Old 05-25-2005, 12:24 AM   #1
suby-brue
Member#: 56758
04 04 WRX - WRB
03 LLBean Outback - Green
Default Lighting Schematics - Aux Fog Light Help
I need to pass my PA state inspection on Saturday... and the inspections say you need to have all fog light turn off when the highbeams come on.
I installed some hella driving lights that currently are manually switched with a toggle switch with all 3 wires going to the battery (positive/ground and negative).
I pulled out my drivers side headlamp on my 2004 WRX and was surprised by the number of leads going to the headlamp assembly... It looks like there are 4 wires going to the lowbeam light.
Does anyone have a schematic showing what each wire does what on 2004 WRX headlight assemblies? I thought theres a way to wire up the grounding wire to something on the low beam (as per the hella instructions.
I've also seen some posts about disabling the foglight off when highbeams on option by cliping a wire on the back of the fusebox?
Any help would be appreciated.... My last resort is pulling the extra fogs for the inspection.
suby-brue is offline   Reply With Quote
Old 05-25-2005, 12:43 AM   #2
ChrisL2
Member#: 1444
You need to clarify what you are using first. Are they fog lights or driving lights? You call them both.
Fog lights are typically only supposed to be on when your low beams are on.
Driving lights are typically only supposed to be on when your high beams are on.
ChrisL2 is offline   Reply With Quote
Old 05-26-2005, 11:22 PM   #3
suby-brue
Member#: 56758
04 04 WRX - WRB
They are Hella Driving lights. I currently have them set up so they are independant of which lights are currently on (yes I have them directly switched from the battery).
My dealership (where I take my car for inspections) tells me all fogs/driving lights etc have to be off when the high-beams are on.
Old 05-27-2005, 12:38 AM   #4
ChrisL2
Member#: 1444
Auxiliary driving lamps shall not be substituted for headlamps. Auxiliary driving lamps may only be used with high headlamp beams.
http://www.pacode.com/secure/data/06...5/s175.66.html
This information at scoobymods might help (you'll have to register)
http://www.scoobymods.com/forums/showthread.php?t=2911
Old 05-29-2005, 08:05 PM   #5
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Driving lights supplaiment your headlights, and let you see farther when there isn't anyone else on the road. Characterized by a narrower, further reaching pattern.
Fog lights light up the few feet in front of the car to let you know you're still on the road when you cant see more than a few feet in front of you due to fog, snow, etc. Characterized by a wide, "shallow" pattern directly in front of the car.
Now, you say driving lights, so you need to wire them up to be on with the high beams, and off with the low beams.
This in no way helps you figure out which wire is which, but it at least tells you what your trying to do.
(option B would be to disconnect the lights and tell the inspectors their just for show).
tooocool49723 is offline   Reply With Quote
Old 05-29-2005, 08:27 PM   #6
MRF582
Member#: 48219
. Always drive
the race line .
i had to go through that with my old car in PA when i had my hella driving lights on. my solution : remove the lights (takes 5 mins) take it into inspection.install lights (5mins)
MRF582 is offline   Reply With Quote
Old 05-30-2005, 08:36 AM   #7
suby-brue
Member#: 56758
04 04 WRX - WRB
I did the disconnect for inspection method - but I'd really like to get these wired up correctly so I don't have to do this next year
WTB: Aux/fog light switch Nakioki SCIC Private Classifieds 8 05-26-2008 07:20 PM
Aux. Fog Lights SubaruMunkey02 Electrical & Lighting 2 11-10-2007 01:18 PM
FS: 04 wrx fog light and STI fog light cover, in wrb coolray Private 'For Sale' Classifieds 3 08-31-2005 12:46 PM
Good fog lights or good fog light bulbs Imprezive2002 Interior & Exterior Modification 10 08-02-2003 02:51 AM
FS: WRX Fog Lights & PIAA Fog Lights H5N1 Vancouver Impreza Club Forum -- VIC 10 08-08-2002 11:31 PM
