold... I get constant 1200 degree F temps just driving around at 30-40 mph. That rises to 1400-1450 while on the highway. Even when a "real" probe is installed in the uppipe, readings should be higher than 365... typically, they're around 200 degrees F less than at the manifold.
Basically, I wouldn't waste my time with the stock EGT probe.
yobtah is offline   Reply With Quote
Old 06-06-2005, 07:54 PM   #154
Quack
Member#: 57264
i put the probe back in (easy to get to on the Helix UP)
no response until +365. i think my max was 765 on a 3rd gear romp onto the hwy.
Old 06-06-2005, 08:48 PM   #155
yobtah
Member#: 48939
Hmm... if that's Celcius, 765 (1409 F) is relatively believeable for WOT in third. If the "200 degrees F cooler in the uppipe" rule is correct, you'd be around 1600 F in the manifold. It's almost as if the stock EGT probe has really low sensitivity ... you might want to consider a better EGT gauge if the temps you're seeing are close to accurate.
Old 06-06-2005, 09:03 PM   #156
Quack
Member#: 57264
it says F, but i don't think know it it did the conversion.
here are some other temp readings (max) w/ the C to F conversion selected
coolant - 186.8 (seems right)
intake air - 98.6 (seems right)
Fuel temp - 32 (F?)
EGT - 765 (F?)
the last 2 don't seem right
Old 06-06-2005, 09:14 PM   #157
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
very cool, I never knew about this...I will be sure to download it and check it out
Old 06-06-2005, 10:48 PM   #158
CBoldman
Member#: 11411
Maybe I am being stupid, but I am not seeing EGT readings on the list..... Any advice?
CBoldman is offline   Reply With Quote
Old 06-06-2005, 10:55 PM   #159
Zumble
Member#: 34860
2005 Forester CGM
Just did some logging at idle in my 05 FXT. Logged worked great but the log columns are off by two. I think someone mentioned this already.
Zumble is offline   Reply With Quote
Old 06-06-2005, 10:55 PM   #160
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
does this new version show injector duty % if not what is the conversion?
Thanks...
mpower22 is offline   Reply With Quote
Old 06-06-2005, 11:04 PM   #161
Quack
Member#: 57264
exhaust gas temp
think it's near the bottom of the analog parameters.
Old 06-06-2005, 11:05 PM   #162
Quack
Member#: 57264
Thanks...
no,
IDC% = IPW*RPM/1200.
Old 06-07-2005, 12:09 AM   #163
twg
Member#: 25587
2004 Forester XT
Originally Posted by engr
Gtechs work off of a totally different princinple.. they are accelerometer based that detects accel and decl and correlate them to time to give you your distance.. Remember physics class V=d/t?
or d=at^2
f=ma, f is determined by accelerometer... m you know... and a can be calculated... then this a is used in first equation combined with a timing device to determine whether you've got 1320 ft...
With the actual time, velocity data from the ECU, you can determine 1/4 time time, or even come up with a dyno chart...
Power=ForcexVelocity... this can be converted to torque... which can then create hp by the hp=torque*rpm/5252 equation...
that's how the other programs have dyno plots...
Calvin... you listening ?
twg is offline   Reply With Quote
Old 06-07-2005, 12:56 AM   #164
mnavarro
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
Originally Posted by calvinc
1I appreciate all the offers of money, but i cant accept it. just keep on using it and building a support base, thats enough payment.
regards,
calvin.
This guy is seriously cool, I will be up and running on this shortly. Maybe we can add in some other features like the way ecutek on the timing maps color codes where the car is experiencing knock. I know it doesn't have a timing map, but it could generate one from what it's reading? Shoot me if it already does this.
mnavarro is offline   Reply With Quote
Old 06-07-2005, 02:01 AM   #165
CBoldman
Member#: 11411
I am getting some crazy numbers when I log the data. I chose to log all of the analog options. Maybe someone else can analyze my data for me?
http://homepage.mac.com/cboldman/.cv...7s.csv-zip.zip
Old 06-07-2005, 02:16 AM   #166
Drayton
Member#: 44055
2003 WRX
mnavarro, when you say color coded timing map, is that like a 3-D xyz axis thing, or a xy axis thing that relates timing to RPM or timing to knock correction?
