Old 05-23-2005, 07:08 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Exclamation Clutch & Flywheel FAQ: Read if you are thinking of buying them!
Clutch FAQ
What is some good background clutch information?
http://auto.howstuffworks.com/clutch.htm
This link is to a Toyota clutch tech article that is applicable for general knowledge.
The first impulse when clutch shopping is to get "too much" clutch. This is often a very big mistake, as there will be compromises in the different types and compositions of clutches.
Clutches hold Torque, not Horsepower:
Most performance enthusiasts relate more to horsepower numbers rather than torque, but clutch capacity is measured in terms of torque. Think in terms of a high rpm 250 HP Honda Civic versus a 250 HP Ford Powerstroke turbo diesel. The truck will need about three times the clutch capacity because the engine produces about three times the torque.
Choosing what’s best for you:
It may be difficult to know what clutch is right for a particular application since there are so many different levels of personal tolerance and many variations in design. Some people can tolerate clutch chatter, or noise, or heavy pedal effort, or shorter clutch life, higher cost, or other trade-offs. But why tolerate unnecessary issues if you don’t have to? Get the clutch that suits your needs.
What are the various clutch materials? Other than unique or specialized compositions, clutches are generally comprised of:
1. Organic
2. Kevlar
3. Ceramic
4. Feramic
5. Carbon (initially invented in 1998 by Alcon Components for the Subaru World Rally team )
6. Sintered Iron
Depending on manufacturer specifications, this list also shows the general order of the amount of force the clutch materials can hold.
Organic: Metal-fiber woven into "organic" (actually CF aramid with other materials), original-equipment style. Known for smooth engagement, long life, broad operating temperature, minimal-to-no break in period. Will take hard use, somewhat intolerant of repeated abuse (will overheat). Will return to almost full operational condition if overheated. Material is dark brown or black with visible metal fibers.
Kevlar: High-durability material more resistant to hard use. Engagement is similar to organic, but may glaze slightly in stop and go traffic, resulting in slippage until worn clean when used hard again. Higher temp range in general, but can be ruined from overheating; will not return to original characteristics if "cooked". Material is uniform yellow/green and may look slightly fuzzy when new.
Ceramic: Very high temperature material. Engagement is more abrupt. Will wear flywheel surface faster, especially in traffic situations. Due to it’s intrinsic properties, ceramic has a very high temperature range. Material is any of several light hues - gray, pink, brown.
Feramic: This unique clutch material is one that incorporates graphite and cindered iron. The result is a friction material that offers good friction coefficient, torque capacity, and smoothness of engagement.
Carbon: Very high temperature material. Engagement is more abrupt. Will wear flywheel surface faster, especially in traffic situations. Slightly more durable and flywheel-friendly compared to other aggressive clutch materials. Material is black.
Sintered Iron: Extremely high temperature material. Engagement is extremely harsh and is generally considered an “on/off switch” both due to it’s characteristics and the clutch types this material is generally associated with. It requires a special flywheel surface. Material is metallic gray in color.
What is a dual friction clutch? A dual friction clutch is when two different friction material facings are applied to each side of the clutch disk. For added performance and service life, Kevlar is added to the pressure plate side of the clutch disk and the other side remains organic. For street and strip, a dual friction disk is often a combo of Kevlar and metal. The one flaw in this logic is that your overall holding power is then limited to the weakest holding material.
Which clutch material is right for my car? This depends on your configuration and the manufacturer's specifications. Each manufacturer has their own "recipe" for each clutch material type so that Manufacturer A's organic clutch material (for example) can be quite different from Manufacturer B's organic clutch material. Many clutch materials can be doped with other materials to provide different characteristics than would be expected of that particular type of clutch material. Changing to a more aggressive clutch material can gain increases of 10% to as high as 60% in the amount of torque they can hold.
As to the rating of clutches, most manufacturers rate their clutches to the point of slip, instead of being able to sustain long term use at specified ratings. Torque ratings are based off of the average torque per crank rotation, if you buy a clutch which is border line with the amount of torque you put out, chances are its going to start slipping sooner than later.
