Old 05-23-2005, 06:37 AM   #1
WRXlerate
Member#: 47725
02 STi Wagon
Default 97 JDM sti swap in 97 impreza CEL flashes, won't hit full boost HELP
I did a 97 JDM sti swap into a 97 impreza. The check engine light is flashing and the car will not hit full boost. It runs fine, like there is nothing wrong, but it will only boost 10psi. I need help if anyone has ANY ideas. Thanks.
WRXlerate is offline   Reply With Quote
Old 05-23-2005, 09:37 AM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
What "code" is it flashing ? Count the short blinks/long blinks.
Ver.III is offline   Reply With Quote
Old 05-23-2005, 01:20 PM   #3
WRXlerate
Member#: 47725
02 STi Wagon
It is not flashing a particular code. It just keeps flashing. It would be one short blink over and over. I tried to have it read on a diagnostic computer and it says there is nothing wrong. I tried resetting the ecu several times, no luck. I am stumped...
Old 05-23-2005, 02:22 PM   #4
Randoramma
Member#: 60649
00RS EJ205 swap
misfiring?
Randy
Randoramma is offline   Reply With Quote
Old 05-23-2005, 03:42 PM   #5
WRXlerate
Member#: 47725
02 STi Wagon
No, it runs fine, gets normal gas milage. Just won't hit full boost and cel flashing. I tried a manual boost controller but the ecu wasn't compensating properly so it was detonating. Please help. Thanks.
Old 05-23-2005, 04:02 PM   #6
Randoramma
Member#: 60649
00RS EJ205 swap
Sorry man, I could help you if it was USDM, if you could get a code read.. but dont think so on JDM.
Randy
Old 05-23-2005, 04:16 PM   #7
WRXlerate
Member#: 47725
02 STi Wagon
Yep, I tried to get it read on a diagnostic machine and had no luck.
Old 05-25-2005, 01:06 PM   #8
kingsubi
Member#: 19239
2011 WRX
You need to read the code as it is OBD1 by combining the two connectors under the dash.
Flashing does not necessarily mean bad but maybe urgent - anything from 02 sensors to AFR to high.
kingsubi is offline   Reply With Quote
Old 05-25-2005, 05:54 PM   #9
WRXlerate
Member#: 47725
02 STi Wagon
Thanks. When I had it read we tried to read it OBD2 and it didn't read anything was wrong. I'll give it a try.
Old 05-25-2005, 05:56 PM   #10
WRXlerate
Member#: 47725
02 STi Wagon
Kingsubi, would you know which O2 sensor that engine uses???
Old 05-25-2005, 07:29 PM   #11
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
although i'm not sure about the jdm stuff.. the US stuff, the CEL will flash when there is a misfire above 50% for a certain period of time.. But since its running ok, i'm not sure what else would cause that.. unless something went whack in the wiring.
subbyspeed is offline   Reply With Quote
Old 05-26-2005, 12:07 PM   #12
kingsubi
Member#: 19239
2011 WRX
Should be a three wire one, get a universal one - it will work.
Not sure how did your wiring. Did you have the complete jdm one? or did you splice the wiring harness in at the ecu??
OBD1 is really good in comparison to the newer OBD2 b/c of many early warning signs built in.
Check out this site:
http://bbs.legacycentral.org/index.php
They all deal with EJ20G engines as well and you find info on replacement parts & how do check CELs
Old 05-27-2005, 04:11 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Are the green plugs under the dash connected together? This will activate a diagnostic mode where the CEL flashes constantly among other things. Look under the driver side dash, if you see two green plugs connected unplug them.
Old 05-31-2005, 12:30 PM   #14
Ver.III
Member#: 1185
I flap my gums
If the CEL is flashing all the time, that means you grounded the read memory wire and the car is in "test mode". That probably explains why you can't get full boost
Car won't hit full boost with or without reflash... apgarabu Open Source Reflashes 25 09-04-2009 09:00 AM
car won't hit full boost..... apgarabu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-25-2009 05:04 PM
Jdm Sti Swap in 2002 Wrx kpmatt00 New England Impreza Club Forum -- NESIC 21 09-25-2006 08:31 AM
Not hitting full boost help AshyLarry Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-15-2006 08:39 PM
Tech article on my USDM 2.5RS -> JDM STi swap in HCI magazine Kotir Subaru Conversions 9 06-22-2005 03:05 PM
