Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 05-23-2005, 11:16 AM   #1
bhall
Member#: 56015
No you're a towel!
Default Can I go with a 215?
So time has come for some new rubber. I want to know if I can sneak a 215 on the stock wheels. I am sitting on whitelines and Gr2's so I am a bit worried about rubbing. I currently have 205/55/16's so I guess I am looking for a bit wider but if I risk rubbing not really worth it.
Also, any tires you like over others? I don’t want to spend a fortune but would like something nice.
bhall is offline   Reply With Quote
Old 05-23-2005, 11:25 AM   #2
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
I'm running 225's on stock suspension, but there looks like there's plenty of room. IIRC, DLC is running 225's w/ TEIN HA's. omahasubaru also runs 225??
razor edit: sorry, I'm talking 17's here. I just read you were talking 16's. won't you need 16x7's for 215's?
iamrazor is offline   Reply With Quote
Old 05-23-2005, 11:28 AM   #3
bhall
Member#: 56015
No you're a towel!
This is what I hope you guys can tell me Just want to try and get the wider rubber in there but it would suck to buy new tires and have them get trashed cause of some rubbing.
Old 05-23-2005, 11:55 AM   #4
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
I think you will have more of an issue with your wheels not being wide enough rather than the tires themselves rubbing. Lots of people are running 215s, just on 7" wide rims, and with an acceptable offset.
Jared
gtwagon941 is offline   Reply With Quote
Old 05-23-2005, 12:21 PM   #5
bhall
Member#: 56015
No you're a towel!
how wide are the stockers?
Old 05-23-2005, 12:27 PM   #6
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
6.5 inches
Old 05-23-2005, 12:35 PM   #7
bhall
Member#: 56015
No you're a towel!
so 6.5 will crown the 215's?
Old 05-23-2005, 01:24 PM   #8
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
are you talking like a 215/50-16 or something else? you also might want to check the tire+wheel forum. I'm positive someone will know for sure there. I'm guessing its a no-go, but I've been wrong in the past. what wheels do you have now? you might be able to sell what you've got now to offset the cost. That's what i did. I sold some RS wheels + tires and bought 17" Rotas w/ decent 225's already mounted + balanced...
Old 05-23-2005, 01:41 PM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
Guys are running 225's on their WRX stock wheels so the same will work on yours however you will be pinching the tire a bit if you use a 225. 215 should be fine. Honestly though I'd just stick with a 205 but get a fatter tire like Falken Azenis Sports (RT-215?), or Kumho Mx or something like that. There aren't a whole lot of tires in good 215 sizes and they are not really noticeably wider than a 205 IMO. Unless you are going to a 225 I wouldn't bother. As for rubbing you will be fine with anything up to a 225. I've had 235's on my car with no rubbing but those were 17's and a wider wheel and more positive offset.
tora is offline   Reply With Quote
Old 05-23-2005, 01:54 PM   #10
bhall
Member#: 56015
No you're a towel!
I am running stock "snowflakes" 16 inch dont know the offset? Well I guess I will stay with a 205/16 any good reason to go 50 or 55?
Old 05-23-2005, 01:56 PM   #11
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
You can run a 225/50-16, but it will be sluggish somewhat due to the pinch.
You'd be best to find a wide 205/55 that will fit your needs. Nothing in 215 will keep your gearing right, but you could try a 215/50 if you can find one (still shorter than stock diameter.
You'd greatly beneifit from considering different wheels (wider) that you can fit more tire on and putting some snows or all-seasons on your stock wheels for the winter months. If you don't get snow or don't want two sets, then get some other wheels & tires and sell off your stockers.
omahasubaru is offline   Reply With Quote
Old 05-23-2005, 02:09 PM   #12
tora
Member#: 5851
09 Forester XT
+ NA Miata
For 16x7's see if you can find someone with the 98-01 RS wheels that would be willing to trade with you. Or buy a set of them, they are 16x7 and work well with a 225/50.
Old 05-23-2005, 03:05 PM   #13
bhall
Member#: 56015
No you're a towel!
Thanks for the help guys. I am off to the tire store to check out my options. Dont know if I can go the new wheel route as I am currently selling my house, tring to buy a new one, just got the wife a new car and have a 2 year old Maybe in 6 months or so.
Thanks again!
Old 05-23-2005, 03:51 PM   #14
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
check out tirerack.com too
Old 05-26-2005, 08:09 PM   #15
Teh Legacy
Member#: 9853
to keep your mouth
shut.
I'm running 225 / 45 / 17's on lowered suspension and have plenty of room -- no rubbing whatsoever. You'll be fine.
