#1 |
Member#: 86822
VIC
Vehicle:2004 WRX PSM |
I noticed my car won't allow me to switch into first when I'm going really slow. It has to be pretty much at a dead stop before it will allow me to. Is this common with all subaru's or what?
Also, my second gear sounds a little funny. Doesn't do it all the time. Just when it feels like it. It makes more of a high pitched noise. Hard to explain. Definately not quite like the rest. Assistance please! thanks Justin
#2 |
Member#: 68015
NWIC
Vehicle:2006 WRX TR Steel Gray Metallic |
deal with it?
im seems like subarus werent made to go into first when rolling. the high pitch noise just might be in ur head. turn up the music... |
#3 |
Visiting NASIOC Timeout
Member#: 34670
South East
Vehicle:If she smokes she pokes |
Make sure your fluid isn't low - especially if it's a new car.
#4 |
Member#: 13660
NESIC
Vehicle:04 WRX 5 speed 05 Impreza OBS |
first gear is always a bitch.
Either double clutch to first or don't put it in 1st unless your in a dead stop. |
#5 |
Member#: 86577
Vehicle:2014 Supercoolmobile Awesome Pearl Metallic |
Usually I put it in 2nd and engine brake, then clutch in and 1st is pretty easy to get into.
#6 |
Member#: 75678
Vehicle:2000 2.5 RS BRP |
1st gear is more of a bitch to get into than any other gear- but as long as you rev match it should be fine. I had a friend on an autox course drive my car and he was on the top of first and second- shifted 9 times around the 30 second course! So- if he can do it, I can learn to do it. I've been practicing for a while because i know its been tough to get into- just not autox course ready to be shiftin like that.
Cliff Notes: It can be done with rev matching with enough practice. |
#7 |
Member#: 33995
South East
Vehicle:2002 WRX Sedan Sedona Red Pearl |
it's because 1st gear isn't synchronized, just like reverse. You'll end up breaking your 1st gear if you keep trying to slam it into 1st from a roll.
Craig |
#8 |
Member#: 86577
1st gear does have a synchronizer.
#9 |
Member#: 81106
RMIC
Vehicle:1962 Mormon Missle Whitey White |
Here's a tip, if you are rolling and need to go into first, give the car a little bit of gas, everything lines up better and the gear slides right in.
#10 | |
Member#: 84148
Vehicle:2005 Wrx black |
yeah thats a good option or while you are rolling hold it to the 1st gear position and it should also slip in while you are slowing down. |
#11 |
Member#: 86577
Holding it in place is just waiting for the synchro. That causes wear on the synchro. It's better to rev match, as he describes.
#12 | |
Member#: 15393
Vehicle:MY00 2.5RS Coupe 5MT Silverthorn Metallic |
do what he said...I can double clutch into 1st going 10mph (not that I would do it all the time)
#13 | |
Member#: 75678
| Thread Tools | |
| Display Modes | |
| 05 tranny is finally in my 02 wagon, but first gear is weird... | dwike | Transmission (AT/MT) & Driveline | 0 | 03-30-2008 08:21 PM |
| I think my first gear is ****ed up | WRX_Mike | Transmission (AT/MT) & Driveline | 3 | 02-17-2006 10:56 PM |
| Pic of broken first gear. Which gear is this.. | quickscooby | Transmission (AT/MT) & Driveline | 2 | 01-03-2004 12:56 PM |
| I spoke too soon..... first gear is clicking.... | GregUnd | Texas Impreza Club Forum -- TXIC | 19 | 11-13-2002 07:32 PM |
| ('93-'01) Have no Fear, First Gear is Here | Aspen_2.5RS | Impreza Forum | 3 | 05-31-2001 12:30 AM |
