Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 05-26-2005, 01:48 AM   #1
evotell
Member#: 85492
07 STi WRB
06 Caterham Super 7
Default Upgrading to Wife 1.0
Last year a friend of mine upgraded from Girlfriend 4.0 to Wife 1.0 and found that it's a memory hog leaving few system resources for other applications. He is also now noticing the Wife 1.0 is also spawning Child-processes which are further consuming valuable resources. No mention of this particular phenomenon was included in the product documentation, though other users have informed me that this is to be expected due to the nature of the application.
Not only that, Wife 1.0 installs itself so that it is always launched at system initialization where it can monitor all other system activity. Some applications such as PokerNite 10.3 , Bachelor Party 2.5, and Pubnite 7.0 are no longer able to run on the system at all, causing the system to lockup when launched (even though the apps worked fine before).
Wife 1.0 provides no installation options. Thus, the installation of undesired plug-ins such as Mother-in-law 55.8 and the Brother-in-law Beta is unavoidable. Also, system performance seems to diminish with each passing day.
Some features my friend would like to see in the upcoming Wife 2.0:
A "don't remind me again" button.
Minimize button.
Ability to delete the "headache" file
An install feature that provides an option to uninstall 2.0 version without loss loss of other system resources.
An option to run the network driver in "promiscuous mode" allowing the the system's Hardware Probe feature to be much more useful/effective.
I myself wish I had decided to avoid all of the headaches associated with Wife 1.0 by sticking with Girlfriend 3.0 Even here, however, I have found many problems. Apparently you cannot install Girlfriend 4.0 on top of girlfriend 3.0. You must uninstall Girlfriend 3.0 first, otherwise the two versions of Girlfriend will have conflicts over shared use of the I/O port. Other users have told me that this is a long-standing problem that I should have been aware of. Guess that explains what happened to versions 1 and 2.
To make matters worse, the uninstall program for Girlfriend 3.0 doesn't work very well, leaving undesirable traces of the application in the system. Another identified problem is that all versions of Girlfriend have annoying little messages about the advantages of upgrading to Wife 1.0!
VIRUS ALERT
All users should be aware that Wife 1.0 has an undocumented bug. If you try to install Mistress 1.1 before uninstalling Wife 1.0, Wife 1.0 will delete MSMoney files before doing the uninstall itself. Once that happens, Mistress 1.1 won't install and you will get an "insufficient resources" error message. To avoid the aforementioned bug, try installing Mistress 1.1 on a different system and " never" run any file transfer applications(such as Laplink) between the two systems.
FYI: Don't even think about a shared directory!!!!!!!!!
evotell is offline   Reply With Quote
Old 05-30-2005, 11:14 AM   #2
JAUNE
Member#: 66263
2002 WRB WRX
TurboXS Stg 4
OMG I'm still with Girldfriend 2.0
Is it still supported? Can I upgrade or I need to re-install?
Thanks in advance
JAUNE is offline   Reply With Quote
Old 05-30-2005, 11:20 AM   #3
evotell
Member#: 85492
07 STi WRB
06 Caterham Super 7
yes support is still offered, however if you do decide to upgrade to wife 1 you may require our tech support hotline 1-800-help!
Old 05-30-2005, 01:08 PM   #4
pinkrobe
Member#: 55447
2002 WRX wgn/'10 STI
WRB/grey
If your version of Girlfriend or Wife is not performing well, try Bernard Callebeaut Tools. It's a small application that can be used in conjunction with other utilities like Shoe Shopper 4 and BackRub XP to really increase your system's performance and deliver smooth operation. BCT works on just about all versions.
pinkrobe is offline   Reply With Quote
3/4 or 1.0 inch HDPE front spacer for an '05 w/ a 2.89 inch speaker depth. Mike 01Hawk Car Audio, Video & Security 8 06-10-2010 02:16 AM
xbox 360 modding crew: It's time to upgrade to ixtreme 1.6... lateralus1082 Off-Topic 17 05-16-2009 04:45 PM
Is Cobb going to offer V1.0 owners an upgrade option? ScoobySnacker AccessPort 26 01-29-2007 11:35 PM
Girlfriend to Wife Upgrade HekWRX Texas Impreza Club Forum -- TXIC 17 12-05-2005 05:44 PM
Safe to hit 1.0 bar in every gear? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 08-02-2002 04:13 PM
