05-21-2005, 10:56 PM | #1 |
Member#: 38228
Vehicle:2003 WRX WGN SNC YLW W/// Edition |
Burnt out Passenger bulb in less than a day Morette
Hello, I have an issue that I can't seem to figure out. I have a set of morettes and i seem to be burning out passenger side bulbs faster than I can put them in. Thankfully I have only been paying $3.00 a piece for these. Yesterday I put a new bulb in drove an hour and it was already burnt out. Make sense? I have had the morettes installed for over a year now. I am using a generic super blue bulb but these same bulbs have lasted others 2 or 3 years even more.
Thanks for anyones help or ideas in advance
05-22-2005, 04:53 PM | #2 |
Member#: 38228
well no one has ideas?!
05-22-2005, 08:55 PM | #3 |
Member#: 74588
NESIC
Vehicle:07 Camry XLE /08 Honda Pilot |
I would check for an open wire in the harness, or check the socket itself for the bulb thats blowing. Your going to need to dissassmble the headlight either way. Make sure your using a good Volt meter to test the wiring. Finally, are you handling the bulb properly when you install it? Don't touch the glass....
05-22-2005, 09:42 PM | #4 |
Member#: 38228
Yes I am handling the bulb properly. and all the fuses are good... so that pretty much leads me to taking it apart...
05-23-2005, 04:01 AM | #5 |
Member#: 81042
Vehicle:2000 5 door turbo Silver |
You could try a different bulb supplier. If the manufacturer has made a bad batch, they will all be in the same box at the same store.
Check the electrical plug that goes onto the bulb. I assume it's the H4. The connectors should float in the holder to allow them to line up without staining the bulb. If they are too tight, they can cause bulb failures. John |
05-31-2005, 02:25 AM | #6 |
Member#: 38228
its actually h7 and and my h1 high beams same bulb manufacturer have been in for over a year
05-31-2005, 09:30 AM | #7 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
If there is a seperate relay for each light perhaps the relay is the cause of this problem and replacing it will fix it. Can't expain why though.
Clutch worn out twice in less than a year | Spida | Transmission (AT/MT) & Driveline | 25 | 01-08-2007 11:38 AM |
Less Than One Day Left On This 419whp Sti On Ebay!!!!!!! | sticrazy | Private Vehicle 'For Sale' Classifieds | 0 | 09-18-2006 10:43 PM |
From hired to fired in less than a day!! | kbcr3 | Off-Topic | 33 | 07-13-2006 12:55 PM |
FS: Stock 03 WRX headlights used less than one day | johnalla0 | Private 'For Sale' Classifieds | 10 | 05-18-2004 03:37 AM |
FS: Stock 03 WRX headlights used less than one day | johnalla0 | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-17-2004 11:33 PM |
