Old 05-22-2005, 05:06 AM   #1
04stilin
Member#: 61783
'05 WRX STi
CGM
Default High Coolant Temp
I just finished porting my turbo. I went on a drive afterwards and my coolant temp. maxed out after about 10 mins. of easy driving. Everything is back in place except the heat shield, would this cause my temp. gauge to read high.
04stilin is offline   Reply With Quote
Old 05-22-2005, 05:51 AM   #2
garie
Member#: 26607
2002 wrx wagon
did you forget to put the coolant hose back onto the turbo? Did you leak alot of coolant when taking taking the turbo off?
garie is offline   Reply With Quote
Old 05-22-2005, 05:56 AM   #3
04stilin
Member#: 61783
'05 WRX STi
CGM
The coolant lines are in place and yes it leaked alot of coolant, about two 16 oz. bottles worth.
Old 05-23-2005, 01:13 PM   #4
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
I'd bet you have an air bubble in the coolant system.
Alan is offline   Reply With Quote
Old 05-24-2005, 06:35 PM   #5
TurboCharged97L
Member#: 71508
1997 Impretzia
Artic Silver Metallic
make sure all the air is out of the system, then after that is done add some more coolant with a nice bottle of water wetter. its a great product and maybe for 60 bucks invest in a low temp thermo
TurboCharged97L is offline   Reply With Quote
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Factory 2.5L Turbo Powertrain 2 03-05-2010 03:25 PM
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Electrical & Lighting 1 02-14-2010 12:58 AM
High Coolant temp w/ Heater on? Beam Factory 2.5L Turbo Powertrain 10 03-11-2009 06:43 AM
High Coolant Temps. 2TG8V South West Impreza Club Forum -- SWIC 5 05-10-2006 04:19 PM
Help!...High Coolant Temp. 04stilin Newbies & FAQs 7 05-22-2005 06:02 PM
Message Board Statistics All times are GMT -4. The time now is 04:37 PM.
