Old 05-24-2005, 09:54 AM   #1
TurboCharged97L
Member#: 71508
1997 Impretzia
Artic Silver Metallic
Default Oil Leak ***
okay i just finished a full 97 jdm front clip sawp into my 97 L and after getting everything up and running i noticed smoke coming from the up-pipe. the smoke turned out to be oil leaking from the block. it seams that it just needs to be resealed or tightened up. its at the back of the block on the passenger side right where the end is bolted on to the main block. has anyone dealt with this and if so what can i do
TurboCharged97L is offline   Reply With Quote
Old 05-24-2005, 11:28 AM   #2
FastfreddyRs
Member#: 64808
2004 FXT & STI Wagon
Take it off. clean off the old silicone RTV. and reapply new RTV and no more oil problem.
FastfreddyRs is offline   Reply With Quote
Old 05-24-2005, 02:13 PM   #3
TurboCharged97L
Member#: 71508
1997 Impretzia
do i have to drain the oil first, and is this possible to do with the motor still in the car? and what is RTV
Old 05-24-2005, 02:19 PM   #4
Idahoser
Member#: 78147
93 impreza 4dr
280.000 and runs 100+
Stands for room temperature vulcanization. Get some good stuff and clean off the leaking area with some spray carb cleaner first.
Idahoser is offline   Reply With Quote
Old 05-24-2005, 03:18 PM   #5
TurboCharged97L
Member#: 71508
1997 Impretzia
any suggestions for what product to get to seal it? would this be a good one: http://www.accessconnect.com/gasket_maker_.htm
Old 05-24-2005, 03:33 PM   #6
Idahoser
Member#: 78147
93 impreza 4dr
Get the ultra, it stands heat and oil better.
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 07:23 PM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 04:23 PM
Oil leak just above oil filter Big_Hitter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-28-2003 09:57 AM
New Omori Oil temp install and oil leak mhbrown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-22-2003 07:10 PM
oil leak from front of engine, oil pump? drftsub Legacy Forum 14 01-06-2003 07:44 PM
