Old 05-23-2005, 11:29 AM   #1
Kensubguy
Member#: 84082
Default Oxygen sensor
I aim to change the Oxygen sensor in my 99 subaru legacy. Is this a hard job and can someone guided me arround to it. If it is doable I aim to get to it this comming weekend
Kensubguy is offline   Reply With Quote
Old 05-23-2005, 12:07 PM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Front or rear?
If it’s the stock original and has been there a while, I would crawl under there a couple days prior and spray the bung down with liquid-wrench or other type of loosener product. Spray it down one day, drive around, spray it down the next day, drive around, and then change it out. Stripping the bung can commonly occur especially with an old rust-welded sensor.
When replacing, you may want to apply a thin layer of anti-seize in case it every needs to come back out again in the future (i.e. exhaust upgrades).
Good luck
xcntrk75 is offline   Reply With Quote
Old 05-23-2005, 03:22 PM   #3
Kensubguy
Member#: 84082
Originally Posted by xcntrk75
Front or rear?
Good luck
I want to chnge both. Where exactly are they located and is it one of those jobs like changing plugs and wires. I have no clue where to find it but from your reply I figure it is on the underside of engine.
Old 05-23-2005, 03:51 PM   #4
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
They are both located in the cat on the exhaust system. They are screwed into bungs. Access can be tough sometimes and you want to be careful not to strip the "nut" part of the sensor using a crescent. Either a socket made for o2 sensors or a large open end wrench.
Jared
gtwagon941 is offline   Reply With Quote
Old 05-23-2005, 04:09 PM   #5
Kensubguy
Member#: 84082
Jared
I see that there is BOSCH O.E. TYPE and BOSCH UNIVERSAL the universal is cheaper. Is there any diffrence? should I buy one over the other.
Old 05-23-2005, 04:44 PM   #6
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Why don’t you just buy a factory replacement part? You can probably get them in stock from a dealer or save your self some pennies and buy online but wait 1+ week for shipping…
http://www.1stsubaruparts.com/
http://www.subaruparts.com
Old 05-23-2005, 09:39 PM   #7
kpalena
Member#: 82431
2006 06 wrx limited
CGM
I just want to reierate how important it is not to force the old ones out. If you strip the threads in the bung you are s.o.l and will have to find a good machine shop. Be careful. Also, if you are a do-it-yourselfer like me, invest in a chiltons manual. It pays for itself every time you fix something yourself.
kpalena is offline   Reply With Quote
Old 05-23-2005, 10:04 PM   #8
mattyg41383
Member#: 87308
2007 Legacy GT
Definately spray it several times before attempting to remove. Ive even heard of them breaking on the way out, and thats a whole new can of worms. But it shouldnt be that difficult if its not rusted on.
mattyg41383 is offline   Reply With Quote
Old 05-23-2005, 10:38 PM   #9
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
The OE type will have the proper connector, all ready to plug right in.
The universal ones come with bare wires & sometimes an assortment of connector options. You'll probably need to re-use your old connectors, which will involve soldering and heatshrinking if you want to do it right. (wire nuts/ crimps/etc. are crappy & unreliable).
Just buy an OE set, or order the pair from a dealer / parts place. Keep in mind the front and rear sensors have two different part numbers, and they have different connectors. (at least that's how it is was on my old '97)
-Brian
KD7000 is offline   Reply With Quote
Old 05-24-2005, 06:56 AM   #10
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
definately buy the OE type or go order one from subaru. The white and "gray" wires looked the exact same to me on the universal sensor and it made wiring a PITA...I wired the white and gray backwards and had to go back and redo everything, so as usual, something simple took twice as long as it should have.
Perdue is offline   Reply With Quote
Old 05-24-2005, 08:11 AM   #11
Kensubguy
Member#: 84082
I am nervous about it all over a sudden. I hope all goes well with this but I am worried. I will work on it though and thanks all for joinning me on this project. I ought report back on this project to all here. Again thanks
Front Oxygen sensor AKA air/fuel sensor swap out Peaty Tribeca Forum 0 02-20-2010 04:36 PM
2007 STi Rear Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 3 02-19-2009 11:49 AM
2007 STI Front Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 0 02-13-2009 02:16 PM
oxygen sensor vs air/fuel sensor paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-02-2008 01:09 PM
FS: Front oxygen sensor 04 WRX 02 sensor Chino Bling Engine/Power/Exhaust 4 11-20-2007 11:56 PM
