Old 05-22-2005, 11:22 AM   #1
Godmal
Member#: 4934
2007 White STI LTD
Grey Mazda 5
Default WRX EJ20 into 99 legacy
Is this swap possible? The car I might be buying has an automatic; do all of Subaru's tranmsssions have the same bolt patterns? I'd like to be able to just swap in the motor, not have to change the trans.
TIA
Godmal is offline   Reply With Quote
Old 05-22-2005, 02:04 PM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Of course its possible, same as the GCs I have an EJ20 in my 98 Legacy, swaps in like Legos. As for the transmission, it will mate to an EJ20 but are you sure youd want to????
xcntrk75 is offline   Reply With Quote
Old 05-22-2005, 02:29 PM   #3
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
you are gonna have some headaches trying to run your stock auto TCU with a wrx ecu i think.
Ben
Old 05-22-2005, 10:49 PM   #4
Godmal
Member#: 4934
2007 White STI LTD
Grey Mazda 5
That's nice to know. As for the trans, I'll take one headache at a time. If the TCU and the ECU can't get along, then I'll look into the 5mt swap. Thanks for the info guys!
Old 05-22-2005, 10:58 PM   #5
Kraziken
Member#: 38629
1999 Legacy GT (STI)
I have a EJ20 I'm about to put into my '99 Legacy.
Although my legacy is a 5 speed. My mechanic said the WRX 5 speed is stronger, and is a different type (push, or pull I can't recall the difference).
That, and also the fact that when I ordered a heavy duty clutch, Rallitek gave me one that works with the WRX, not my current tranny. Instead of sending it back I decided it be better to just get the WRX tranny.
Food for thought.
Kraziken is offline   Reply With Quote
Old 05-22-2005, 11:41 PM   #6
napphappy
Member#: 56170
95 Impreza L
Ugly
you will have to get a wrx rear end as well. the gear ratios are different.
IMO I would stick with the legacy 5MT. Lower gears=quicker
napphappy is offline   Reply With Quote
Dome & Map Light problem after 02 wrx radio into 99 Legacy moogoob Car Audio, Video & Security 5 09-01-2013 10:08 AM
Swap Wrx Motor Into 99 Impreza Scottylack Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-14-2008 06:55 PM
96 tt motor into 99 legacy gt help Met202 Newbies & FAQs 0 08-26-2008 08:40 PM
semi newb-wrx longblock into 99 2.5 Tigris Normally Aspirated with bolt-on Forced Induction Powertrain 2 11-14-2005 10:58 PM
WRX shifter into 99 RS? NimrodBoz Transmission (AT/MT) & Driveline 1 07-06-2003 10:00 PM
