Old 05-22-2005, 04:17 PM   #1
turfshark
Member#: 86273
05 wrx
"dirty" black
Default Probs with Cobb AP Map Manager
just bought a used cobb ap for my 05 wrx.
the first thing i did was connect it to my pc to download some maps. it syncs fine with the 1.3 version of mm and will not recognize it with the updated 1.6.
anyhow, i wanted to put some maps that i downloaded from the website onto the unit (specifically 91 oct ca base map) but when i try to import the map it says "file error: could not read map data from file."
any ideas?
turfshark is offline   Reply With Quote
Old 05-23-2005, 12:47 AM   #2
AdmiralWRX
Member#: 80204
2005 WRX++
Read these instructions:
AP Upgrade Instructions
You need to upgrade your AP before you can use any of the current maps on the Cobb's site.
From Cobb's website:
2004-2005 WRX AccessPORT Update (2/16/05)
Before using the new Map Manager, you will need to first have your AccessPORT upgraded to the latest software which includes the ability to properly report the VIN number on 2005 vehicles. The 2004 models did not support this option, however additional updates have been made to the map files which require all 2004-2005 owners to perform this upgrade.
AdmiralWRX is offline   Reply With Quote
Old 05-23-2005, 10:32 AM   #3
turfshark
Member#: 86273
05 wrx
"dirty" black
thanks, will try that tonight.
Old 05-23-2005, 10:50 PM   #4
turfshark
Member#: 86273
05 wrx
"dirty" black
updated and worked beautifully. Thanks Admiral!
Boost Spiking Using After Changing Maps with Cobb AP (kind of long) Gray_Scale AccessPort 2 07-03-2006 01:08 PM
Boost Spiking After Changing Maps with Cobb AP (kind of long) Gray_Scale Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-03-2006 01:04 PM
Modified Injectors with Cobb AP Base Map 2.5 wrx904 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-08-2005 03:59 PM
COM2 line command for new ap map management hondaeater69 Engine Management & Tuning 0 02-13-2005 01:02 PM
Cobb AP Map Manager <help> QKWRX Engine Management & Tuning 3 09-10-2004 01:18 AM