Do I need a sprung or unsprung clutch? Many do not consider this an important issue. A sprung clutch allows it to act similarly to springs on a car. In this fashion, the clutch is “engaged”, slack is taken out of the springs, and then the clutch is fully engaged. The actual amount of travel of these springs in only a few millimeters. The theory is that the springs will dampen the engagement slightly and to soften driveline shock and reduce associated clutch engagement noise. To generalize, sprung clutches are preferred for street use and unsprung clutches are preferred for racing applications.
What are the various clutch construction methods?
a. Full face
b. Segmented*
c. Windowed*
d. Puck (AKA Paddle)
e. Multi Disc (AKA Multi Plate)
*These two construction methods represent the same reasoning and methodology with two different construction techniques depending on the manufacturer.
Full faced: Full round facing of material or full face with slight separations similar to sprung and unsprung clutch photo shown above.
Segmented: Generally associated with Kevlar clutches. The missing sections are designed for greater heat dissipation.
Windowed: Generally associated with Kevlar clutches. The missing sections are designed for greater heat dissipation.
Puck (AKA Paddle): Generally associated with higher power vehicles. Careful consideration should be given prior to using this type of clutch.
Multi Disc (AKA Multi Plate): Generally associated with higher power vehicles. Careful consideration should be given prior to using this type of clutch.
What causes increased clutch pedal pressure? Pressure plate clamp force. Just because you buy an aftermarket clutch does not mean you have to have a heavy clutch pedal. The amount of increase over the OEM clutch pedal pressure is dependent upon what the pressure plate manufacturer's specifications are.
Are there any drawbacks to high clamping pressure plates? Generally speaking, the higher clamping pressure of the pressure plate, the higher pressure you induce on your crankshaft thrust bearings.
Can I use XXX's pressure plate on YYY's clutch? No. All manufacturers plainly state to use the same brand components, so if you go with YYY, use all YYY components.
What is the most transmission friendly clutch? The OEM organic clutch is by far the easiest on your transmission. This is due to the lighter clamp loads of the OEM pressure plate and the organic clutch material. Organic materials, which are bound by resins, will almost always loose friction when they get very hot. This is because the resin melts and becomes almost like a lubricant rather than a bonding agent. Any increase in clamp load or clutch material coefficient of friction will increase the shock load to your gears.
Can I use a 6MT clutch in my 5MT? Yes, but it requires some modification to do so. this link provides detail on how to do so.
Can I use a 5MT clutch in my 6MT? Yes, but you do have to use the 6MT clutch fork.
So this gives me carte blanche to use either clutch willy-nilly then right? It means you CAN use them in either application, it doesn't mean you SHOULD.
How much torque will the OEM 5MT and 6MT clutches hold? Though no one knows for sure, common knowledge say that the 5MT will hold 300 TQ and the 6 MT will hold 400 TQ.
What clutch will hold the most power? Generally speaking, one that has:
a. Highly sprung pressure plate. The more clamping force the pressure plate exerts, the better it will grip.
b. High coefficient of friction clutch material. The higher the coefficient of friction, the better it will grip.
c. Increase the amount of surfaces. This can be accomplished by going to a twin or triple disc design.
What about a "Stage 1 clutch"? Stage 1, 2, 3, etc. clutches are just a marketing tool like Stage 1, 2, 3, etc. power packages for Subarus. Some manufacturers have them, some don't. While a staged clutch may suit your application, DO NOT use a staged clutch package as a methodology to purchase your clutch based on your staged Subaru.
So since I need to buy a clutch based on torque is there a list somewhere? Some asshat put together this list so you can make an idiot proof decision.
Where do I buy a clutch? Every Subaru/Import performance store sells them. For purchasing, support your local economy or the NASIOC Vendors.
How hard is it to install a clutch? Allow around five hours for install time. Professional installation, depending on your area, is around $300. This is one vehicle modification that should be farmed out to a professional unless you have the right tools/equipment and are mechanically skilled.
