05-24-2005, 01:41 AM | #1 |
Member#: 51002
SCIC
Vehicle:2016 Pig STi Pearl |
Boost gauge question...
My newly installed boost gauge is reading 20 - 30 vacuum at idle.. and some when driving (not boosting) Then it reads normal boost when boosting... I thought it was supposed to show 0 all the time. Anyway let me know what I did wrong with the install pleeeease
05-24-2005, 01:43 AM | #2 |
Member#: 59993
International
Vehicle:Ass, grass or cash no one rides for free!! |
you're fine....
05-24-2005, 01:49 AM | #3 |
Member#: 51002
SCIC
w00t.. I ask because I've seen boost gauges run at 0 all day long, with no vacuum.. I thought maybe I put it in the wrong place or something.. thanks a bunch
05-24-2005, 01:53 AM | #4 |
Member#: 59993
International
anytime
05-24-2005, 01:20 PM | #5 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
Yup - when coasting along, or very low throttle, you'll see vacuum.
If someone had a boost gauge capable of reading vacuum that read 0 at idle, its hooked up wrong. |
05-24-2005, 02:17 PM | #6 |
Member#: 51002
SCIC
Also it doesn't really show boost unless its almost WOT.. my bov goes off.. even when it shows 0 or vacuum.. is this correct too?
05-24-2005, 02:37 PM | #7 |
Member#: 31511
SCIC
Vehicle:2003 GD2 GM4 BP9 www.ITNRally.org |
if anything check for kinks in the line, but I think you are fine.
I have two boost gauges in the car, the analog one is a little too sensitive and the digital one a tad delayed...but it has a peak hold reading which makes it the more useful of the two. RR |
05-24-2005, 04:25 PM | #8 |
Member#: 51002
SCIC
woot, rewiring tonight.. hah I'll check the tubes when I do it. I hooked up to the clock's dimmer so 2 of the 3 gauges are only on with the headlights.. so thanks RR and others, hopefully seeya at the thursday meet. I'll bring you a cookie if you come
05-24-2005, 04:43 PM | #9 |
Member#: 85354
Use teflon tape on the guage's threads and make sure there are no leaks anywhere.
05-25-2005, 05:37 AM | #10 | |
Member#: 8666
Vehicle:2005 STi Crystal Gray |
-wdb |
05-27-2005, 03:19 PM | #11 |
Member#: 51002
SCIC
I got it, I just needed to splice into a diff. wire, got the correct voltage and whatnot too. Thanks for the concern!
05-27-2005, 09:50 PM | #12 |
Member#: 69586
International
dirtysanchezalotapez
Boost Gauge question | neurotic | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-09-2001 04:09 PM |
GFB bov and factory boost gauge questions | shogunate83 | Newbies & FAQs | 2 | 10-31-2001 11:04 AM |
Boost Gauge Question | lbk16 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 09-17-2001 10:03 AM |
Boost Gauge Question | MaxPSI | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-12-2001 01:38 AM |
Installing boost gauge questions | jmott | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 06-09-2001 06:43 AM |