Old 06-07-2005, 05:24 AM   #167
calvinc
Member#: 73190
2005 Impreza WRX STi
not all ecu's support the same parameters. do others with the same ecu type as you get the egt data item?
not yet. might add it in soon. need to figure our the rpm address for the cobb users first.
is it not the skewed columns with the rpm data missing - like we've seen on the cobb users?
when we can read out the ecu rom then we can do something like that.
calvin.
calvinc is offline   Reply With Quote
Old 06-07-2005, 06:16 AM   #168
Quack
Member#: 57264
here's my log file. i'm running a 2004 Wagon (w/ 2005 ECU) VF30 w/ Cobb AP.
this is also before i re-installed my EGT probe
http://www.wrxfanatics.com/index.php...post&id=434524
and with the EGT probe installed:
http://www.wrxfanatics.com/index.php...post&id=435651
Old 06-07-2005, 08:23 AM   #169
KGreb
Member#: 13463
2012 Chevy Volt
From your profile, you have a USDM STi. Your car does not come with an EGT sensor, so the ECU is not programmed to display a value. In general, the EGT sensor is only found on the cars with a cat in the up-pipe, like the WRX, FXT, LGT, etc.
KGreb is offline   Reply With Quote
Old 06-07-2005, 11:31 AM   #170
mnavarro
Member#: 51537
2004 WRB WRX STI
When I was getting my ecutek tune, the timing map was color coded where knock events where happening from blue (good), green(ok), yellow,red (knock). What's cool about it is you get to see visually where the knock is happening. The tuner just goes to those cells where they're red and takes a few degrees of timing out.
My idea because we don't have access to the timing map directly from the software:
Let the software do a rough map of timing over engine load, building a map as it goes. When knock events happen it shows them in a graph, making it easier to see where areas of the actual timing map need to be tuned. Maybe, the same thing with AFR and boost. It's nice because in one quick glance you know where your problems are at.
Old 06-07-2005, 11:44 AM   #171
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Will this cable plus the home made interface that's linked in that page work? sorry if I'm wtlw
http://www.obd2cables.com/products/index.php
Undepelo is offline   Reply With Quote
Old 06-07-2005, 12:34 PM   #172
Drayton
Member#: 44055
2003 WRX
So basically one could make a line graph using timing, knock correction, and/or the knock sensor digital parameter. To use the resulting graph like you're wanting to use would mean trying to do a 3rd gear wrx or 4th gear sti pull as smoothly as possible, right? The way I understand it, the digital knock parameter is like 0=no knock and 1=knock. So you could make a two axis RPM vs Timing graph to get a feel for what the timing does at a certain RPM, and make a timing vs digital knock parameter and be able to tell where knock happened at a certain timing point? <-- Knowing from the previous graph where in the RPM range that knock occured.
I like your way better, sounds much slicker, but do I have the concept?
Old 06-07-2005, 12:57 PM   #173
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
No - that is just a wiring adapter cable without any electronics. I sell a USB one at
tactrix.com
or there are other kits like this which will probably work:
http://www.andywhittaker.com/ecu/obdii_hardware.htm
colby is offline   Reply With Quote
Old 06-07-2005, 01:03 PM   #174
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
tactrix.com
What I ment was the wire in the link PLUS this:
http://www.planetfall.com/%7Ejeff/obdii/
Old 06-07-2005, 01:13 PM   #175
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
that should work if you get the pinouts right.
Does ANYONE make a free flasher/logger for Pre-2001 subie ECUs? kaisersouse General Community 2 09-23-2009 05:38 PM
free data logger 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-18-2008 07:44 PM
!!FREE!! Subaru Leather Sedan Interior !!FREE!! xcntrk75 MAIC Private Classifieds 10 11-12-2007 07:17 AM
New Issue of Subaru Drive Magazine Available Online - Free Subaru Safety DVD Offer Jon [in CT] News & Rumors 16 05-19-2006 08:38 PM
Free Subaru Bigred14 Texas Impreza Club Forum -- TXIC 11 02-08-2002 01:17 PM