How do I install a clutch? Refer to the clutch manufacturer's instructions. For clutches without instructions, below are links to some of the better known clutch installation instructions:
Clutch replacement instructions
RS clutch instructions
OBS clutch instructions
scoobymods.com Clutch replacement instructions
Helpful link
Helpful link
Various SOA clutch/flywheel install instructions
5MB .pdf instructions
Are there any other important things to remember when replacing the clutch myself? Yes, unless using a new flywheel, the old flywheel must be resurfaced on a blanchard grinder or by a professional shop who uses that or other specific type of machinery for resurfacing. DO NOT use emery cloth, a Dremel tool, a regular lathe, or other shortcut. While flywheels work similar in fashion to brake rotors, you cannot get away with the unusual techniques some people use with brake rotors during a brake pad change.
Is there a bed in period for a new clutch? As with new brake pads, there is a bed-in period with clutches. This varies between manufacturers and is generally a period of less than 1000 miles. For more information as to how long and how to properly bed in your clutch, refer to your clutch manufacturer’s recommendations.
Old 05-23-2005, 07:08 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Flywheel FAQ
How does a lightweight flywheel improve performance? A transmission can be thought of as a fulcrum and lever in a car. First gear has a really long lever; second gear has a shorter lever, etc. The lever represents the mechanical advantage that gears give your vehicle. When your car is moving, you have two factors that are present during acceleration, one is driveline losses, which are constant and the variable, which is vehicle weight and the mechanical advantage supplied by each gear. While changing to a lighter flywheel will give the user little to no changes on a dyno, the apparent changes are quite dramatic due to the greater mechanical advantage. Consider these made up figures for consideration: Drive line losses, 45 pounds and vehicle mass (weight) at the driveline (remember your gear's mechanical advantage reduces your actual car weight). We know that within reason, vehicle mass is a constant. Now imagine if you reduced the driveline loss from 45 to 35 with the use of a lightweight flywheel. Since the engine has less drivetrain losses to compensate for, this means the "gained" horsepower can be applied to moving the vehicle mass. Using mathematics, one can realize that the higher you go up in gears, the less effect that a lightened flywheel will have to the overall equation.
How much will a lightweight flywheel affect my car's performance? This Excel document will allow you to find out for your WRX or STi application.
Are there any downsides to a lightweight flywheel? While the performance characteristics of a lightweight flywheel seem to be the perfect solution, there are compromises:
a. Low end performance is affected. This usually means that higher revs are necessary for smooth starts due to the reduced rotational mass. For drag racers, this can be a BIG issue.
b. Possible missfire check engine light.
c. Possible chatter, like missfire this affects some users and not others.
What causes a missfire CEL with lightweight flywheels? No one is really sure. There are theories though. One theory is that the Crank Position Sensor senses the rotational speed of your crankshaft. Since a lightweight flywheel reduces the rotation mass of your engine, your crankshaft accelerates and decelerates quicker than OEM specifications. Another theory is that there is a missmatch of information from your Crank Position Sensor and the Cam Position Sensor during acceleration and deceleration. This may or may not be caused by the slow reaction of the belt tensioner which will cause enough belt slop to give erroneous readings to the ECU. Since missfire CELs (due to lightweight flywheels) do not occur as often on the STi and the STi has two Cam Position Sensors, this adds further evidence that the missfire CEL has something to do with the Cam Position Sensor since there is only one on the WRX.
Which lightweight flywheel will not throw a missfire CEL? In truth, there is no lightweight flywheel that will not throw a missfire CEL. The odds of you throwing a missfire CEL are higher the lower in flywheel weight you go. Even with a “heavier” lightweight flywheel, you may throw a missfire CEL.
Will the use of a lightweight pulley increase my chances of a missfire CEL with a lightweight flywheel? Yes. To a smaller degree, lightweight pulleys also decrease rotation mass, adding their quicker acceleration and deceleration into the equation.
How do I fix a missfire CEL with a lightweight flywheel? The safest course of action is to use a portable OBDII code instrument and clear the codes frequently. Once you know the frequency of the missfire CELs, it will aid you in determining if this is an actual code or perhaps something to investigate further. While the missfire CEL code is a "safe code" (just an indicator and won't throw your car into safe or limp mode), it is never a good idea to drive around with the CEL on for extended periods of time as another, more serious code can be present without your knowledge. Additionally, it is not a wise idea to remove the missfire CELs via engine management software. Missfire codes can be an indication of a problem and removing their presence will remove possible symptoms of an actual problem.
