Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-24-2005, 04:02 PM   #1
sliver911
Member#: 87835
Question Low end bog, bad timing?
I just purchased a 94 legacy sport with the ej22t. the last owner just put in a new water pump and timing belt. Is it possible to retard/advance the timing when doing this. I believe that its not running like it should. I am also wondering if a bad cat or O2 sensor could cause the same issue. any help would be great. Thanks.
sliver911 is offline   Reply With Quote
Old 05-24-2005, 04:19 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
low end bog? welcome to the world of turbo engines(and an old one at that).
fibuz is offline   Reply With Quote
Old 05-24-2005, 09:32 PM   #3
sliver911
Member#: 87835
yeah, thats definately a given. but this is far worse than it should be. it backfires through the intake every once in a while, idles like a frieght train and will not accelerate hard at all. i think i located the problem.
Old 05-25-2005, 10:15 AM   #4
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Check to make sure the timing belt is on right, and then check to see if the crank pulley is loose. If the crank pulley has been loose for a long enough time, It will chew the key up, and allow the crank sprocket to rotate on the crackshaft, which REALLY affects how they run.
wrx_driver_2002 is offline   Reply With Quote
Old 05-25-2005, 05:51 PM   #5
suby2low
Member#: 82633
'08 WRX STI
and yes. it is really to screw up timing when changing the t-belt.
suby2low is offline   Reply With Quote
Old 05-26-2005, 12:50 AM   #6
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
If your crank timing gear is turning (I know it turns with the crank), I'd guess you're SOL. Hello new crankshaft? Let's hope it's not an interference engine, otherwise, hello new engine...
I'm not sure how the key being messed up outside the timing cover would affect the portion of the key that the timing sprocket runs on. Can you explain? Do you have experience with this?
Thanks!
Aaron
fastenova is offline   Reply With Quote
Old 05-26-2005, 08:02 AM   #7
ncarn8
Member#: 71419
so youve jumped straight to the engine rebuild line iof thinking.
have you discounted every other possibilty?
_ AFM, knock sensor, coils, fuel pump, etc etc?
An 02 sensor can cause it to run way rich, which can cause hesitation, but it should throw up a code if it detects abnormal voltage.
A blocked cat can cause it to run like a bag of crap as well, really hesitating, bucking etc, many things, (and it can be a reall ahole to isolate it as being the problem.)
Id check voltages, continuity, resistance, all that fun stuff before you buy a new engine for it. And fault codes too.
ncarn8 is offline   Reply With Quote
Old 05-26-2005, 10:29 AM   #8
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Thanks!
Aaron
Yes, I have expierience with this. That key holds two components on the crankshaft from spinning. It holds the Pulley (Which spins the outside belts) and the sprocket. When the pully comes loose, it grinds the key down to nothing, and at the same time, it widens the hole for the key in the crankshaft (Allowing what's left of the key, and the sprocket to rotate). I've seen them soo bad that we've had to replace engines because of it.
Sometimes you can just put loctite along with a new key, sprocket, and pulley, and be okay. The reason you have to replace the sprocket is because when the pulley is wobbling on the crankshaft, it rounds the surface of the sprocket.
If you reuse the sprocket (and it's surface is not flat anymore) it won't let the pulley set evenly on the sprocket. You can tighten the bolt down as tight as you can, but it will still work it's way loose again (because of the uneven sealing surface between the sprocket and the pulley). It's happened to me before.
Old 03-13-2012, 09:24 PM   #9
bbond06
Member#: 311626
1997 Impreza 2.2
blue
I have a 97 2.2 and i am having similar bogging issues. Bogs really bad on the low end but it seems to get better as it warms up. i have already replaced plugs, wires, coil, air filter, and fuel filter. any ideas for me?
bbond06 is offline   Reply With Quote
2005 lgt bad internal low end 06Roxy Built Motor Discussion 0 01-06-2008 07:00 PM
'95 legacy bogging badly on acceleration hklvette Normally Aspirated Powertrain 7 08-19-2007 09:41 PM
MY96 EJ18 low end bogging Drimmie Normally Aspirated Powertrain 17 06-23-2006 06:01 PM
Timing/low end bog. sliver911 Pre-2002 Factory Turbo Powertrain 4 05-24-2005 09:37 PM
Air intake - Increases top end power at a cost of low-end power? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-04-2002 08:22 PM
