05-25-2005, 12:40 AM | #1 |
Member#: 16004
Vehicle:1998 2.5 RS - Blue Dreaming of Boost |
Using stock foglight switch with store bought wiring kit
We just installed some factory RS foglights in my friend's older impreza using a store bought foglight wiring kit which basically has three wires connecting to the switch:
power - connected to positive battery terminal, fused in between ground - grounded in the car lead out - wire goes to the positive terminal on the foglights This works fine when using the ghetto switch that the kit came with, but we want to use a factoryswitch. I've seen a few diagrams of the factory switch that all seem to contradict each other. We tried following one today and only ended up with a blown fuse. Could someone tell me how I can hook up a factory fog switch to my setup (power, ground, and lead out). Thanks Jonathan
05-25-2005, 01:29 AM | #2 |
Member#: 25989
NWIC
Vehicle:2009 WRX Built EJ257 Lightning Red Hatchback |
bump....I want to use a factory fog from my new electronic deer avoidance system. Any help would be much appreciated.
JC |
05-25-2005, 12:09 PM | #3 |
Member#: 44168
SCIC
Vehicle:2017 Silver Forester with not enough lights... |
Try this:
http://forums.nasioc.com/forums/show...ht=pin+diagram I was looking to do the same thing at one time. |
05-25-2005, 01:22 PM | #4 | |
Member#: 16004
So, my constant power wire from the battery I can hook up to "ACC Power" pin 6, and my positive lead out to the foglights I'd hook up to pin 4, with the ground of course at pin 2? This worked for you? jonathan |
WTB:wrx heated seat switches with plugs & wire. | joe r | Private 'Wanted' Classifieds | 0 | 03-27-2005 07:31 PM |
Stock Foglight Switch | Erconcepts | Private 'Wanted' Classifieds | 0 | 12-06-2004 11:23 PM |
help with non-stock foglight switch wiring | yeng | Electrical & Lighting | 5 | 02-19-2004 06:00 PM |
Using Stock Foglight Switch w/ Hellas | bleuquila | Electrical & Lighting | 35 | 12-31-2003 02:54 PM |
stock foglight switch with hella's? | wagonman | Electrical & Lighting | 3 | 12-28-2003 01:51 PM |
