Old 05-25-2005, 01:22 PM   #1
oilybirdy
Member#: 52754
2007 BMW 335i Coupe
Default Can I use cheap gas?
I have a 98 Legacy and we were going to sell it within the next 5-6 months, is it OK to use 87 octane fuel in it for the remainder of the time instead of 89?
oilybirdy is offline   Reply With Quote
Old 05-25-2005, 01:24 PM   #2
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
I thought the EJ25 only requires 87
thats all i've ever run
iamrazor is offline   Reply With Quote
Old 05-25-2005, 01:40 PM   #3
oilybirdy
Member#: 52754
2007 BMW 335i Coupe
You could very well be right, I don't have access to the manual at this moment but I guess that will be the way to find out (unless some helpful member wants to just give us the answer )
Old 05-25-2005, 01:40 PM   #4
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
"Tests have shown... Chevron outperforms other leading gasolines..."
I've been running Chevron or Shell primarily for the past several years. I have found I get better mileage on these than on cheap gas. But I also am anal about car stuff. I figure if the fuel will burn cleaner and keep my intake & exhaust ports cleaner, it's worth the extra few cents a gallon. Just remember, a few cents a gallon is less than 45 cents a fillup, and probably not more than $30 a year savings, assuming you fill up once a week. Really not all that drastic, IMO...
Yep, the EJ25 only requires 87 octane. Your ECU is probabl accustomed to 89, so if you switch, it will likely run sub-par for a few tanks. You can also reset your ECU to speed up the learning process.
fastenova is offline   Reply With Quote
Old 05-25-2005, 01:43 PM   #5
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Oh, I believe the EZ33 (premium) in the SVX and probably the older turbos were the only older Subies that needed plus or better. The new turbos (wrx, lgt) and the newer H6 take at least plus too. Someone correct me if I'm wrong.
-Aaron
Old 05-25-2005, 02:04 PM   #6
oilybirdy
Member#: 52754
2007 BMW 335i Coupe
Actually the newer turbo's require premium, our other car is an 05 LGT (NOT getting rid of that ) and we have to feed that 91/93.. but thats good to know its fine to feed the 'ole '98 87.
Old 05-25-2005, 02:44 PM   #7
JjSwee
Member#: 75880
96 legacy's 2.5 NA needed premium, they fixed that in 97 and gave the engine 10 more HP. Soo glad I got a 97. (sorry 96 guys)
JjSwee is offline   Reply With Quote
Old 05-25-2005, 06:13 PM   #8
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
87 chevron only for me for a longgg time...
fibuz is offline   Reply With Quote
Old 05-25-2005, 06:16 PM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
Chez 87 since my cars conception and never a problem.
tora is offline   Reply With Quote
Old 05-26-2005, 11:08 AM   #10
Gil
Member#: 20872
t3h rubber-neckers
must die!
i was concerned about the same thing.
http://forums.nasioc.com/forums/showthread.php?t=743132
but I've been running 97 the last 2 months and nothing bad has cropped up.
Gil is offline   Reply With Quote
Old 05-26-2005, 11:52 AM   #11
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
97!!!!!!!!!!!!!!!!???????????????????????
Old 05-26-2005, 11:57 AM   #12
Gil
Member#: 20872
t3h rubber-neckers
must die!
That's Right!!!!
Bow down to ME!!
Old 05-26-2005, 10:37 PM   #13
rogerd
Member#: 59934
2005 Legacy GT Wagon
Atlantic Blue
Ran the 95 on anybody's 87 until 2004. It's still in the family, still running happily on the cheapest 87 that can be found. No ill effects ever. And yes LGT's require premium. When I can I buy from Costco - $2.13 per.
rogerd is offline   Reply With Quote
Old 05-27-2005, 12:41 AM   #14
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
My old-skool LT requires premium.
IronMonkeyL255 is offline   Reply With Quote
can anybody use 245/40/18 tires? Toyo T1-S CHEAP elgorey Mid Atlantic Impreza Club -- MAIC 6 05-15-2006 05:22 PM
The price of gas. MSN Cheap Gas Finder MrMorninwood North West Impreza Club Forum -- NWIC 7 04-29-2006 04:25 PM
Where can I find cheap gas in Orange County powderdtoastman Southern California Impreza Club Forum -- SCIC 18 04-29-2006 04:01 AM
Want to complain about gas, find cheap gas prices? Post here. Matt Mid Atlantic Impreza Club -- MAIC 115 11-14-2005 01:51 AM
Can I use race gas/93 mix for a day at the track browniesti04 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-17-2005 08:16 PM
