Old 05-24-2005, 04:29 PM   #1
vica153
Member#: 76586
2006 9-2x Aero
Default Best/cheap heads for swap.
I plan on swapping out my 1.8 block for an legacy turbo block, I want use the 1.8 intake manifold for easy wiring, but what heads should i use (will fit)?
The legacy turbo heads, RS heads, N/A ej22 heads? (I plan on sending the cams to delta cams no matter which i do)
I would like to increase the compression ratio from stock legacy(or keep the same).
Decreasing the C.R. would make it terribly low wouldn't it?
Thanks,
Ken
vica153 is offline   Reply With Quote
Old 05-24-2005, 04:50 PM   #2
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
This doesn't sound like a conversion, sounds like an aftermarket forum thread. You would get a lot of help from over there man. Good luck though
benjaminetanyahoo is offline   Reply With Quote
Old 05-24-2005, 05:07 PM   #3
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Im using 98 DOHC RS heads on my ej20g. Your intake manifold should fit on those. If you have got the green go for a set of older STI heads.
Rick
RallySport Direct is offline   Reply With Quote
Old 05-25-2005, 03:07 PM   #4
vica153
Member#: 76586
2006 9-2x Aero
Anyone know if RS heads would raise or lower the CR?
Old 05-26-2005, 10:43 AM   #5
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
If you run the RS heads, you will need the RS intake manifold too.
If you want to keep your stock 1.8 intake manifold (like I did) then go with the 2.2 n/a heads. They bolt right up and you don't have to worry about the oil fittings it has built into it for the stock Legacy turbo.
Chad
subachad is offline   Reply With Quote
Old 05-26-2005, 11:10 AM   #6
svxtrem
Member#: 1008
2006 STI
Steel Grey Metallic
If you're interested, I have a complete set of DOHC heads including intake manifold, exhaust manifolds, etc from a '97 JDM turbo impreza. These have beautiful cloverleaf combustion chambers, and you can just bolt these onto a 2.2 block. I was going to do this, but sold the car. Will sell all parts for $300, you pay shipping.
svxtrem is offline   Reply With Quote
Old 05-26-2005, 11:50 AM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
*coughcoughpricewaywaytoolowcoughcough*
Old 05-26-2005, 12:59 PM   #8
svxtrem
Member#: 1008
2006 STI
Steel Grey Metallic
yes, the price is low, but I am moving, and don't need all of these parts sitting around. There are several suby owners in Michigan who know me and who have seen these.
WRX Heads for sale cheap think0rz Tri-State Area Private Classifieds 4 11-30-2009 12:08 PM
WRX Heads for sale cheap think0rz Engine/Power/Exhaust 12 11-30-2009 12:07 PM
CHEAP head unit for sale!!! BuggeyEYED Interior/Dressup/Audio & Security 4 10-17-2006 07:58 PM
brand new 05 wrx heads for sale cheap! ganderson155 Private 'For Sale' Classifieds 1 03-08-2006 10:54 PM
Best cheap, effective, non-exhaust mod for 2.2 Legacy? Davenow Normally Aspirated Powertrain 1 04-22-2003 03:22 PM