Who is a good or a bad candidate for a lightweight flywheel? Arguably, the users whose driving technique is most highlighted by the benefits of a lightweight flywheel are people who autocross frequently. Many people are also genuinely happy with the performance increase in their daily driven vehicles as well. The only group that is generally dissatisfied are people who competitively drag race as the reduced rotational mass does not lend itself to their severe launch techniques.
Editors Note
My special thanks to the following personnel for their assistance in the formulation and research on this FAQ:
* NASIOC member DrDRum who came to my rescue and made the WONDERFUL Excel chart for lightweight flywheels. I wanted something ghetto, and he created something highly configurable and very pro looking.
* Tom @ Kartboy for giving me hands on experience with a complete clutch assembly and explaining the basics.
* David Koyle at ACT for humoring my questions after I met him at the Rim of the World.
* Andrew Yates for verifying a lot of my information and going over advanced clutch information.
This post was created because I wasn't able to find a good clutch/flywheel FAQ. I came up with the text based on LOTS of searching here. It was also created to be intentionally brand neutral so that it serves as a stepping stone for further research. Upon reading this you should have an idea of what type of clutch and/or flywheel best suits your needs. The manufacturer is up to you.
If you find an error in this FAQ, please PM me with factual details and I will update this post. Responses such as, "I have XXX's clutch and it's great!" or "XXX's flywheel cracked after 1 month" are not appreciated here, that is what the Car Parts Review Forum is for.
Old 05-23-2005, 09:00 PM   #3
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
awesome FAQ...as usual.
eltrouble is offline   Reply With Quote
Old 05-23-2005, 09:11 PM   #4
Andrewtech
Member#: 47821
Good work Ron! This will help alot of people.
Andrew
Andrewtech is offline   Reply With Quote
Old 05-23-2005, 10:00 PM   #5
intence
Member#: 58477
. Member #1 of
the witty MS Crew
another great FAQ. waiting on a suspension FAQ from you...
intence is offline   Reply With Quote
Old 05-23-2005, 10:07 PM   #6
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
^^ i second this motion ^^
Old 05-24-2005, 06:46 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
thumbs up!
ride5000 is online now   Reply With Quote
Old 05-28-2005, 05:35 AM   #8
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
Default Sticky?
Sticky? Do I hear Sticky?
Script to run during backup: (never mind the tortured syntax)
If (ThreadStarter == "Unabomber" & ThreadTitle Includes "Faq")
Then ThreadStatus == Sticky
endIf
GravelRash is offline   Reply With Quote
Old 05-28-2005, 03:22 PM   #9
STiTuner
Member#: 5778
09 135i
Jet Black
Something to Add
Add to clutch compunds
Organic material as it become hotter has less grip while carbon actually grips better under heat. a Night as at the drag strip will teach you this.
Add to stages of clutches
Rating of clutches, most manufacturers rate their clutches to the point of slip, instead of being able to sustain long term use at specified ratings. Torque ratings are based off of the average torque per crank roation, if you buy a clutch which is border line with the amount of torque you put out, chances are its going to start slipping sooner than later.
Notes for when considering the purchase of a carbon clutch. Make sure that what you are buying is a Full Carbon on Carbon assembly and not carbon on metal. carbon on metal tends to slip quickly and not last as long, especially under high temp. This causes more frequent replacement. carbon clutchs can NOT be fully rebuilt. There are replacment parts for carbon on metal clutches but a true carbon on carbon can only be "refreshed" to some extent
STiTuner is offline   Reply With Quote
Old 05-28-2005, 10:20 PM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
STiTuner, thank you very much for your wonderful input. I added the section about torque ratings as I somehow forgot it and you elegantly stated what needed to be mentioned. As to the info on carbon setup, this is 100% true from my research, but as I'm sure you have noticed, I have left out a lot of information such as you have mentioned. These FAQs go for 80% and to point out all the pros and cons of every clutch compound would make for a very long and very specific FAQ.