Teh Legacy is offline   Reply With Quote
Old 05-27-2005, 02:59 AM   #16
LegacySTI
Member#: 86621
95 If it brakes
Mod it
Yokohama makes the prada in a 205/40R-16 and 205/45R-16. With these you dont really need to go wider because they're hardcore cornering tires so you'll have more traction than 215 stockers
LegacySTI is offline   Reply With Quote
Old 05-27-2005, 05:50 AM   #17
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
+1. Don't shortchange yourself - I went this route, along with H&R springs and GR2's, and everything fits just fine. Oh yeh, and the car TURNS so nice, now!
EDIT: Line removed because I'm an idiot and can't read!
Re: Wheels maybe later - It's worth the ~$350 now. I've had too many times where I wish I'd bought the right stuff the first time around, and wound up spending more because of it. If you're ever going to go to the 7" wide wheels, I recommend finding a way.
LetItSnow is offline   Reply With Quote
Old 05-27-2005, 10:25 AM   #18
bhall
Member#: 56015
No you're a towel!
Thanks for the replies guys. I will check out the 40s and 45s but I fear they will look really small in a 16 and will be big trouble with the Colorado pot holes.
As far as the new wheels go I am all for it but finding some in that 350 range is going to be hard. I dont have an extra set so I would have to find someone local to swap with so I dont go with out wheels. Over all I think the benifit for me does not out weigh the time and money needed. I would love to think that I would be racing or auto crossing but mostly I just sit in bumper to bumper for 2 hours a day at 30 MPH so most tires can handle that I think
How much are you guys spending on decent rubber? It seems for the crappest tires out that 500 seems to be the starting point.
Old 05-27-2005, 10:28 AM   #19
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
you could always look for a set FS (wheels w/ tires). sure, you might not get exactly what you want, but its cheaper than buying both new. then you can sell what you have to recoup some of the expense. or, use the stockers for snow tires...
Old 05-27-2005, 10:31 AM   #20
bhall
Member#: 56015
No you're a towel!
<--- Heads to FS forum
Will almost all wheels bolt up (IE wrx, older legs, ect)
Old 05-27-2005, 10:37 AM   #21
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
all but 05 STI!
not sure about SVX wheels though.
if you want to stay 16" then here's my idea:
winter :stock WRX wheels (cheap and i dont think they look too bad)
summer: any RS wheel so you can run the 215 tire (not sure 225's fit on it)
although for the cost of the RS wheels you might be able to get some 17" Rotas. not sure how dead set against going to 17's you are.
oh, if you haven't changed your front brakes then you can even run a 15" steelie.
Old 05-27-2005, 10:57 AM   #22
bhall
Member#: 56015
No you're a towel!
Ok so no wheels in the FS forum. Are the RS wheels 17's or just 16x7 as opposed to 16x6.5 on the leg.
Come on Tora hook a brotha up. I know you got day of the week wheels, you can go with out a new wheel for Wednesday or something.
Old 05-27-2005, 10:57 AM   #23
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
Originally Posted by LetItSnow
My Dunlop Sport 9000's say right on the sidewall not to mount them on 6.5" wheels... do what you like, but I'll pass.
Are you sure it doesn't say not to mount them on 16.5" wheels?? My Dunlop sp5000s say that on them. Not 6.5" but rather 16.5".
/back on topic.
Jared
Old 05-27-2005, 11:16 AM   #24
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
RS wheels are 16x7
Old 05-27-2005, 11:16 AM   #25
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
What size tires are you talking about, and what kind of use?
Kumho Ecsta 712's, which are arguably the best "cheap" tires available, can be had for $68/ each in 205/55/16. I just put a set of stock-size BF Goodrich G-Force Sports on the Leg Wagon; those were only $77 each.
--If you're interested in a wider than stock tire, you can't really go wrong stepping up to a 16x7, or better yet, a 17x7 or 17x7.5" wheel. As mentioned, just put some snow tires on your stock wheels.
--If you need more tire recommendations, you should really spend some time in the Wheel & Tire Forum, as every option has been discussed already.
-Brian
KD7000 is offline   Reply With Quote
How low can one go with a WRX/STi jdmhebek9 Brakes, Steering & Suspension 22 07-02-2004 10:23 PM
how many km can u go with 1 tank of gas in ur sti??? ThEdOg Vancouver Impreza Club Forum -- VIC 15 04-10-2004 03:11 PM
How tall can I go with snow tires on 2000? Mx5racer Legacy Forum 4 12-21-2003 09:37 AM
How far can you go with NA EJ25? Cusco Normally Aspirated Powertrain 14 02-18-2002 03:02 PM
Message Board Statistics All times are GMT -4. The time now is 01:07 AM.