To everyone else, thanks for the appreciation! A suspension FAQ is in the batter's box and I hope to have my next FAQ done within a month.
Old 08-04-2005, 07:45 PM   #11
felixwankel88
Member#: 92876
2004 sti forester
java black
dang, GREAT info
felixwankel88 is offline   Reply With Quote
Old 08-08-2005, 01:50 AM   #12
InfamousDX
Member#: 25413
What is the weight of a stock 04 STI flywheel?
Old 08-08-2005, 12:06 PM   #13
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
18.9 lbs
Old 09-16-2005, 01:45 AM   #14
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
You may want to add a note in there that none of the clutch install instructions, apart from the SOA ones, mention you have to disconnect the clutch fork from the throwout bearing to separate the engine and tranny. I've been doing a clutch install for 3 weeks and just figured that out.
icantdrive75 is offline   Reply With Quote
Old 09-16-2005, 08:55 AM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
well normally you don't disconnect them to separate the engine/tranny... because you've already removed the hinge pin for the fork. the hinge is free to move at that point.
Old 09-16-2005, 05:54 PM   #16
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
Subaru instructions say to do it...I haven't been able to do it without taking it out. I think I remember someone saying you only have to on turbo models...but I might be making that up.
I could move my clutch fork back and forth, and when I removed this I could move it around freely. Either way. At least the info is here now so someone can do it if they need to.
Old 10-04-2005, 10:38 PM   #17
humara
Member#: 53289
04 wrx waggin'
wrb
this faq just saved me money!!! i was going to buy "too much" clutch.
humara is offline   Reply With Quote
Old 10-12-2005, 02:50 PM   #18
ofay
Member#: 69621
05 mines wrx RIP
still hatin ROTAS
how much tq should the stock clutch hold up to on a wrx?
ofay is offline   Reply With Quote
Old 10-12-2005, 04:56 PM   #19
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Stock clutches should be good for around 250-300 ft/lbs TQ from what I've heard. That means that for MANY users, the stock one is still the ticket.
Old 10-13-2005, 07:43 PM   #20
ofay
Member#: 69621
05 mines wrx RIP
still hatin ROTAS
at the wheels?
Old 10-13-2005, 08:18 PM   #21
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Originally Posted by ofay
at the wheels?
yes...specifically the flywheel.
Old 10-13-2005, 08:37 PM   #22
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
hahaha good one.
Another note if I may. If you buy a flywheel and are planning on installing it yourself, I had a problem with the dowel pins. They were not included with the flywheel. I couldn't find them anywhere. If this happens to you, take your old flywheel to a machine shop. They should have a tool called a dowel pin puller(go figure) that can get them out in under 5 minutes. Its basically a slide hammer with a special fitting on the end. The machine shop I went to didn't even charge me. Then you just bang them in with a hammer.
Old 10-14-2005, 12:33 AM   #23
ofay
Member#: 69621
05 mines wrx RIP
still hatin ROTAS
I said wheels and you said yes, flywheel? that doesnt make sense(unless of course thats a snide comment at the fact that its flywheel hp, and if thats the case, way to be an elitist when I asked an honest question)
Im just trying to find out if I make ~275lbs of tq if the stocker will hold up as long as I dont drive like a ham fisted monkey
Old 10-14-2005, 12:37 AM   #24
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
That torque is measured at the flywheel...the only thing that would matter when refering to clutch capacity.
And his comment was not snide nor elitist...it was witty and humorus.
Old 10-14-2005, 01:12 AM   #25
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
The previous post answers that one...
It was just a joke. But yeah, when referring to clutch capacity, it's torque measured at the flywheel. The stock clutch is perfectly fine for the power you're lookin for, anything beyond 300whp and you might need something stronger.
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Piston FAQ: Read if you are thinking about buying them! Unabomber Built Motor Discussion 82 06-26-2015 01:51 PM
Intercooler Hose FAQ: Read if you are thinking of buying them! Unabomber Newbies & FAQs 42 04-05-2014 10:18 PM
Spring/Strut/Coilover FAQ: Read if you are thinking of buying them! Unabomber Brakes, Steering & Suspension 39 04-19-2013 05:30 AM
